an error occured when using sja1110 gPTP
xiaoshumiao
Dear NXP fellows:
I am using S32G-VNP-RDB3 and Linux BSP 38.0
I have configured pfe0 to communicate with sja1110 port 4 through sgmii, and can ping. I want to synchronize the time between s32g and sja1110 through pfe0 and sja1110 port 4 interface.
Referring to the configuration of "gptp_sja1110x", I added gPTP statck on the "switch_config_s32g_vnp_rdb" and configured gptp. Finally, I compiled and generated flash_image.bin, renamed it to sja1110_uc.bin, and copied it to /lib/firmware.
But an error occurred, as follows:
I'm guessing the error is here:
For detailed log please refer to the attached file
I can't solve this, and would really appreciate your help.
xiaoshumiao
Hi @alejandro_e
Thank you very much for your reply. This method still doesn’t work and other errors will occur.
I refer to this to solve the problem
https://community.nxp.com/t5/S32G/s32g-vnp-rdb2-Errror-when-uploading-sja1110-uc-and-using-gPTP/m-p/...
alejandro_e
Hello @xiaoshumiao,
Checking the logs you added it seems that the problems is only the loading and not the gPTP configuration. Please check the jumpers in J198 and ensure the following configuration:
I tested it successfully with said configuration:
s32g399ardb3 login: root
root@s32g399ardb3:~# dmesg | grep -i "sja"
[    0.591985] gpio-345 (sja1110-rst-phy-t1): hogged as output/low
[    0.597484] gpio-402 (sja1110-rst-core): hogged as output/low
[    6.765011] sja1110: loading out-of-tree module taints kernel.
[    6.765512] SPI driver sja1110 has no spi_device_id for nxp,sja1110-switch
[    6.765516] SPI driver sja1110 has no spi_device_id for nxp,sja1110-uc
[    6.765614] sja1110 spi5.0: probing uc
[    6.765743] sja1110 spi5.1: probing switch
[    6.766024] sja1110 spi5.1: Could not get GPIO from device tree
[    6.766044] sja1110 spi5.1: [sja1110_post_probe_upload_worker] Trying to initialize switch
[    6.766659] sja1110 spi5.1: Direct firmware load for sja1110_switch.bin failed with error -2
[    6.766668] sja1110 spi5.1: request_firmware failed with -2
[    6.766673] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC
[    6.769220] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin'
[    6.769227] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 125376
[    6.769302] sja1110 spi5.0: [sja1110_pre_uc_upload] firmware appears to be valid
[    6.769340] sja1110 spi5.0: [sja1110_pre_uc_upload] \xc2\xb5C not ready for download (Status=0x31)
[    6.769430] sja1110 spi5.0: Uploading firmware...
[    7.061479] sja1110 spi5.0: Upload successfully verified!
root@s32g399ardb3:~# ls /lib/firmware/
s32g_pfe_class.fw  s32g_pfe_util.fw  sja1110_uc.bin
 Let me know if you keep having problems.
xiaoshumiao
Hi @alejandro_e
I have confirmed that the configuration of J189 is correct. The configuration of rdb3 booting from sd card is also correct.
I tested it again. When I directly compiled "switch_config_s32g_vnp_rdb" without any modification and loaded it, there was no error“
Spoiler
[ 6.995965] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 6.996275] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.001365] systemd[1]: Starting Load Kernel Modules...
[ 7.017206] sja1110: loading out-of-tree module taints kernel.
[ 7.023197] SPI driver sja1110 has no spi_device_id for nxp,sja1110-switch
[ 7.023203] SPI driver sja1110 has no spi_device_id for nxp,sja1110-uc
[ 7.023294] sja1110 spi5.0: probing uc
[ 7.023415] sja1110 spi5.1: probing switch
[ 7.023668] sja1110 spi5.1: Could not get GPIO from device tree
[ 7.023690] sja1110 spi5.1: [sja1110_post_probe_upload_worker] Trying to initialize switch
[ 7.024403] sja1110 spi5.1: Direct firmware load for sja1110_switch.bin failed with error -2
[ 7.024413] sja1110 spi5.1: request_firmware failed with -2
[ 7.024419] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC
S[ 7.026935] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin'
t[ 7.026946] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 126400
a[ 7.027015] sja1110 spi5.0: [sja1110_pre_uc_upload] firmware appears to be valid
r[ 7.027050] sja1110 spi5.0: [sja1110_pre_uc_upload] µC not ready for download (Status=0x31)
t[ 7.027138] sja1110 spi5.0: Uploading firmware...
Startin[ 7.138512] systemd[1]: Starting Generate network units from Kernel command line...
g Generate network …ts from Kernel command line...
Starting [ 7.166366] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.184599] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: disabled.
Star[ 7.210767] systemd[1]: Starting Coldplug All udev Devices...
[ OK ] Started Journal [ 7.236049] systemd[1]: Started Journal Service.
Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Finished [ 7.319044] sja1110 spi5.0: Upload successfully verified!
Set the console keyboard layout.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module efi_pstore.
[ OK ] Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Modules.
When I only add gptp_config in Middleware and don't make any modifications, compile and load, there will be an error. That is to say, adding gptp_config will cause an error when loading.
Spoiler
Starting Load K[ 7.073122] SPI driver sja1110 has no spi_device_id for nxp,sja1110-switch
e[ 7.073128] SPI driver sja1110 has no spi_device_id for nxp,sja1110-uc
r[ 7.073214] sja1110 spi5.0: probing uc
n[ 7.073340] sja1110 spi5.1: probing switch
e[ 7.073596] sja1110 spi5.1: Could not get GPIO from device tree
l[ 7.073611] sja1110 spi5.1: [sja1110_post_probe_upload_worker] Trying to initialize switch
[ 7.074373] sja1110 spi5.1: Direct firmware load for sja1110_switch.bin failed with error -2
M[ 7.074383] sja1110 spi5.1: request_firmware failed with -2
od[ 7.074390] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC
u[ 7.077579] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin'
les[ 7.077593] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 131104
[[ 7.077698] sja1110 spi5.0: [sja1110_pre_uc_upload] µC not ready for download (Status=0x31)
0[ 7.077815] sja1110 spi5.0: Uploading firmware...
m...
Starti[ 7.186666] systemd[1]: Starting Generate network units from Kernel command line...
ng Generate network …ts from Kernel command line...
Starting [ 7.214398] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.239162] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: disabled.
[ 7.239520] systemd[1]: Starting Coldplug All udev Devices...
