an error occured when using sja1110 gPTP
3,238 次查看
xiaoshumiao
Dear NXP fellows:
I am using S32G-VNP-RDB3 and Linux BSP 38.0
I have configured pfe0 to communicate with sja1110 port 4 through sgmii, and can ping. I want to synchronize the time between s32g and sja1110 through pfe0 and sja1110 port 4 interface.
Referring to the configuration of "gptp_sja1110x", I added gPTP statck on the "switch_config_s32g_vnp_rdb" and configured gptp. Finally, I compiled and generated flash_image.bin, renamed it to sja1110_uc.bin, and copied it to /lib/firmware.
But an error occurred, as follows:
I'm guessing the error is here:
For detailed log please refer to the attached file
I can't solve this, and would really appreciate your help.
3,134 次查看
xiaoshumiao
Hi @alejandro_e
Thank you very much for your reply. This method still doesn’t work and other errors will occur.
I refer to this to solve the problem
https://community.nxp.com/t5/S32G/s32g-vnp-rdb2-Errror-when-uploading-sja1110-uc-and-using-gPTP/m-p/...
5 回复数
3,215 次查看
alejandro_e
Hello @xiaoshumiao,
Checking the logs you added it seems that the problems is only the loading and not the gPTP configuration. Please check the jumpers in J198 and ensure the following configuration:
I tested it successfully with said configuration:
s32g399ardb3 login: root
root@s32g399ardb3:~# dmesg | grep -i "sja"
[    0.591985] gpio-345 (sja1110-rst-phy-t1): hogged as output/low
[    0.597484] gpio-402 (sja1110-rst-core): hogged as output/low
[    6.765011] sja1110: loading out-of-tree module taints kernel.
[    6.765512] SPI driver sja1110 has no spi_device_id for nxp,sja1110-switch
[    6.765516] SPI driver sja1110 has no spi_device_id for nxp,sja1110-uc
[    6.765614] sja1110 spi5.0: probing uc
[    6.765743] sja1110 spi5.1: probing switch
[    6.766024] sja1110 spi5.1: Could not get GPIO from device tree
[    6.766044] sja1110 spi5.1: [sja1110_post_probe_upload_worker] Trying to initialize switch
[    6.766659] sja1110 spi5.1: Direct firmware load for sja1110_switch.bin failed with error -2
[    6.766668] sja1110 spi5.1: request_firmware failed with -2
[    6.766673] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC
[    6.769220] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin'
[    6.769227] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 125376
[    6.769302] sja1110 spi5.0: [sja1110_pre_uc_upload] firmware appears to be valid
[    6.769340] sja1110 spi5.0: [sja1110_pre_uc_upload] \xc2\xb5C not ready for download (Status=0x31)
[    6.769430] sja1110 spi5.0: Uploading firmware...
[    7.061479] sja1110 spi5.0: Upload successfully verified!
root@s32g399ardb3:~# ls /lib/firmware/
s32g_pfe_class.fw  s32g_pfe_util.fw  sja1110_uc.bin
 Let me know if you keep having problems.
3,199 次查看
xiaoshumiao
Hi @alejandro_e
I have confirmed that the configuration of J189 is correct. The configuration of rdb3 booting from sd card is also correct.
I tested it again. When I directly compiled "switch_config_s32g_vnp_rdb" without any modification and loaded it, there was no error“
破坏者
[ 6.995965] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 6.996275] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.001365] systemd[1]: Starting Load Kernel Modules...
[ 7.017206] sja1110: loading out-of-tree module taints kernel.
[ 7.023197] SPI driver sja1110 has no spi_device_id for nxp,sja1110-switch
[ 7.023203] SPI driver sja1110 has no spi_device_id for nxp,sja1110-uc
[ 7.023294] sja1110 spi5.0: probing uc
[ 7.023415] sja1110 spi5.1: probing switch
[ 7.023668] sja1110 spi5.1: Could not get GPIO from device tree
[ 7.023690] sja1110 spi5.1: [sja1110_post_probe_upload_worker] Trying to initialize switch
[ 7.024403] sja1110 spi5.1: Direct firmware load for sja1110_switch.bin failed with error -2
[ 7.024413] sja1110 spi5.1: request_firmware failed with -2
[ 7.024419] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC
S[ 7.026935] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin'
t[ 7.026946] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 126400
a[ 7.027015] sja1110 spi5.0: [sja1110_pre_uc_upload] firmware appears to be valid
r[ 7.027050] sja1110 spi5.0: [sja1110_pre_uc_upload] µC not ready for download (Status=0x31)
t[ 7.027138] sja1110 spi5.0: Uploading firmware...
Startin[ 7.138512] systemd[1]: Starting Generate network units from Kernel command line...
g Generate network …ts from Kernel command line...
Starting [ 7.166366] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.184599] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: disabled.
Star[ 7.210767] systemd[1]: Starting Coldplug All udev Devices...
[ OK ] Started Journal [ 7.236049] systemd[1]: Started Journal Service.
Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Finished [ 7.319044] sja1110 spi5.0: Upload successfully verified!
Set the console keyboard layout.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module efi_pstore.
[ OK ] Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Modules.
When I only add gptp_config in Middleware and don't make any modifications, compile and load, there will be an error. That is to say, adding gptp_config will cause an error when loading.
破坏者
Starting Load K[ 7.073122] SPI driver sja1110 has no spi_device_id for nxp,sja1110-switch
e[ 7.073128] SPI driver sja1110 has no spi_device_id for nxp,sja1110-uc
r[ 7.073214] sja1110 spi5.0: probing uc
n[ 7.073340] sja1110 spi5.1: probing switch
e[ 7.073596] sja1110 spi5.1: Could not get GPIO from device tree
l[ 7.073611] sja1110 spi5.1: [sja1110_post_probe_upload_worker] Trying to initialize switch
[ 7.074373] sja1110 spi5.1: Direct firmware load for sja1110_switch.bin failed with error -2
M[ 7.074383] sja1110 spi5.1: request_firmware failed with -2
od[ 7.074390] sja1110 spi5.0: [sja1110_post_probe_upload_worker] Trying to initialize uC
u[ 7.077579] sja1110 spi5.0: [sja1110_init_hw] loaded fw 'sja1110_uc.bin'
les[ 7.077593] sja1110 spi5.0: [sja1110_pre_uc_upload] Found firmware of size 131104
[[ 7.077698] sja1110 spi5.0: [sja1110_pre_uc_upload] µC not ready for download (Status=0x31)
0[ 7.077815] sja1110 spi5.0: Uploading firmware...
m...
