S32V234 PCIE no space for EP
xiaofeng_sz
Hi.
I have a custom EP Device connected to S32V234 on pcie bus.
When Linux starts, the following problems occur:
The above figure shows that the EP device BAR0 needs 256MB of mapping space, but the PCIE space of S32V234 is insufficient, causing the allocation to fail.
Can someone help me in finding a solution please?
Thank you very much.
bpe
Support to S32V234 is done only via tickets. If you wish NXP Technical Support
to contact you with regards to the problem described in this post, please make
sure you registered on NXP Website with your corporate e-Mail address and open
a Support Case.
Platon