[ OK ] Started Jour[ 7.272430] systemd[1]: Started Journal Service.
nal Service.
[ OK ] Finished Set the console keyboard layout.
[ 7.459749] random: crng init done
[ 7.459769] random: 44 urandom warning(s) missed due to ratelimiting
[ 7.463272] sja1110 spi5.0: [sja1110_uc_parse_status_many] Upload error detected in status message 31600 (status=0x36,err=0x5b)
[ 7.463285] sja1110 spi5.0: Upload error detected!
[ 7.463290] sja1110 spi5.0: uploading firmware failed with 91
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
I think it's a problem with the spi rate, or there's something wrong with the uboot settings.
Spoiler
=> printenv
baudrate=115200
board_rev=F
boot_fdt=try
boot_mtd=booti
bootargs=root=/dev/ram rw earlycon loglevel=7
bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; else run netboot;fi
bootdelay=2
bootscript=echo Running bootscript from mmc ...; source
console=ttyLF0
eth1addr=00:01:be:be:ef:11
ethact=eth_pfeng
fdt_addr=0x83000000
fdt_enable_hs400es=fdt addr ${fdt_addr}; fdt rm /soc/mmc no-1-8-v; fdt resize;
fdt_file=s32g399a-rdb3.dtb
fdt_high=0xffffffffffffffff
fdt_override=;
fdtcontroladdr=ffa97000
flashboot=echo Booting from flash...; run flashbootargs;mtd read Kernel ${loadaddr};mtd read DTB ${fdt_addr};mtd read Rootfs ${ramdisk_addr};${boot_mtd} ${loadaddr} ${ramdisk_addr} ${fdt_addr};
flashbootargs=setenv bootargs console=${console},${baudrate} root=/dev/ram rw earlycon nohz=off coherent_pool=64M;setenv flashsize 0x04000000;
hwconfig=serdes0:mode=pcie,clock=ext;pcie0:mode=rc;serdes1:mode=xpcs0&xpcs1,clock=ext,fmhz=125;xpcs1_0:speed=2G5;xpcs1_1:speed=2G5
image=Image
initrd_high=0xffffffffffffffff
ipaddr=10.0.0.100
jtagboot=echo Booting using jtag...; ${boot_mtd} ${loadaddr} ${ramdisk_addr} ${fdt_addr}
jtagsdboot=echo Booting loading Linux with ramdisk from SD...; run loadimage; run loadramdisk; run loadfdt;${boot_mtd} ${loadaddr} ${ramdisk_addr} ${fdt_addr}
loadaddr=0x80000000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}; run fdt_override;
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
loadtftpfdt=tftp ${fdt_addr} ${fdt_file};
loadtftpimage=tftp ${loadaddr} ${image};
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} earlycon nohz=off coherent_pool=64M
mmcboot=echo Booting from mmc ...; run mmcargs; if run loadfdt; then ${boot_mtd} ${loadaddr} - ${fdt_addr}; else echo WARN: Cannot load the DT; fi;
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp earlycon nohz=off coherent_pool=64M
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then ${boot_mtd} ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then ${boot_mtd}; else echo WARN: Cannot load the DT; fi; fi; else ${boot_mtd}; fi;
netmask=255.255.255.0
nfsboot=echo Booting from net using tftp and nfs...; run nfsbootargs;run loadtftpimage; run loadtftpfdt;${boot_mtd} ${loadaddr} - ${fdt_addr};
nfsbootargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs rw ip=${ipaddr}:${serverip}::${netmask}::eth0:off nfsroot=${serverip}:/tftpboot/rfs,nolock,v3,tcp earlycon nohz=off coherent_pool=64M
pfe1_phy_addr=8
pfe1addr=00:01:be:be:ef:22
pfe2addr=00:01:be:be:ef:33
pfeaddr=00:01:be:be:ef:11
pfeng_mode=enable,sgmii,sgmii,rgmii
pfengemac=0
ramdisk_addr=0x90000000
s32cc_gmac_mode=enable
script=boot.scr
serverip=10.0.0.1
stderr=serial@401c8000
stdin=serial@401c8000
stdout=serial@401c8000
update_sd_firmware=if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if mmc dev ${mmcdev}; then if ${get_cmd} ${update_sd_firmware_filename}; then setexpr fw_sz ${filesize} / 0x200; setexpr fw_sz ${fw_sz} - 7; setexpr loadaddr ${loadaddr} + 0x1000; mmc write ${loadaddr} 0x8 ${fw_sz}; fi; fi
update_sd_firmware_filename=fip.s32
Environment size: 3538/8188 bytes
alejandro_e
Hello @xiaoshumiao,
From the logs I can see that the download was actually completed, please see this part:
 if you check sja1110_init.h#L53, which is the module in charge of loading the firmware you can see the following:
The status is completed (0x36) and there is no error (0x5B=91). I am assuming you are using the Yocto build, in that setup, you can modify the patch in: .../sources/meta-alb/recipes-kernel/sja1110/sja1110/0001-s32g274a-rdb2-Add-support-for-S32G-VNP-RDB2.patch and add COMPLETED as a correct state, in here:
after that you can test if the functionalities related to the SJA1110 still work correctly.
Please let me know the result of the test.
xiaoshumiao
Hi @alejandro_e
alejandro_e
Hello @xiaoshumiao,
I'm glad you were able to solve the problem. Thanks for the reference for the solution.