Starti[ 7.186666] systemd[1]: Starting Generate network units from Kernel command line...
ng Generate network …ts from Kernel command line...
Starting [ 7.214398] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.239162] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: disabled.
[ 7.239520] systemd[1]: Starting Coldplug All udev Devices...
[ OK ] Started Jour[ 7.272430] systemd[1]: Started Journal Service.
nal Service.
[ OK ] Finished Set the console keyboard layout.
[ 7.459749] random: crng init done
[ 7.459769] random: 44 urandom warning(s) missed due to ratelimiting
[ 7.463272] sja1110 spi5.0: [sja1110_uc_parse_status_many] Upload error detected in status message 31600 (status=0x36,err=0x5b)
[ 7.463285] sja1110 spi5.0: Upload error detected!
[ 7.463290] sja1110 spi5.0: uploading firmware failed with 91
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
I think it's a problem with the spi rate, or there's something wrong with the uboot settings.
破坏者
=> printenv
baudrate=115200
board_rev=F
boot_fdt=try
boot_mtd=booti
bootargs=root=/dev/ram rw earlycon loglevel=7
bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; else run netboot;fi
bootdelay=2
bootscript=echo Running bootscript from mmc ...; source
console=ttyLF0
eth1addr=00:01:be:be:ef:11
ethact=eth_pfeng
fdt_addr=0x83000000
fdt_enable_hs400es=fdt addr ${fdt_addr}; fdt rm /soc/mmc no-1-8-v; fdt resize;
fdt_file=s32g399a-rdb3.dtb
fdt_high=0xffffffffffffffff
fdt_override=;
fdtcontroladdr=ffa97000
flashboot=echo Booting from flash...; run flashbootargs;mtd read Kernel ${loadaddr};mtd read DTB ${fdt_addr};mtd read Rootfs ${ramdisk_addr};${boot_mtd} ${loadaddr} ${ramdisk_addr} ${fdt_addr};
flashbootargs=setenv bootargs console=${console},${baudrate} root=/dev/ram rw earlycon nohz=off coherent_pool=64M;setenv flashsize 0x04000000;
hwconfig=serdes0:mode=pcie,clock=ext;pcie0:mode=rc;serdes1:mode=xpcs0&xpcs1,clock=ext,fmhz=125;xpcs1_0:speed=2G5;xpcs1_1:speed=2G5
image=Image
initrd_high=0xffffffffffffffff
ipaddr=10.0.0.100
jtagboot=echo Booting using jtag...; ${boot_mtd} ${loadaddr} ${ramdisk_addr} ${fdt_addr}
jtagsdboot=echo Booting loading Linux with ramdisk from SD...; run loadimage; run loadramdisk; run loadfdt;${boot_mtd} ${loadaddr} ${ramdisk_addr} ${fdt_addr}
loadaddr=0x80000000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}; run fdt_override;
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
loadtftpfdt=tftp ${fdt_addr} ${fdt_file};
loadtftpimage=tftp ${loadaddr} ${image};
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} earlycon nohz=off coherent_pool=64M
mmcboot=echo Booting from mmc ...; run mmcargs; if run loadfdt; then ${boot_mtd} ${loadaddr} - ${fdt_addr}; else echo WARN: Cannot load the DT; fi;
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp earlycon nohz=off coherent_pool=64M
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then ${boot_mtd} ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then ${boot_mtd}; else echo WARN: Cannot load the DT; fi; fi; else ${boot_mtd}; fi;
netmask=255.255.255.0
nfsboot=echo Booting from net using tftp and nfs...; run nfsbootargs;run loadtftpimage; run loadtftpfdt;${boot_mtd} ${loadaddr} - ${fdt_addr};
nfsbootargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs rw ip=${ipaddr}:${serverip}::${netmask}::eth0:off nfsroot=${serverip}:/tftpboot/rfs,nolock,v3,tcp earlycon nohz=off coherent_pool=64M
pfe1_phy_addr=8
pfe1addr=00:01:be:be:ef:22
pfe2addr=00:01:be:be:ef:33
pfeaddr=00:01:be:be:ef:11
pfeng_mode=enable,sgmii,sgmii,rgmii
pfengemac=0
ramdisk_addr=0x90000000
s32cc_gmac_mode=enable
script=boot.scr
serverip=10.0.0.1
stderr=serial@401c8000
stdin=serial@401c8000
stdout=serial@401c8000
update_sd_firmware=if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if mmc dev ${mmcdev}; then if ${get_cmd} ${update_sd_firmware_filename}; then setexpr fw_sz ${filesize} / 0x200; setexpr fw_sz ${fw_sz} - 7; setexpr loadaddr ${loadaddr} + 0x1000; mmc write ${loadaddr} 0x8 ${fw_sz}; fi; fi
update_sd_firmware_filename=fip.s32
Environment size: 3538/8188 bytes
3,165 次查看
alejandro_e
Hello @xiaoshumiao,
From the logs I can see that the download was actually completed, please see this part:
 if you check sja1110_init.h#L53, which is the module in charge of loading the firmware you can see the following:
The status is completed (0x36) and there is no error (0x5B=91). I am assuming you are using the Yocto build, in that setup, you can modify the patch in: .../sources/meta-alb/recipes-kernel/sja1110/sja1110/0001-s32g274a-rdb2-Add-support-for-S32G-VNP-RDB2.patch and add COMPLETED as a correct state, in here:
after that you can test if the functionalities related to the SJA1110 still work correctly.
Please let me know the result of the test.
3,135 次查看
xiaoshumiao
Hi @alejandro_e
3,111 次查看
alejandro_e
Hello @xiaoshumiao,
I'm glad you were able to solve the problem. Thanks for the reference for the solution.
If you encounter any other problem feel free to create a new post.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2083859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20sja1110%20gPTP%20%E6%97%B6%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%8A%E6%95%AC%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E5%90%84%E4%BD%8D%E5%90%8C%E4%BB%81%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8S32G-VNP-RDB3%E5%92%8CLinux%20BSP%2038.0%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E9%85%8D%E7%BD%AEpfe0%E9%80%9A%E8%BF%87sgmii%E4%B8%8Esja1110%E7%AB%AF%E5%8F%A34%E9%80%9A%E4%BF%A1%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5ping%E9%80%9A%E3%80%82%E6%88%91%E6%83%B3%E9%80%9A%E8%BF%87pfe0%E5%92%8Csja1110%E7%AB%AF%E5%8F%A34%E6%8E%A5%E5%8F%A3%E5%90%8C%E6%AD%A5s32g%E5%92%8Csja1110%E4%B9%8B%E9%97%B4%E7%9A%84%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E2%80%9Cgptp_sja1110x%E2%80%9D%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%88%91%E5%9C%A8%E2%80%9Cswitch_config_s32g_vnp_rdb%E2%80%9D%E4%B8%8A%E6%B7%BB%E5%8A%A0%E4%BA%86gPTP%20statck%EF%BC%8C%E5%B9%B6%E9%85%8D%E7%BD%AE%E4%BA%86gptp%E3%80%82%E6%9C%80%E5%90%8E%E6%88%91%E7%BC%96%E8%AF%91%E7%94%9F%E6%88%90%E4%BA%86flash_image.bin%EF%BC%8C%E5%B0%86%E5%85%B6%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BAsja1110_uc.bin%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E5%A4%8D%E5%88%B6%E5%88%B0%2Flib%2Ffirmware%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%87%BA%E7%8E%B0%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiaoshumiao_0-1745235794086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiaoshumiao_0-1745235794086.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334071iCD543D091095AB46%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiaoshumiao_0-1745235794086.png%22%20alt%3D%22xiaoshumiao_0-1745235794086.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8C%9C%E6%B5%8B%E9%94%99%E8%AF%AF%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiaoshumiao_1-1745235852368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiaoshumiao_1-1745235852368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334072iF7BEDFBBB687EBCD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiaoshumiao_1-1745235852368.png%22%20alt%3D%22xiaoshumiao_1-1745235852368.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiaoshumiao_2-1745235892615.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiaoshumiao_2-1745235892615.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334073i416E99EABD63D0CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiaoshumiao_2-1745235892615.png%22%20alt%3D%22xiaoshumiao_2-1745235892615.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AF%A6%E7%BB%86%E6%97%A5%E5%BF%97%E8%AF%B7%E5%8F%82%E8%80%83%E9%99%84%E4%BB%B6%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2085609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20sja1110%20gPTP%20%E6%97%B6%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231689%22%20target%3D%22_blank%22%3E%40xiaoshumiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E4%BD%A0%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E7%9A%84%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%88%9B%E5%BB%BA%E6%96%B0%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2085345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20sja1110%20gPTP%20%E6%97%B6%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%AD%A4%E6%96%B9%E6%B3%95%E4%BB%8D%E7%84%B6%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E8%BF%98%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%85%B6%E4%BB%96%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%82%E8%80%83%E8%BF%99%E4%B8%AA%E6%9D%A5%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2Fs32g-vnp-rdb2-Errror-when-uploading-sja1110-uc-and-using-gPTP%2Fm-p%2F1610265%2Fthread-id%2F2396%2Fhighlight%2Ftrue%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2Fs32g-vnp-rdb2-Error-when-uploading-sja1110-uc-and-using-gPTP%2Fmp%2F1610265%2Fthread-id%2F2396%2Fhighlight%2Ftrue%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20sja1110%20gPTP%20%E6%97%B6%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231689%22%20target%3D%22_blank%22%3E%40xiaoshumiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E4%BB%8E%E6%97%A5%E5%BF%97%E4%B8%AD%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E4%B8%8B%E8%BD%BD%E7%A1%AE%E5%AE%9E%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E6%AD%A4%E9%83%A8%E5%88%86%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%207.463272%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_uc_parse_status_many%5D%20Upload%20error%20detected%20in%20status%20message%2031600%20(status%3D0x36%2Cerr%3D0x5b)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%A3%80%E6%9F%A5%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-archive%2Fautoivnsw_sja1110_linux%2Fblob%2Fac06f130d512e75edcf98d1a8304edd90055e525%2Fsja1110_init.h%23L53%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esja1110_init.h%23L53%3C%2FA%3E%20%EF%BC%88%E8%B4%9F%E8%B4%A3%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%89%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1745361788142.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1745361788142.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334365i4AE087010282A1E9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1745361788142.png%22%20alt%3D%22alejandro_e_0-1745361788142.