If you encounter any other problem feel free to create a new post.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2083859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ean%20error%20occured%20when%20using%20sja1110%20gPTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20fellows%3A%3C%2FP%3E%3CP%3EI%20am%20using%20S32G-VNP-RDB3%20and%20Linux%20BSP%2038.0%3C%2FP%3E%3CP%3EI%20have%20configured%20pfe0%20to%20communicate%20with%20sja1110%20port%204%20through%20sgmii%2C%20and%20can%20ping.%20I%20want%20to%20synchronize%20the%20time%20between%20s32g%20and%20sja1110%20through%20pfe0%20and%20sja1110%20port%204%20interface.%3C%2FP%3E%3CP%3EReferring%20to%20the%20configuration%20of%20%22gptp_sja1110x%22%2C%20I%20added%20gPTP%20statck%20on%20the%20%22switch_config_s32g_vnp_rdb%22%20and%20configured%20gptp.%20Finally%2C%20I%20compiled%20and%20generated%20flash_image.bin%2C%20renamed%20it%20to%20sja1110_uc.bin%2C%20and%20copied%20it%20to%20%2Flib%2Ffirmware.%3C%2FP%3E%3CP%3EBut%20an%20error%20occurred%2C%20as%20follows%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiaoshumiao_0-1745235794086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiaoshumiao_0-1745235794086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334071iCD543D091095AB46%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiaoshumiao_0-1745235794086.png%22%20alt%3D%22xiaoshumiao_0-1745235794086.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI'm%20guessing%20the%20error%20is%20here%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiaoshumiao_1-1745235852368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiaoshumiao_1-1745235852368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334072iF7BEDFBBB687EBCD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiaoshumiao_1-1745235852368.png%22%20alt%3D%22xiaoshumiao_1-1745235852368.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiaoshumiao_2-1745235892615.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiaoshumiao_2-1745235892615.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334073i416E99EABD63D0CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiaoshumiao_2-1745235892615.png%22%20alt%3D%22xiaoshumiao_2-1745235892615.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFor%20detailed%20log%20please%20refer%20to%20the%20attached%20file%3C%2FP%3E%3CP%3EI%20can't%20solve%20this%2C%20and%20would%20really%20appreciate%20your%20help.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2085609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20an%20error%20occured%20when%20using%20sja1110%20gPTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231689%22%20target%3D%22_blank%22%3E%40xiaoshumiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20glad%20you%20were%20able%20to%20solve%20the%20problem.%20Thanks%20for%20the%20reference%20for%20the%20solution.%3C%2FP%3E%0A%3CP%3EIf%20you%20encounter%20any%20other%20problem%20feel%20free%20to%20create%20a%20new%20post.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2085345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20an%20error%20occured%20when%20using%20sja1110%20gPTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20reply.%20This%20method%20still%20doesn%E2%80%99t%20work%20and%20other%20errors%20will%20occur.%3C%2FP%3E%3CP%3EI%20refer%20to%20this%20to%20solve%20the%20problem%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2Fs32g-vnp-rdb2-Errror-when-uploading-sja1110-uc-and-using-gPTP%2Fm-p%2F1610265%2Fthread-id%2F2396%2Fhighlight%2Ftrue%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2Fs32g-vnp-rdb2-Errror-when-uploading-sja1110-uc-and-using-gPTP%2Fm-p%2F1610265%2Fthread-id%2F2396%2Fhighlight%2Ftrue%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20an%20error%20occured%20when%20using%20sja1110%20gPTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231689%22%20target%3D%22_blank%22%3E%40xiaoshumiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EFrom%20the%20logs%20I%20can%20see%20that%20the%20download%20was%20actually%20completed%2C%20please%20see%20this%20part%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%5B%207.463272%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_uc_parse_status_many%5D%20Upload%20error%20detected%20in%20status%20message%2031600%20(status%3D0x36%2Cerr%3D0x5b)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%26nbsp%3Bif%20you%20check%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-archive%2Fautoivnsw_sja1110_linux%2Fblob%2Fac06f130d512e75edcf98d1a8304edd90055e525%2Fsja1110_init.h%23L53%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esja1110_init.h%23L53%3C%2FA%3E%2C%20which%20is%20the%20module%20in%20charge%20of%20loading%20the%20firmware%20you%20can%20see%20the%20following%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1745361788142.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1745361788142.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334365i4AE087010282A1E9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1745361788142.png%22%20alt%3D%22alejandro_e_0-1745361788142.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20status%20is%20completed%20(0x36)%20and%20there%20is%20no%20error%20(0x5B%3D91).%20I%20am%20assuming%20you%20are%20using%20the%20Yocto%20build%2C%20in%20that%20setup%2C%20you%20can%20modify%20the%20patch%20in%3A%26nbsp%3B%3CSTRONG%3E...%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fsja1110%2Fsja1110%2F0001-s32g274a-rdb2-Add-support-for-S32G-VNP-RDB2.patch%26nbsp%3B%3C%2FSTRONG%3Eand%20add%26nbsp%3B%3CSTRONG%3ECOMPLETED%3C%2FSTRONG%3E%20as%20a%20correct%20state%2C%20in%20here%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_1-1745362130548.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_1-1745362130548.