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%8A%B6%E6%80%81%E4%B8%BA%E5%AE%8C%E6%88%90%EF%BC%880x36%EF%BC%89%E4%B8%94%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%880x5B%3D91%EF%BC%89%E3%80%82%E6%88%91%E5%81%87%E8%AE%BE%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Yocto%20%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%9C%A8%E8%AF%A5%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E7%9A%84%E8%A1%A5%E4%B8%81%EF%BC%9A%20%3CSTRONG%3E...%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fsja1110%2Fsja1110%2F0001-s32g274a-rdb2-Add-support-for-S32G-VNP-RDB2.patch%3C%2FSTRONG%3E%E5%B9%B6%E6%B7%BB%E5%8A%A0%3CSTRONG%3ECOMPLETED%3C%2FSTRONG%3E%E4%BD%9C%E4%B8%BA%E6%AD%A3%E7%A1%AE%E7%8A%B6%E6%80%81%EF%BC%8C%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_1-1745362130548.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_1-1745362130548.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334366iBAF2C2DFB8EF6BCE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_1-1745362130548.png%22%20alt%3D%22alejandro_e_1-1745362130548.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%B5%8B%E8%AF%95%E4%B8%8E%20SJA1110%20%E7%9B%B8%E5%85%B3%E7%9A%84%E5%8A%9F%E8%83%BD%E6%98%AF%E5%90%A6%E4%BB%8D%E7%84%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20sja1110%20gPTP%20%E6%97%B6%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F238460%22%20target%3D%22_blank%22%3E%40alejandro_e%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%A1%AE%E8%AE%A4J189%E7%9A%84%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%E3%80%82rdb3%E4%BB%8Esd%E5%8D%A1%E5%90%AF%E5%8A%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B9%9F%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%88%E6%B5%8B%E8%AF%95%E4%BA%86%E4%B8%80%E4%B8%8B%E3%80%82%E5%BD%93%E6%88%91%E7%9B%B4%E6%8E%A5%E7%BC%96%E8%AF%91%E2%80%9Cswitch_config_s32g_vnp_rdb%E2%80%9D%E8%80%8C%E4%B8%8D%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E4%BF%AE%E6%94%B9%E5%B9%B6%E5%8A%A0%E8%BD%BD%E5%AE%83%E6%97%B6%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E2%80%9C%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%5B%206.995965%5D%20systemd%5B1%5D%3A%20%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%E5%AF%BC%E8%87%B4%E8%B7%B3%E8%BF%87%20OpenVSwitch%20%E6%B8%85%E7%90%86%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%5B%206.996275%5D%20systemd%5B1%5D%3A%20%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%E5%AF%BC%E8%87%B4%E8%B7%B3%E8%BF%87%E6%A0%B9%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%A3%80%E6%9F%A5%E3%80%82%3CBR%20%2F%3E%5B%207.001365%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%A7%8B%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97...%3CBR%20%2F%3E%20%5B7.017206%5Dsja1110%3A%E5%8A%A0%E8%BD%BD%E6%A0%91%E5%A4%96%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%B1%A1%E6%9F%93%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%5B7.023197%5DSPI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fsja1110%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8Enxp%E3%80%81sja1110%20switch%E7%9A%84spi_device_id%3CBR%20%2F%3E%20%5B7.023203%5DSPI%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fsja1110%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8Enxp%E3%80%81sja1110-uc%E7%9A%84spi_device_id%3CBR%20%2F%3E%20%5B7.023294%5DSJA1110%20SPI5.0%EF%BC%9A%E6%8E%A2%E6%B5%8BUC%3CBR%20%2F%3E%20%5B7.023415%5DSJA1110%20SPI5.1%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%BC%80%E5%85%B3%3CBR%20%2F%3E%5B7.023668%5DSJA1110%20SPI5.1%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BB%8E%E8%AE%BE%E5%A4%87%E6%A0%91%E8%8E%B7%E5%8F%96%20GPIO%3CBR%20%2F%3E%20%5B7.023690%5DSJA1110%20SPI5.1%EF%BC%9A%5Bsja1110_post_probe_upload_worker%5D%20%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%A4%E6%8D%A2%E6%9C%BA%3CBR%20%2F%3E%5B7.024403%5DSJA1110%20SPI5.1%EF%BC%9Asja1110_switch.bin%20%E7%9A%84%E7%9B%B4%E6%8E%A5%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-2%3CBR%20%2F%3E%20%5B7.024413%5DSJA1110%20SPI5.1%EF%BC%9Arequest_firmware%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%BF%94%E5%9B%9E%20-2%3CBR%20%2F%3E%20%5B7.024419%5DSJA1110%20SPI5.0%EF%BC%9A%5Bsja1110_post_probe_upload_worker%5D%20%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%20uC%3CBR%20%2F%3E%20S%5B%207.026935%5D%20sja1110%20spi5.0%3A%5Bsja1110_init_hw%5D%20%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E2%80%98sja1110_uc.bin%E2%80%99%3CBR%20%2F%3Et%5B7.026946%5Dsja1110%20spi5.0%3A%5Bsja1110_pre_uc_upload%5D%20%E6%89%BE%E5%88%B0%E5%A4%A7%E5%B0%8F%E4%B8%BA%20126400%20%E7%9A%84%E5%9B%BA%E4%BB%B6%3CBR%20%2F%3E%E4%B8%80%E4%B8%AA%5B7.027015%5D%20sja1110%20spi5.0%3A%5Bsja1110_pre_uc_upload%5D%E5%9B%BA%E4%BB%B6%E4%BC%BC%E4%B9%8E%E6%9C%89%E6%95%88%3CBR%20%2F%3Er%5B7.027050%5Dsja1110%20spi5.0%3A%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20%E5%B0%9A%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%E4%B8%8B%E8%BD%BD%EF%BC%88%E7%8A%B6%E6%80%81%3D0x31%EF%BC%89%3CBR%20%2F%3E%20t%5B%207.027138%5D%20sja1110%20spi5.0%3A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%E5%9B%BA%E4%BB%B6...%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97...%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%5B7.138512%5D%20systemd%5B1%5D%3A%20%E5%BC%80%E5%A7%8B%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83...%3CBR%20%2F%3E%20g%20%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C...ts...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20%5B%207.166366%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20%5B7.184599%5DEXT4-fs%EF%BC%88mmcblk0p2%EF%BC%89%EF%BC%9A%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E3%80%82%E9%80%89%E9%A1%B9%EF%BC%9A%EF%BC%88%E7%A9%BA%EF%BC%89%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3EStar%5B7.210767%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20Coldplug%20%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%5B7.236049%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%A4%A7%E9%A1%B5%E9%9D%A2%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%20POSIX%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%5B7.319044%5D%20sja1110%20spi5.0%3A%E4%B8%8A%E4%BC%A0%E5%B7%B2%E6%88%90%E5%8A%9F%E9%AA%8C%E8%AF%81%EF%BC%81%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E9%94%AE%E7%9B%98%E5%B8%83%E5%B1%80%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E4%BF%9D%E9%99%A9%E4%B8%9D%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B%206.995965%5D%20systemd%5B1%5D%3A%20%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%E5%AF%BC%E8%87%B4%E8%B7%B3%E8%BF%87%20OpenVSwitch%20%E6%B8%85%E7%90%86%E9%85%8D%E7%BD%AE%E3%80%82%5B6.996275%5D%20systemd%5B1%5D%3A%20%E6%9D%A1%E4%BB%B6%E6%A3%80%E6%9F%A5%E5%AF%BC%E8%87%B4%E8%B7%B3%E8%BF%87%E6%A0%B9%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E6%A3%80%E6%9F%A5%E3%80%82%5B7.001365%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%A7%8B%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97...%5B%207.017206%5D%20sja1110%3A%20%E5%8A%A0%E8%BD%BD%E6%A0%91%E5%A4%96%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%B1%A1%E6%9F%93%E5%86%85%E6%A0%B8%E3%80%82%5B7.023197%5D%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20sja1110%20%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8E%20nxp%E3%80%81sja1110-switch%20%E7%9A%84%20spi_device_id%5B%207.023203%5D%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20sja1110%20%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8E%20nxp%E3%80%81sja1110-uc%20%E7%9A%84%20spi_device_id%5B%207.023294%5D%20sja1110%20spi5.0%EF%BC%9A%E6%8E%A2%E6%B5%8Buc%5B7.023415%5Dsja1110%20spi5.1%3A%E6%8E%A2%E6%B5%8B%E5%BC%80%E5%85%B3%5B7.023668%5D%20sja1110%20spi5.1%3A%E6%97%A0%E6%B3%95%E4%BB%8E%E8%AE%BE%E5%A4%87%E6%A0%91%E8%8E%B7%E5%8F%96%20GPIO%5B7.023690%5D%20sja1110%20spi5.1%3A%5Bsja1110_post_probe_upload_worker%5D%20%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%A4%E6%8D%A2%E6%9C%BA%5B7.024403%5D%20sja1110%20spi5.1%3Asja1110_switch.bin%20%E7%9A%84%E7%9B%B4%E6%8E%A5%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-2%5B%207.024413%5D%20sja1110%20spi5.1%3Arequest_firmware%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-2%5B%207.024419%5D%20sja1110%20spi5.0%3A%5Bsja1110_post_probe_upload_worker%5D%20%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%20uCS%5B%207.026935%5D%20sja1110%20spi5.0%3A%5Bsja1110_init_hw%5D%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%20fw'sja1110_uc.bin't%5B7.026946%5D%20sja1110%20spi5.0%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%20%E6%89%BE%E5%88%B0%E5%A4%A7%E5%B0%8F%E4%B8%BA%20126400a%5B%207.027015%5D%20sja1110%20spi5.0%20%E7%9A%84%E5%9B%BA%E4%BB%B6%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%20%E5%9B%BA%E4%BB%B6%E4%BC%BC%E4%B9%8E%E6%9C%89%E6%95%88%5B%207.027050%5D%20sja1110%20spi5.0%3A%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20%E5%B0%9A%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%E4%B8%8B%E8%BD%BD%20(%E7%8A%B6%E6%80%81%3D0x31)t%5B%207.027138%5D%20sja1110%20spi5.0%3A%E4%B8%8A%E4%BC%A0%E5%9B%BA%E4%BB%B6...%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97...%E5%BC%80%E5%A7%8B%5B7.138512%5D%20systemd%5B1%5D%3A%20%E5%BC%80%E5%A7%8B%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83...%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C...ts...%E5%BC%80%E5%A7%8B%20%5B7.166366%5D%20systemd%5B1%5D%3A%20%E5%BC%80%E5%A7%8B%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%5B7.184599%5D%20EXT4-fs%20(mmcblk0p2)%3A%20%E5%B7%B2%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E3%80%82%E9%80%89%E9%A1%B9%EF%BC%9A%EF%BC%88%E7%A9%BA%EF%BC%89%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E5%90%AF%E5%8A%A8%20%5B%207.210767%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%5B%20OK%20%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%20%5B%207.236049%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1%E3%80%82%E6%9C%8D%E5%8A%A1%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%A4%A7%E9%A1%B5%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%20POSIX%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%5B%E5%A5%BD%E7%9A%84%5D%20%E5%AE%8C%E6%88%90%5B7.319044%5D%20sja1110%20spi5.0%3A%E4%B8%8A%E4%BC%A0%E5%B7%B2%E6%88%90%E5%8A%9F%E9%AA%8C%E8%AF%81%EF%BC%81%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E9%94%AE%E7%9B%98%E5%B8%83%E5%B1%80%E3%80%82%5BOK%20%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs%E3%80%82%5BOK%20%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm%E3%80%82%5BOK%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore%E3%80%82%5BOK%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97fuse%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%BD%93%E6%88%91%E5%9C%A8Middleware%E4%B8%AD%E5%8F%AA%E6%B7%BB%E5%8A%A0gptp_config%E8%80%8C%E4%B8%8D%E5%81%9A%E4%BB%BB%E4%BD%95%E4%BF%AE%E6%94%B9%EF%BC%8C%E7%BC%96%E8%AF%91