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334366iBAF2C2DFB8EF6BCE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_1-1745362130548.png%22%20alt%3D%22alejandro_e_1-1745362130548.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eafter%20that%20you%20can%20test%20if%20the%20functionalities%20related%20to%20the%20SJA1110%20still%20work%20correctly.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%20let%20me%20know%20the%20result%20of%20the%20test.%3C%2FP%3E%0A%3CP%3EThanks%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20an%20error%20occured%20when%20using%20sja1110%20gPTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20have%20confirmed%20that%20the%20configuration%20of%20J189%20is%20correct.%20The%20configuration%20of%20rdb3%20booting%20from%20sd%20card%20is%20also%20correct.%3C%2FP%3E%3CP%3EI%20tested%20it%20again.%20When%20I%20directly%20compiled%20%22switch_config_s32g_vnp_rdb%22%20without%20any%20modification%20and%20loaded%20it%2C%20there%20was%20no%20error%E2%80%9C%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESpoiler%3C%2FA%3E%3CNOSCRIPT%3E%20(Highlight%20to%20read)%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%5B%206.995965%5D%20systemd%5B1%5D%3A%20Condition%20check%20resulted%20in%20OpenVSwitch%20configuration%20for%20cleanup%20being%20skipped.%3CBR%20%2F%3E%5B%206.996275%5D%20systemd%5B1%5D%3A%20Condition%20check%20resulted%20in%20File%20System%20Check%20on%20Root%20Device%20being%20skipped.%3CBR%20%2F%3E%5B%207.001365%5D%20systemd%5B1%5D%3A%20Starting%20Load%20Kernel%20Modules...%3CBR%20%2F%3E%5B%207.017206%5D%20sja1110%3A%20loading%20out-of-tree%20module%20taints%20kernel.%3CBR%20%2F%3E%5B%207.023197%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-switch%3CBR%20%2F%3E%5B%207.023203%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-uc%3CBR%20%2F%3E%5B%207.023294%5D%20sja1110%20spi5.0%3A%20probing%20uc%3CBR%20%2F%3E%5B%207.023415%5D%20sja1110%20spi5.1%3A%20probing%20switch%3CBR%20%2F%3E%5B%207.023668%5D%20sja1110%20spi5.1%3A%20Could%20not%20get%20GPIO%20from%20device%20tree%3CBR%20%2F%3E%5B%207.023690%5D%20sja1110%20spi5.1%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20switch%3CBR%20%2F%3E%5B%207.024403%5D%20sja1110%20spi5.1%3A%20Direct%20firmware%20load%20for%20sja1110_switch.bin%20failed%20with%20error%20-2%3CBR%20%2F%3E%5B%207.024413%5D%20sja1110%20spi5.1%3A%20request_firmware%20failed%20with%20-2%3CBR%20%2F%3E%5B%207.024419%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20uC%3CBR%20%2F%3ES%5B%207.026935%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_init_hw%5D%20loaded%20fw%20'sja1110_uc.bin'%3CBR%20%2F%3Et%5B%207.026946%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20Found%20firmware%20of%20size%20126400%3CBR%20%2F%3Ea%5B%207.027015%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20firmware%20appears%20to%20be%20valid%3CBR%20%2F%3Er%5B%207.027050%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20not%20ready%20for%20download%20(Status%3D0x31)%3CBR%20%2F%3Et%5B%207.027138%5D%20sja1110%20spi5.0%3A%20Uploading%20firmware...%3CBR%20%2F%3Eing%20Load%20Kernel%20Modules...%3CBR%20%2F%3EStartin%5B%207.138512%5D%20systemd%5B1%5D%3A%20Starting%20Generate%20network%20units%20from%20Kernel%20command%20line...%3CBR%20%2F%3Eg%20Generate%20network%20%E2%80%A6ts%20from%20Kernel%20command%20line...%3CBR%20%2F%3EStarting%20%5B%207.166366%5D%20systemd%5B1%5D%3A%20Starting%20Remount%20Root%20and%20Kernel%20File%20Systems...%3CBR%20%2F%3ERemount%20Root%20and%20Kernel%20File%20Systems...%3CBR%20%2F%3E%5B%207.184599%5D%20EXT4-fs%20(mmcblk0p2)%3A%20re-mounted.%20Opts%3A%20(null).%20Quota%20mode%3A%20disabled.%3CBR%20%2F%3EStar%5B%207.210767%5D%20systemd%5B1%5D%3A%20Starting%20Coldplug%20All%20udev%20Devices...%3CBR%20%2F%3Eting%20Coldplug%20All%20udev%20Devices...%3CBR%20%2F%3E%5B%20OK%20%5D%20Started%20Journal%20%5B%207.236049%5D%20systemd%5B1%5D%3A%20Started%20Journal%20Service.%3CBR%20%2F%3EService.%3CBR%20%2F%3E%5B%20OK%20%5D%20Mounted%20Huge%20Pages%20File%20System.%3CBR%20%2F%3E%5B%20OK%20%5D%20Mounted%20POSIX%20Message%20Queue%20File%20System.%3CBR%20%2F%3E%5B%20OK%20%5D%20Mounted%20Kernel%20Debug%20File%20System.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20%5B%207.319044%5D%20sja1110%20spi5.0%3A%20Upload%20successfully%20verified!%3CBR%20%2F%3ESet%20the%20console%20keyboard%20layout.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20configfs.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20drm.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20efi_pstore.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20fuse.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Modules.%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B%206.995965%5D%20systemd%5B1%5D%3A%20Condition%20check%20resulted%20in%20OpenVSwitch%20configuration%20for%20cleanup%20being%20skipped.%5B%206.996275%5D%20systemd%5B1%5D%3A%20Condition%20check%20resulted%20in%20File%20System%20Check%20on%20Root%20Device%20being%20skipped.%5B%207.001365%5D%20systemd%5B1%5D%3A%20Starting%20Load%20Kernel%20Modules...%5B%207.017206%5D%20sja1110%3A%20loading%20out-of-tree%20module%20taints%20kernel.