%E5%8A%A0%E8%BD%BD%E6%97%B6%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%E6%B7%BB%E5%8A%A0gptp_config%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%8A%A0%E8%BD%BD%E6%97%B6%E5%87%BA%E9%94%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%E5%BC%80%E5%A7%8B%E5%8A%A0%E8%BD%BD%20K%5B%207.073122%5D%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20sja1110%20%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8E%20nxp%E3%80%81sja1110-switch%20%E7%9A%84%20spi_device_id%3CBR%20%2F%3E%20e%5B%207.073128%5D%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20sja1110%20%E6%B2%A1%E6%9C%89%E9%80%82%E7%94%A8%E4%BA%8E%20nxp%E3%80%81sja1110-uc%20%E7%9A%84%20spi_device_id%3CBR%20%2F%3E%20r%5B7.073214%5Dsja1110%20spi5.0%EF%BC%9A%E6%8E%A2%E6%B5%8BUC%3CBR%20%2F%3E%20n%5B%207.073340%5D%20sja1110%20spi5.1%3A%E6%8E%A2%E6%B5%8B%E5%BC%80%E5%85%B3%3CBR%20%2F%3Ee%5B%207.073596%5D%20sja1110%20spi5.1%3A%E6%97%A0%E6%B3%95%E4%BB%8E%E8%AE%BE%E5%A4%87%E6%A0%91%E8%8E%B7%E5%8F%96%20GPIO%3CBR%20%2F%3E%20l%5B%207.073611%5D%20sja1110%20spi5.1%3A%5Bsja1110_post_probe_upload_worker%5D%20%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%A4%E6%8D%A2%E6%9C%BA%3CBR%20%2F%3E%5B7.074373%5DSJA1110%20SPI5.1%EF%BC%9Asja1110_switch.bin%20%E7%9A%84%E7%9B%B4%E6%8E%A5%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-2%3CBR%20%2F%3E%20M%5B%207.074383%5D%20sja1110%20spi5.1%3Arequest_firmware%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%BF%94%E5%9B%9E%20-2%3CBR%20%2F%3E%20od%5B7.074390%5D%20sja1110%20spi5.0%3A%5Bsja1110_post_probe_upload_worker%5D%20%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%20uC%3CBR%20%2F%3E%20u%5B7.077579%5D%20sja1110%20spi5.0%3A%5Bsja1110_init_hw%5D%20%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E2%80%98sja1110_uc.bin%E2%80%99%3CBR%20%2F%3E%E8%8E%B1%E6%96%AF%5B7.077593%5D%20sja1110%20spi5.0%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%20%E6%89%BE%E5%88%B0%E5%A4%A7%E5%B0%8F%E4%B8%BA%20131104%20%E7%9A%84%E5%9B%BA%E4%BB%B6%3CBR%20%2F%3Esja1110%20spi5.0%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%E5%9B%BA%E4%BB%B6%E4%BC%BC%E4%B9%8E%E6%9C%89%E6%95%88%3CBR%20%2F%3E%5B%5B7.077698%5Dsja1110%20spi5.0%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20%E5%B0%9A%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%E4%B8%8B%E8%BD%BD%EF%BC%88%E7%8A%B6%E6%80%81%3D0x31%EF%BC%89%3CBR%20%2F%3E%200%5B7.077815%5Dsja1110%20spi5.0%3A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%E5%9B%BA%E4%BB%B6...%3CBR%20%2F%3E%E6%88%91...%3CBR%20%2F%3E%20Starti%5B%207.186666%5D%20systemd%5B1%5D%3A%20%E5%BC%80%E5%A7%8B%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83...%3CBR%20%2F%3E%20ng%20%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C...ts...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20%5B%207.214398%5D%20systemd%5B1%5D%3A%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%20%5B7.239162%5DEXT4-fs%EF%BC%88mmcblk0p2%EF%BC%89%EF%BC%9A%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E3%80%82%E9%80%89%E9%A1%B9%EF%BC%9A%EF%BC%88%E7%A9%BA%EF%BC%89%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3E%5B%207.239520%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%20Coldplug%20%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%E5%BC%80%E5%A7%8B%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%5B7.272430%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E7%BB%88%E6%9C%8D%E5%8A%A1%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%A4%A7%E9%A1%B5%E9%9D%A2%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%20POSIX%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E9%94%AE%E7%9B%98%E5%B8%83%E5%B1%80%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm%E3%80%82%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E4%BF%9D%E9%99%A9%E4%B8%9D%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E3%80%82%3CBR%20%2F%3E%5B7.459749%5D%E9%9A%8F%E6%9C%BA%EF%BC%9Acrng%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%5B7.459769%5D%E9%9A%8F%E6%9C%BA%EF%BC%9A%E7%94%B1%E4%BA%8E%E9%80%9F%E7%8E%87%E9%99%90%E5%88%B6%EF%BC%8C%E9%94%99%E8%BF%87%E4%BA%8644%E4%B8%AAurandom%E8%AD%A6%E5%91%8A%3CBR%20%2F%3E%5B7.463272%5DSJA1110%20SPI5.0%EF%BC%9A%5Bsja1110_uc_parse_status_many%5D%20%E5%9C%A8%E7%8A%B6%E6%80%81%E6%B6%88%E6%81%AF%2031600%20%E4%B8%AD%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%8A%E4%BC%A0%E9%94%99%E8%AF%AF%20(status%3D0x36%2Cerr%3D0x5b)%3CBR%20%2F%3E%20%5B7.463285%5DSJA1110%20SPI5.0%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%8A%E4%BC%A0%E9%94%99%E8%AF%AF%EF%BC%81%3CBR%20%2F%3E%5B7.463290%5DSJA1110%20SPI5.0%EF%BC%9A%E4%B8%8A%E4%BC%A0%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%2091%3CBR%20%2F%3E%20%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%8C%E6%88%90%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83%E3%80%82%3CBR%20%2F%3E%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%AE%8C%E6%88%90%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%AE%89%E8%A3%85%20FUSE%20%E6%8E%A7%E5%88%B6%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E5%AE%89%E8%A3%85%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%E5%BC%80%E5%A7%8B%E5%8A%A0%E8%BD%BD%20K%5B%207.073122%5D%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20sja1110%20%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8E%20nxp%E3%80%81sja1110-switche%20%E7%9A%84%20spi_device_id%5B%207.073128%5D%20SPI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