%5B%207.023197%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-switch%5B%207.023203%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-uc%5B%207.023294%5D%20sja1110%20spi5.0%3A%20probing%20uc%5B%207.023415%5D%20sja1110%20spi5.1%3A%20probing%20switch%5B%207.023668%5D%20sja1110%20spi5.1%3A%20Could%20not%20get%20GPIO%20from%20device%20tree%5B%207.023690%5D%20sja1110%20spi5.1%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20switch%5B%207.024403%5D%20sja1110%20spi5.1%3A%20Direct%20firmware%20load%20for%20sja1110_switch.bin%20failed%20with%20error%20-2%5B%207.024413%5D%20sja1110%20spi5.1%3A%20request_firmware%20failed%20with%20-2%5B%207.024419%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20uCS%5B%207.026935%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_init_hw%5D%20loaded%20fw%20'sja1110_uc.bin't%5B%207.026946%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20Found%20firmware%20of%20size%20126400a%5B%207.027015%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20firmware%20appears%20to%20be%20validr%5B%207.027050%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20not%20ready%20for%20download%20(Status%3D0x31)t%5B%207.027138%5D%20sja1110%20spi5.0%3A%20Uploading%20firmware...ing%20Load%20Kernel%20Modules...Startin%5B%207.138512%5D%20systemd%5B1%5D%3A%20Starting%20Generate%20network%20units%20from%20Kernel%20command%20line...g%20Generate%20network%20%E2%80%A6ts%20from%20Kernel%20command%20line...Starting%20%5B%207.166366%5D%20systemd%5B1%5D%3A%20Starting%20Remount%20Root%20and%20Kernel%20File%20Systems...Remount%20Root%20and%20Kernel%20File%20Systems...%5B%207.184599%5D%20EXT4-fs%20(mmcblk0p2)%3A%20re-mounted.%20Opts%3A%20(null).%20Quota%20mode%3A%20disabled.Star%5B%207.210767%5D%20systemd%5B1%5D%3A%20Starting%20Coldplug%20All%20udev%20Devices...ting%20Coldplug%20All%20udev%20Devices...%5B%20OK%20%5D%20Started%20Journal%20%5B%207.236049%5D%20systemd%5B1%5D%3A%20Started%20Journal%20Service.Service.%5B%20OK%20%5D%20Mounted%20Huge%20Pages%20File%20System.%5B%20OK%20%5D%20Mounted%20POSIX%20Message%20Queue%20File%20System.%5B%20OK%20%5D%20Mounted%20Kernel%20Debug%20File%20System.%5B%20OK%20%5D%20Finished%20%5B%207.319044%5D%20sja1110%20spi5.0%3A%20Upload%20successfully%20verified!Set%20the%20console%20keyboard%20layout.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20configfs.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20drm.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20efi_pstore.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20fuse.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Modules.%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EWhen%20I%20only%20add%20gptp_config%20in%20Middleware%20and%20don't%20make%20any%20modifications%2C%20compile%20and%20load%2C%20there%20will%20be%20an%20error.%20That%20is%20to%20say%2C%20adding%20gptp_config%20will%20cause%20an%20error%20when%20loading.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESpoiler%3C%2FA%3E%3CNOSCRIPT%3E%20(Highlight%20to%20read)%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3EStarting%20Load%20K%5B%207.073122%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-switch%3CBR%20%2F%3Ee%5B%207.073128%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-uc%3CBR%20%2F%3Er%5B%207.073214%5D%20sja1110%20spi5.0%3A%20probing%20uc%3CBR%20%2F%3En%5B%207.073340%5D%20sja1110%20spi5.1%3A%20probing%20switch%3CBR%20%2F%3Ee%5B%207.073596%5D%20sja1110%20spi5.1%3A%20Could%20not%20get%20GPIO%20from%20device%20tree%3CBR%20%2F%3El%5B%207.073611%5D%20sja1110%20spi5.1%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20switch%3CBR%20%2F%3E%5B%207.074373%5D%20sja1110%20spi5.1%3A%20Direct%20firmware%20load%20for%20sja1110_switch.bin%20failed%20with%20error%20-2%3CBR%20%2F%3EM%5B%207.074383%5D%20sja1110%20spi5.1%3A%20request_firmware%20failed%20with%20-2%3CBR%20%2F%3Eod%5B%207.074390%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20uC%3CBR%20%2F%3Eu%5B%207.077579%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_init_hw%5D%20loaded%20fw%20'sja1110_uc.bin'%3CBR%20%2F%3Eles%5B%207.077593%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20Found%20firmware%20of%20size%20131104%3CBR%20%2F%3Esja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20firmware%20appears%20to%20be%20valid%3CBR%20%2F%3E%5B%5B%207.077698%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20not%20ready%20for%20download%20(Status%3D0x31)%3CBR%20%2F%3E0%5B%207.077815%5D%20sja1110%20spi5.0%3A%20Uploading%20firmware...%3CBR%20%2F%3Em...%3CBR%20%2F%3EStarti%5B%207.186666%5D%20systemd%5B1%5D%3A%20Starting%20Generate%20network%20units%20from%20Kernel%20command%20line...%3CBR%20%2F%3Eng%20Generate%20network%20%E2%80%A6ts%20from%20Kernel%20command%20line...%3CBR%20%2F%3EStarting%20%5B%207.214398%5D%20systemd%5B1%5D%3A%20Starting%20Remount%20Root%20and%20Kernel%20File%20Systems...%3CBR%20%2F%3ERemount%20Root%20and%20Kernel%20File%20Systems...%3CBR%20%2F%3E%5B%207.239162%5D%20EXT4-fs%20(mmcblk0p2)%3A%20re-mounted.%20Opts%3A%20(null).%20Quota%20mode%3A%20disabled.%3CBR%20%2F%3E%5B%207.239520%5D%20systemd%5B1%5D%3A%20Starting%20Coldplug%20All%20udev%20Devices...%3CBR%20%2F%3EStarting%20Coldplug%20All%20udev%20Devices...%3CBR%20%2F%3E%5B%20OK%20%5D%20Started%20Jour%5B%207.272430%5D%20systemd%5B1%5D%3A%20Started%20Journal%20Service.%3CBR%20%2F%3Enal%20Service.%3CBR%20%2F%3E%5B%20OK%20%5D%20Mounted%20Huge%20Pages%20File%20System.%3CBR%20%2F%3E%5B%20OK%20%5D%20Mounted%20POSIX%20Message%20Queue%20File%20System.%3CBR%20%2F%3E%5B%20OK%20%5D%20Mounted%20Kernel%20Debug%20File%20System.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Set%20the%20console%20keyboard%20layout.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20configfs.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20drm.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20efi_pstore.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20fuse.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Modules.%3CBR%20%2F%3E%5B%207.459749%5D%20random%3A%20crng%20init%20done%3CBR%20%2F%3E%5B%207.459769%5D%20random%3A%2044%20urandom%20warning(s)%20missed%20due%20to%20ratelimiting%3CBR%20%2F%3E%5B%207.463272%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_uc_parse_status_many%5D%20Upload%20error%20detected%20in%20status%20message%2031600%20(status%3D0x36%2Cerr%3D0x5b)%3CBR%20%2F%3E%5B%207.463285%5D%20sja1110%20spi5.0%3A%20Upload%20error%20detected!%3CBR%20%2F%3E%5B%207.463290%5D%20sja1110%20spi5.0%3A%20uploading%20firmware%20failed%20with%2091%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Generate%20network%20units%20from%20Kernel%20command%20line.%3CBR%20%2F%3E%5B%20OK%20%5D%20Finished%20Remount%20Root%20and%20Kernel%20File%20Systems.%3CBR%20%2F%3EMounting%20FUSE%20Control%20File%20System...%3CBR%20%2F%3EMounting%20Kernel%20Configuration%20File%20System...%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3EStarting%20Load%20K%5B%207.073122%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-switche%5B%207.073128%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-ucr%5B%207.073214%5D%20sja1110%20spi5.0%3A%20probing%20ucn%5B%207.073340%5D%20sja1110%20spi5.1%3A%20probing%20switche%5B%207.073596%5D%20sja1110%20spi5.1%3A%20Could%20not%20get%20GPIO%20from%20device%20treel%5B%207.073611%5D%20sja1110%20spi5.1%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20switch%5B%207.074373%5D%20sja1110%20spi5.1%3A%20Direct%20firmware%20load%20for%20sja1110_switch.bin%20failed%20with%20error%20-2M%5B%207.074383%5D%20sja1110%20spi5.1%3A%20request_firmware%20failed%20with%20-2od%5B%207.074390%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20uCu%5B%207.077579%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_init_hw%5D%20loaded%20fw%20'sja1110_uc.bin'les%5B%207.077593%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20Found%20firmware%20of%20size%20131104sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20firmware%20appears%20to%20be%20valid%5B%5B%207.077698%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20not%20ready%20for%20download%20(Status%3D0x31)0%5B%207.077815%5D%20sja1110%20spi5.0%3A%20Uploading%20firmware...m...Starti%5B%207.186666%5D%20systemd%5B1%5D%3A%20Starting%20Generate%20network%20units%20from%20Kernel%20command%20line...ng%20Generate%20network%20%E2%80%A6ts%20from%20Kernel%20command%20line...Starting%20%5B%207.214398%5D%20systemd%5B1%5D%3A%20Starting%20Remount%20Root%20and%20Kernel%20File%20Systems...Remount%20Root%20and%20Kernel%20File%20Systems...%5B%207.239162%5D%20EXT4-fs%20(mmcblk0p2)%3A%20re-mounted.%20Opts%3A%20(null).%20Quota%20mode%3A%20disabled.%5B%207.239520%5D%20systemd%5B1%5D%3A%20Starting%20Coldplug%20All%20udev%20Devices...Starting%20Coldplug%20All%20udev%20Devices...%5B%20OK%20%5D%20Started%20Jour%5B%207.272430%5D%20systemd%5B1%5D%3A%20Started%20Journal%20Service.nal%20Service.%5B%20OK%20%5D%20Mounted%20Huge%20Pages%20File%20System.%5B%20OK%20%5D%20Mounted%20POSIX%20Message%20Queue%20File%20System.%5B%20OK%20%5D%20Mounted%20Kernel%20Debug%20File%20System.%5B%20OK%20%5D%20Finished%20Set%20the%20console%20keyboard%20layout.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20configfs.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20drm.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20efi_pstore.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Module%20fuse.%5B%20OK%20%5D%20Finished%20Load%20Kernel%20Modules.%5B%207.459749%5D%20random%3A%20crng%20init%20done%5B%207.459769%5D%20random%3A%2044%20urandom%20warning(s)%20missed%20due%20to%20ratelimiting%5B%207.463272%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_uc_parse_status_many%5D%20Upload%20error%20detected%20in%20status%20message%2031600%20(status%3D0x36%2Cerr%3D0x5b)%5B%207.463285%5D%20sja1110%20spi5.0%3A%20Upload%20error%20detected!%5B%207.463290%5D%20sja1110%20spi5.0%3A%20uploading%20firmware%20failed%20with%2091%5B%20OK%20%5D%20Finished%20Generate%20network%20units%20from%20Kernel%20command%20line.%5B%20OK%20%5D%20Finished%20Remount%20Root%20and%20Kernel%20File%20Systems.Mounting%20FUSE%20Control%20File%20System...Mounting%20Kernel%20Configuration%20File%20System...%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EI%20think%20it's%20a%20problem%20with%20the%20spi%20rate%2C%20or%20there's%20something%20wrong%20with%20the%20uboot%20settings.%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESpoiler%3C%2FA%3E%3CNOSCRIPT%3E%20(Highlight%20to%20read)%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E%3D%26gt%3B%20printenv%3CBR%20%2F%3Ebaudrate%3D115200%3CBR%20%2F%3Eboard_rev%3DF%3CBR%20%2F%3Eboot_fdt%3Dtry%3CBR%20%2F%3Eboot_mtd%3Dbooti%3CBR%20%2F%3Ebootargs%3Droot%3D%2Fdev%2Fram%20rw%20earlycon%20loglevel%3D7%3CBR%20%2F%3Ebootcmd%3Dmmc%20dev%20%24%7Bmmcdev%7D%3B%20if%20mmc%20rescan%3B%20then%20if%20run%20loadimage%3B%20then%20run%20mmcboot%3B%20else%20run%20netboot%3B%20fi%3B%20else%20run%20netboot%3Bfi%3CBR%20%2F%3Ebootdelay%3D2%3CBR%20%2F%3Ebootscript%3Decho%20Running%20bootscript%20from%20mmc%20...%3B%20source%3CBR%20%2F%3Econsole%3DttyLF0%3CBR%20%2F%3Eeth1addr%3D00%3A01%3Abe%3Abe%3Aef%3A11%3CBR%20%2F%3Eethact%3Deth_pfeng%3CBR%20%2F%3Efdt_addr%3D0x83000000%3CBR%20%2F%3Efdt_enable_hs400es%3Dfdt%20addr%20%24%7Bfdt_addr%7D%3B%20fdt%20rm%20%2Fsoc%2Fmmc%20no-1-8-v%3B%20fdt%20resize%3B%3CBR%20%2F%3Efdt_file%3Ds32g399a-rdb3.dtb%3CBR%20%2F%3Efdt_high%3D0xffffffffffffffff%3CBR%20%2F%3Efdt_override%3D%3B%3CBR%20%2F%3Efdtcontroladdr%3Dffa97000%3CBR%20%2F%3Eflashboot%3Decho%20Booting%20from%20flash...%3B%20run%20flashbootargs%3Bmtd%20read%20Kernel%20%24%7Bloadaddr%7D%3Bmtd%20read%20DTB%20%24%7Bfdt_addr%7D%3Bmtd%20read%20Rootfs%20%24%7Bramdisk_addr%7D%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3B%3CBR%20%2F%3Eflashbootargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fram%20rw%20earlycon%20nohz%3Doff%20coherent_pool%3D64M%3Bsetenv%20flashsize%200x04000000%3B%3CBR%20%2F%3Ehwconfig%3Dserdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D2G5%3CBR%20%2F%3Eimage%3DImage%3CBR%20%2F%3Einitrd_high%3D0xffffffffffffffff%3CBR%20%2F%3Eipaddr%3D10.0.0.100%3CBR%20%2F%3Ejtagboot%3Decho%20Booting%20using%20jtag...