20sja1110%20%E6%B2%A1%E6%9C%89%E7%94%A8%E4%BA%8E%20nxp%E3%80%81sja1110-ucr%20%E7%9A%84%20spi_device_id%5B%207.073214%5D%20sja1110%20spi5.0%3A%E6%8E%A2%E6%B5%8Bucn%5B7.073340%5D%20sja1110%20spi5.1%EF%BC%9A%E6%8E%A2%E6%B5%8B%E5%BC%80%E5%85%B3%5B7.073596%5D%20sja1110%20spi5.1%3A%E6%97%A0%E6%B3%95%E4%BB%8E%E8%AE%BE%E5%A4%87%E6%A0%91%5B7.073611%5D%20sja1110%20spi5.1%E8%8E%B7%E5%8F%96GPIO%EF%BC%9A%5Bsja1110_post_probe_upload_worker%5D%20%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%A4%E6%8D%A2%E6%9C%BA%5B7.074373%5D%20sja1110%20spi5.1%3Asja1110_switch.bin%20%E7%9A%84%E7%9B%B4%E6%8E%A5%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%B8%BA%20-2M%5B%207.074383%5D%20sja1110%20spi5.1%3Arequest_firmware%20%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%E4%B8%BA%20-2od%5B%207.074390%5D%20sja1110%20spi5.0%3A%5Bsja1110_post_probe_upload_worker%5D%20%E5%B0%9D%E8%AF%95%E5%88%9D%E5%A7%8B%E5%8C%96%20uCu%5B%207.077579%5D%20sja1110%20spi5.0%3A%5Bsja1110_init_hw%5D%20%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E2%80%9Csja1110_uc.bin%E2%80%9D%E6%96%87%E4%BB%B6%5B7.077593%5D%20sja1110%20spi5.0%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%20%E6%89%BE%E5%88%B0%E5%A4%A7%E5%B0%8F%E4%B8%BA%20131104sja1110%20spi5.0%20%E7%9A%84%E5%9B%BA%E4%BB%B6%EF%BC%9A%5Bsja1110_pre_uc_upload%5D%20%E5%9B%BA%E4%BB%B6%E4%BC%BC%E4%B9%8E%E6%9C%89%E6%95%88%5B%5B%207.077698%5D%20sja1110%20spi5.0%3A%5Bsja1110_pre_uc_upload%5D%20%C2%B5C%20%E5%B0%9A%E6%9C%AA%E5%87%86%E5%A4%87%E5%A5%BD%E4%B8%8B%E8%BD%BD%20(%E7%8A%B6%E6%80%81%3D0x31)0%5B%207.077815%5D%20sja1110%20spi5.0%3A%E6%AD%A3%E5%9C%A8%E4%B8%8A%E4%BC%A0%E5%9B%BA%E4%BB%B6...m...%E5%BC%80%E5%A7%8B%5B%207.186666%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83...ng%20%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C...ts...%E5%BC%80%E5%A7%8B%20%5B%207.214398%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%A7%8B%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%5B%207.239162%5D%20EXT4-fs%20(mmcblk0p2)%3A%20%E5%B7%B2%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E3%80%82%E9%80%89%E9%A1%B9%EF%BC%9A%EF%BC%88%E7%A9%BA%EF%BC%89%E3%80%82%E9%85%8D%E9%A2%9D%E6%A8%A1%E5%BC%8F%EF%BC%9A%E7%A6%81%E7%94%A8%E3%80%82%5B7.239520%5D%20systemd%5B1%5D%3A%20%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%B7%E6%8F%92%E6%8B%94%E6%89%80%E6%9C%89%20udev%20%E8%AE%BE%E5%A4%87...%5B%20%E7%A1%AE%E5%AE%9A%20%5D%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%5B%207.272430%5D%20systemd%5B1%5D%3A%20%E5%B7%B2%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E6%9C%8D%E5%8A%A1.nal%20%E6%9C%8D%E5%8A%A1%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%A4%A7%E9%A1%B5%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%20POSIX%20%E6%B6%88%E6%81%AF%E9%98%9F%E5%88%97%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%86%85%E6%A0%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%5BOK%20%5D%20%E5%AE%8C%E6%88%90%E8%AE%BE%E7%BD%AE%E6%8E%A7%E5%88%B6%E5%8F%B0%E9%94%AE%E7%9B%98%E5%B8%83%E5%B1%80%E3%80%82%5BOK%20%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20configfs%E3%80%82%5BOK%20%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20drm%E3%80%82%5BOK%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%20efi_pstore%E3%80%82%5BOK%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97fuse%E3%80%82%5BOK%5D%20%E5%AE%8C%E6%88%90%E5%8A%A0%E8%BD%BD%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%E3%80%82%5B7.459749%5D%20%E9%9A%8F%E6%9C%BA%EF%BC%9Acrng%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AE%8C%E6%88%90%5B7.459769%5D%20%E9%9A%8F%E6%9C%BA%EF%BC%9A%E7%94%B1%E4%BA%8E%E9%80%9F%E7%8E%87%E9%99%90%E5%88%B6%E8%80%8C%E9%94%99%E8%BF%87%2044%20%E4%B8%AA%20urandom%20%E8%AD%A6%E5%91%8A%5B7.463272%5D%20sja1110%20spi5.0%EF%BC%9A%5Bsja1110_uc_parse_status_many%5D%20%E5%9C%A8%E7%8A%B6%E6%80%81%E6%B6%88%E6%81%AF%2031600%20%E4%B8%AD%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%8A%E4%BC%A0%E9%94%99%E8%AF%AF%20(status%3D0x36%2Cerr%3D0x5b)%5B%207.463285%5D%20sja1110%20spi5.0%3A%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%8A%E4%BC%A0%E9%94%99%E8%AF%AF%EF%BC%81%5B7.463290%5D%20sja1110%20spi5.0%EF%BC%9A%E4%B8%8A%E4%BC%A0%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%2091%5B%20OK%20%5D%20%E5%B7%B2%E5%AE%8C%E6%88%90%E4%BB%8E%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%94%9F%E6%88%90%E7%BD%91%E7%BB%9C%E5%8D%95%E5%85%83%E3%80%82%5B%E7%A1%AE%E5%AE%9A%5D%20%E5%B7%B2%E5%AE%8C%E6%88%90%E9%87%8D%E6%96%B0%E6%8C%82%E8%BD%BD%E6%A0%B9%E5%92%8C%E5%86%85%E6%A0%B8%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%20FUSE%20%E6%8E%A7%E5%88%B6%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%E6%AD%A3%E5%9C%A8%E6%8C%82%E8%BD%BD%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F...%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%98%AFspi%E9%80%9F%E7%8E%87%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%96%E8%80%85%E6%98%AFuboot%E8%AE%BE%E7%BD%AE%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E7%8E%AF%E5%A2%83%3CBR%20%2F%3E%E6%B3%A2%E7%89%B9%E7%8E%87%3D115200%3CBR%20%2F%3E%20board_rev%3DF%3CBR%20%2F%3E%20boot_fdt%3D%E5%B0%9D%E8%AF%95%3CBR%20%2F%3Eboot_mtd%3D%E5%90%AF%E5%8A%A8%3CBR%20%2F%3Ebootargs%3Droot%3D%2Fdev%2Fram%20rw%20earlycon%20loglevel%3D7%3CBR%20%2F%3E%20bootcmd%3Dmmc%20dev%20%24%7Bmmcdev%7D%20%3B%20%E5%A6%82%E6%9E%9C%20mmc%20%E9%87%8D%E6%96%B0%E6%89%AB%E6%8F%8F%EF%BC%9B%E5%88%99%E5%A6%82%E6%9E%9C%E8%BF%90%E8%A1%8C%20loadimage%EF%BC%9B%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20mmcboot%EF%BC%9B%E5%90%A6%E5%88%99%E8%BF%90%E8%A1%8C%20netboot%EF%BC%9Bfi%EF%BC%9B%E5%90%A6%E5%88%99%E8%BF%90%E8%A1%8C%20netboot%EF%BC%9Bfi%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E5%BB%B6%E8%BF%9F%3D2%3CBR%20%2F%3E%20bootscript%3Decho%20%E4%BB%8E%20mmc%20%E8%BF%90%E8%A1%8C%20bootscript%20...