%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3CBR%20%2F%3Ejtagsdboot%3Decho%20Booting%20loading%20Linux%20with%20ramdisk%20from%20SD...%3B%20run%20loadimage%3B%20run%20loadramdisk%3B%20run%20loadfdt%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3CBR%20%2F%3Eloadaddr%3D0x80000000%3CBR%20%2F%3Eloadbootscript%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bscript%7D%3B%3CBR%20%2F%3Eloadfdt%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%20run%20fdt_override%3B%3CBR%20%2F%3Eloadimage%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3CBR%20%2F%3Eloadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%3CBR%20%2F%3Eloadtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3B%3CBR%20%2F%3Emmcargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%24%7Bmmcroot%7D%20earlycon%20nohz%3Doff%20coherent_pool%3D64M%3CBR%20%2F%3Emmcboot%3Decho%20Booting%20from%20mmc%20...%3B%20run%20mmcargs%3B%20if%20run%20loadfdt%3B%20then%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%20else%20echo%20WARN%3A%20Cannot%20load%20the%20DT%3B%20fi%3B%3CBR%20%2F%3Emmcdev%3D0%3CBR%20%2F%3Emmcpart%3D1%3CBR%20%2F%3Emmcroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rw%3CBR%20%2F%3Enetargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%24%7Bserverip%7D%3A%24%7Bnfsroot%7D%2Cv3%2Ctcp%20earlycon%20nohz%3Doff%20coherent_pool%3D64M%3CBR%20%2F%3Enetboot%3Decho%20Booting%20from%20net%20...%3B%20run%20netargs%3B%20if%20test%20%24%7Bip_dyn%7D%20%3D%20yes%3B%20then%20setenv%20get_cmd%20dhcp%3B%20else%20setenv%20get_cmd%20tftp%3B%20fi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%3B%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20yes%20%7C%7C%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20if%20%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%20then%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%20else%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20%24%7Bboot_mtd%7D%3B%20else%20echo%20WARN%3A%20Cannot%20load%20the%20DT%3B%20fi%3B%20fi%3B%20else%20%24%7Bboot_mtd%7D%3B%20fi%3B%3CBR%20%2F%3Enetmask%3D255.255.255.0%3CBR%20%2F%3Enfsboot%3Decho%20Booting%20from%20net%20using%20tftp%20and%20nfs...%3B%20run%20nfsbootargs%3Brun%20loadtftpimage%3B%20run%20loadtftpfdt%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%3CBR%20%2F%3Enfsbootargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20rw%20ip%3D%24%7Bipaddr%7D%3A%24%7Bserverip%7D%3A%3A%24%7Bnetmask%7D%3A%3Aeth0%3Aoff%20nfsroot%3D%24%7Bserverip%7D%3A%2Ftftpboot%2Frfs%2Cnolock%2Cv3%2Ctcp%20earlycon%20nohz%3Doff%20coherent_pool%3D64M%3CBR%20%2F%3Epfe1_phy_addr%3D8%3CBR%20%2F%3Epfe1addr%3D00%3A01%3Abe%3Abe%3Aef%3A22%3CBR%20%2F%3Epfe2addr%3D00%3A01%3Abe%3Abe%3Aef%3A33%3CBR%20%2F%3Epfeaddr%3D00%3A01%3Abe%3Abe%3Aef%3A11%3CBR%20%2F%3Epfeng_mode%3Denable%2Csgmii%2Csgmii%2Crgmii%3CBR%20%2F%3Epfengemac%3D0%3CBR%20%2F%3Eramdisk_addr%3D0x90000000%3CBR%20%2F%3Es32cc_gmac_mode%3Denable%3CBR%20%2F%3Escript%3Dboot.scr%3CBR%20%2F%3Eserverip%3D10.0.0.1%3CBR%20%2F%3Estderr%3Dserial%40401c8000%3CBR%20%2F%3Estdin%3Dserial%40401c8000%3CBR%20%2F%3Estdout%3Dserial%40401c8000%3CBR%20%2F%3Eupdate_sd_firmware%3Dif%20test%20%24%7Bip_dyn%7D%20%3D%20yes%3B%20then%20setenv%20get_cmd%20dhcp%3B%20else%20setenv%20get_cmd%20tftp%3B%20fi%3B%20if%20mmc%20dev%20%24%7Bmmcdev%7D%3B%20then%20if%20%24%7Bget_cmd%7D%20%24%7Bupdate_sd_firmware_filename%7D%3B%20then%20setexpr%20fw_sz%20%24%7Bfilesize%7D%20%2F%200x200%3B%20setexpr%20fw_sz%20%24%7Bfw_sz%7D%20-%207%3B%20setexpr%20loadaddr%20%24%7Bloadaddr%7D%20%2B%200x1000%3B%20mmc%20write%20%24%7Bloadaddr%7D%200x8%20%24%7Bfw_sz%7D%3B%20fi%3B%20fi%3CBR%20%2F%3Eupdate_sd_firmware_filename%3Dfip.s32%3C%2FP%3E%3CP%3EEnvironment%20size%3A%203538%2F8188%20bytes%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%3D%26gt%3B%20printenvbaudrate%3D115200board_rev%3DFboot_fdt%3Dtryboot_mtd%3Dbootibootargs%3Droot%3D%2Fdev%2Fram%20rw%20earlycon%20loglevel%3D7bootcmd%3Dmmc%20dev%20%24%7Bmmcdev%7D%3B%20if%20mmc%20rescan%3B%20then%20if%20run%20loadimage%3B%20then%20run%20mmcboot%3B%20else%20run%20netboot%3B%20fi%3B%20else%20run%20netboot%3Bfibootdelay%3D2bootscript%3Decho%20Running%20bootscript%20from%20mmc%20...%3B%20sourceconsole%3DttyLF0eth1addr%3D00%3A01%3Abe%3Abe%3Aef%3A11ethact%3Deth_pfengfdt_addr%3D0x83000000fdt_enable_hs400es%3Dfdt%20addr%20%24%7Bfdt_addr%7D%3B%20fdt%20rm%20%2Fsoc%2Fmmc%20no-1-8-v%3B%20fdt%20resize%3Bfdt_file%3Ds32g399a-rdb3.dtbfdt_high%3D0xfffffffffffffffffdt_override%3D%3Bfdtcontroladdr%3Dffa97000flashboot%3Decho%20Booting%20from%20flash...%3B%20run%20flashbootargs%3Bmtd%20read%20Kernel%20%24%7Bloadaddr%7D%3Bmtd%20read%20DTB%20%24%7Bfdt_addr%7D%3Bmtd%20read%20Rootfs%20%24%7Bramdisk_addr%7D%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3Bflashbootargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fram%20rw%20earlycon%20nohz%3Doff%20coherent_pool%3D64M%3Bsetenv%20flashsize%200x04000000%3Bhwconfig%3Dserdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D2G5image%3DImageinitrd_high%3D0xffffffffffffffffipaddr%3D10.0.0.100jtagboot%3Decho%20Booting%20using%20jtag...%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7Djtagsdboot%3Decho%20Booting%20loading%20Linux%20with%20ramdisk%20from%20SD...%3B%20run%20loadimage%3B%20run%20loadramdisk%3B%20run%20loadfdt%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7Dloadaddr%3D0x80000000loadbootscript%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bscript%7D%3Bloadfdt%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%20run%20fdt_override%3Bloadimage%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7Dloadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3Bloadtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3Bmmcargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%24%7Bmmcroot%7D%20earlycon%20nohz%3Doff%20coherent_pool%3D64Mmmcboot%3Decho%20Booting%20from%20mmc%20...%3B%20run%20mmcargs%3B%20if%20run%20loadfdt%3B%20then%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%20else%20echo%20WARN%3A%20Cannot%20load%20the%20DT%3B%20fi%3Bmmcdev%3D0mmcpart%3D1mmcroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rwnetargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%24%7Bserverip%7D%3A%24%7Bnfsroot%7D%2Cv3%2Ctcp%20earlycon%20nohz%3Doff%20coherent_pool%3D64Mnetboot%3Decho%20Booting%20from%20net%20...%3B%20run%20netargs%3B%20if%20test%20%24%7Bip_dyn%7D%20%3D%20yes%3B%20then%20setenv%20get_cmd%20dhcp%3B%20else%20setenv%20get_cmd%20tftp%3B%20fi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%3B%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20yes%20%7C%7C%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20if%20%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%20then%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%20else%20if%20test%20%24%7Bboot_fdt%7D%20%3D%20try%3B%20then%20%24%7Bboot_mtd%7D%3B%20else%20echo%20WARN%3A%20Cannot%20load%20the%20DT%3B%20fi%3B%20fi%3B%20else%20%24%7Bboot_mtd%7D%3B%20fi%3Bnetmask%3D255.255.255.0nfsboot%3Decho%20Booting%20from%20net%20using%20tftp%20and%20nfs...%3B%20run%20nfsbootargs%3Brun%20loadtftpimage%3B%20run%20loadtftpfdt%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3Bnfsbootargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20rw%20ip%3D%24%7Bipaddr%7D%3A%24%7Bserverip%7D%3A%3A%24%7Bnetmask%7D%3A%3Aeth0%3Aoff%20nfsroot%3D%24%7Bserverip%7D%3A%2Ftftpboot%2Frfs%2Cnolock%2Cv3%2Ctcp%20earlycon%20nohz%3Doff%20coherent_pool%3D64Mpfe1_phy_addr%3D8pfe1addr%3D00%3A01%3Abe%3Abe%3Aef%3A22pfe2addr%3D00%3A01%3Abe%3Abe%3Aef%3A33pfeaddr%3D00%3A01%3Abe%3Abe%3Aef%3A11pfeng_mode%3Denable%2Csgmii%2Csgmii%2Crgmiipfengemac%3D0ramdisk_addr%3D0x90000000s32cc_gmac_mode%3Denablescript%3Dboot.scrserverip%3D10.0.0.1stderr%3Dserial%40401c8000stdin%3Dserial%40401c8000stdout%3Dserial%40401c8000update_sd_firmware%3Dif%20test%20%24%7Bip_dyn%7D%20%3D%20yes%3B%20then%20setenv%20get_cmd%20dhcp%3B%20else%20setenv%20get_cmd%20tftp%3B%20fi%3B%20if%20mmc%20dev%20%24%7Bmmcdev%7D%3B%20then%20if%20%24%7Bget_cmd%7D%20%24%7Bupdate_sd_firmware_filename%7D%3B%20then%20setexpr%20fw_sz%20%24%7Bfilesize%7D%20%2F%200x200%3B%20setexpr%20fw_sz%20%24%7Bfw_sz%7D%20-%207%3B%20setexpr%20loadaddr%20%24%7Bloadaddr%7D%20%2B%200x1000%3B%20mmc%20write%20%24%7Bloadaddr%7D%200x8%20%24%7Bfw_sz%7D%3B%20fi%3B%20fiupdate_sd_firmware_filename%3Dfip.s32Environment%20size%3A%203538%2F8188%20bytes%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20an%20error%20occured%20when%20using%20sja1110%20gPTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231689%22%20target%3D%22_blank%22%3E%40xiaoshumiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EChecking%20the%20logs%20you%20added%20it%20seems%20that%20the%20problems%20is%20only%20the%20loading%20and%20not%20the%20gPTP%20configuration.%20Please%20check%20the%20jumpers%20in%20J198%20and%20ensure%20the%20following%20configuration%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1745266247187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1745266247187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334109iFE46DF1EE00369C3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1745266247187.png%22%20alt%3D%22alejandro_e_0-1745266247187.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20tested%20it%20successfully%20with%20said%20configuration%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Es32g399ardb3%20login%3A%20root%0Aroot%40s32g399ardb3%3A~%23%20dmesg%20%7C%20grep%20-i%20%22sja%22%0A%5B%20%20%20%200.591985%5D%20gpio-345%20(sja1110-rst-phy-t1)%3A%20hogged%20as%20output%2Flow%0A%5B%20%20%20%200.597484%5D%20gpio-402%20(sja1110-rst-core)%3A%20hogged%20as%20output%2Flow%0A%5B%20%20%20%206.765011%5D%20sja1110%3A%20loading%20out-of-tree%20module%20taints%20kernel.%0A%5B%20%20%20%206.765512%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-switch%0A%5B%20%20%20%206.765516%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-uc%0A%5B%20%20%20%206.765614%5D%20sja1110%20spi5.0%3A%20probing%20uc%0A%5B%20%20%20%206.765743%5D%20sja1110%20spi5.1%3A%20probing%20switch%0A%5B%20%20%20%206.766024%5D%20sja1110%20spi5.1%3A%20Could%20not%20get%20GPIO%20from%20device%20tree%0A%5B%20%20%20%206.766044%5D%20sja1110%20spi5.1%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20switch%0A%5B%20%20%20%206.766659%5D%20sja1110%20spi5.1%3A%20Direct%20firmware%20load%20for%20sja1110_switch.bin%20failed%20with%20error%20-2%0A%5B%20%20%20%206.766668%5D%20sja1110%20spi5.1%3A%20request_firmware%20failed%20with%20-2%0A%5B%20%20%20%206.766673%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20uC%0A%5B%20%20%20%206.769220%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_init_hw%5D%20loaded%20fw%20'sja1110_uc.bin'%0A%5B%20%20%20%206.769227%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20Found%20firmware%20of%20size%20125376%0A%5B%20%20%20%206.769302%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20firmware%20appears%20to%20be%20valid%0A%5B%20%20%20%206.769340%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20%5Cxc2%5Cxb5C%20not%20ready%20for%20download%20(Status%3D0x31)%0A%5B%20%20%20%206.769430%5D%20sja1110%20spi5.0%3A%20Uploading%20firmware...%0A%5B%20%20%20%207.061479%5D%20sja1110%20spi5.0%3A%20Upload%20successfully%20verified!%0Aroot%40s32g399ardb3%3A~%23%20ls%20%2Flib%2Ffirmware%2F%0As32g_pfe_class.fw%20%20s32g_pfe_util.fw%20%20sja1110_uc.bin%0Aroot%40s32g399ardb3%3A~%23%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%26nbsp%3BLet%20me%20know%20if%20you%20keep%20having%20problems.%3C%2FP%3E%3C%2FLINGO-BODY%3E