%3B%E6%9D%A5%E6%BA%90%3CBR%20%2F%3E%E6%8E%A7%E5%88%B6%E5%8F%B0%3DttyLF0%3CBR%20%2F%3E%20eth1addr%3D00%3A01%3Abe%3Abe%3Aef%3A11%3CBR%20%2F%3E%20ethact%3Deth_pfeng%3CBR%20%2F%3E%20fdt_addr%3D0x83000000%3CBR%20%2F%3E%20fdt_enable_hs400es%3Dfdt%20%E5%9C%B0%E5%9D%80%24%7Bfdt_addr%7D%20%EF%BC%9Bfdt%20rm%20%2Fsoc%2Fmmc%20no-1-8-v%EF%BC%9Bfdt%20%E8%B0%83%E6%95%B4%E5%A4%A7%E5%B0%8F%EF%BC%9B%3CBR%20%2F%3E%20fdt_%E6%96%87%E4%BB%B6%3Ds32g399a-rdb3.dtb%3CBR%20%2F%3E%20fdt_high%3D0xffffffffffffffff%3CBR%20%2F%3E%20fdt_%E8%A6%86%E7%9B%96%3D%EF%BC%9B%3CBR%20%2F%3E%20fdtcontroladdr%3Dffa97000%3CBR%20%2F%3E%20flashboot%3Decho%20%E4%BB%8E%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8...%3B%20%E8%BF%90%E8%A1%8C%20flashbootargs%3Bmtd%20%E8%AF%BB%E5%8F%96%E5%86%85%E6%A0%B8%24%7Bloadaddr%7D%20%3Bmtd%20%E8%AF%BB%E5%8F%96%20DTB%20%24%7Bfdt_addr%7D%20%3Bmtd%20%E8%AF%BB%E5%8F%96%20Rootfs%20%24%7Bramdisk_addr%7D%20%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%20%3B%3CBR%20%2F%3E%20flashbootargs%20%3D%20setenv%20bootargs%20console%20%3D%20%24%7Bconsole%7D%20%EF%BC%8C%20%24%7Bbaudrate%7D%20root%20%3D%20%2F%20dev%20%2F%20ram%20rw%20earlycon%20nohz%20%3D%20off%20coherent_pool%20%3D%2064M%3B%20setenv%20flashsize%200x04000000%3B%3CBR%20%2F%3E%20hwconfig%3Dserdes0%3A%E6%A8%A1%E5%BC%8F%3Dpcie%EF%BC%8C%E6%97%B6%E9%92%9F%3Dext%EF%BC%9Bpcie0%EF%BC%9A%E6%A8%A1%E5%BC%8F%3Drc%EF%BC%9Bserdes1%EF%BC%9A%E6%A8%A1%E5%BC%8F%3Dxpcs0%26amp%3Bxpcs1%EF%BC%8C%E6%97%B6%E9%92%9F%3Dext%EF%BC%8Cfmhz%3D125%EF%BC%9Bxpcs1_0%EF%BC%9A%E9%80%9F%E5%BA%A6%3D2G5%EF%BC%9Bxpcs1_1%EF%BC%9A%E9%80%9F%E5%BA%A6%3D2G5%3CBR%20%2F%3E%E5%9B%BE%E5%83%8F%3D%E5%9B%BE%E5%83%8F%3CBR%20%2F%3Einitrd_high%20%3D%200xffffffffffffffff%3CBR%20%2F%3E%20IP%E5%9C%B0%E5%9D%80%3D10.0.0.100%3CBR%20%2F%3E%20jtagboot%3Decho%20%E4%BD%BF%E7%94%A8%20jtag%20%E5%90%AF%E5%8A%A8...%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3CBR%20%2F%3E%20jtagsdboot%3Decho%20%E4%BB%8E%20SD%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E5%B8%A6%E6%9C%89%20ramdisk%20%E7%9A%84%20Linux...%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadimage%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadramdisk%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadfdt%EF%BC%9B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E5%9C%B0%E5%9D%80%3D0x80000000%3CBR%20%2F%3E%20loadbootscript%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bscript%7D%20%3B%3CBR%20%2F%3E%20loadfdt%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%20%E8%BF%90%E8%A1%8C%20fdt_override%3B%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BD%E5%9B%BE%E5%83%8F%3D%E5%8A%A0%E8%BD%BD%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3CBR%20%2F%3E%20loadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%EF%BC%9B%3CBR%20%2F%3E%E5%8A%A0%E8%BD%BDtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%20%EF%BC%9B%3CBR%20%2F%3E%20mmcargs%20%3D%20setenv%20bootargs%20%E6%8E%A7%E5%88%B6%E5%8F%B0%3D%20%24%7Bconsole%7D%20%EF%BC%8C%20%24%7Bbaudrate%7D%E6%A0%B9%3D%20%24%7Bmmcroot%7D%20earlycon%20nohz%20%3D%20off%20coherent_pool%20%3D%2064M%3CBR%20%2F%3E%20mmcboot%20%3D%20echo%20%E4%BB%8E%20mmc%20%E5%90%AF%E5%8A%A8...%EF%BC%9B%E8%BF%90%E8%A1%8C%20mmcargs%EF%BC%9B%E5%A6%82%E6%9E%9C%E8%BF%90%E8%A1%8C%20loadfdt%EF%BC%9B%E5%88%99%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%EF%BC%9B%E5%90%A6%E5%88%99%20echo%20WARN%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%20DT%EF%BC%9Bfi%EF%BC%9B%3CBR%20%2F%3E%20mmcdev%3D0%3CBR%20%2F%3E%20mmcpart%3D1%3CBR%20%2F%3E%20mmcroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rw%3CBR%20%2F%3E%20netargs%20%3D%20setenv%20bootargs%20console%20%3D%20%24%7Bconsole%7D%20%EF%BC%8C%20%24%7Bbaudrate%7D%20root%20%3D%20%2F%20dev%20%2F%20nfs%20ip%20%3D%20dhcp%20nfsroot%20%3D%20%24%7Bserverip%7D%20%EF%BC%9A%20%24%7Bnfsroot%7D%20%EF%BC%8Cv3%EF%BC%8Ctcp%20earlycon%20nohz%20%3D%20off%20coherent_pool%20%3D%2064M%3CBR%20%2F%3E%20netboot%3Decho%20%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8%20...%3B%20%E8%BF%90%E8%A1%8C%20netargs%3B%20%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bip_dyn%7D%20%3D%20%E6%98%AF%3B%20%E5%88%99%20setenv%20get_cmd%20dhcp%3B%20%E5%90%A6%E5%88%99%20setenv%20get_cmd%20tftp%3B%20fi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%20%3B%20%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bboot_fdt%7D%20%3D%20%E6%98%AF%20%7C%7C%20%E6%B5%8B%E8%AF%95%24%7Bboot_fdt%7D%20%3D%20%E5%B0%9D%E8%AF%95%3B%20%E5%88%99%E5%A6%82%E6%9E%9C%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%20%E5%88%99%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%3B%20%E5%90%A6%E5%88%99%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bboot_fdt%7D%20%3D%20%E5%B0%9D%E8%AF%95%3B%20%E5%88%99%24%7Bboot_mtd%7D%20%3B%20%E5%90%A6%E5%88%99%20echo%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%20DT%3B%20fi%3B%20fi%3B%20%E5%90%A6%E5%88%99%24%7Bboot_mtd%7D%20%3B%20fi%3B%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%E6%8E%A9%E7%A0%81%3D255.255.255.0%3CBR%20%2F%3Enfsboot%3Decho%20%E4%BD%BF%E7%94%A8%20tftp%20%E5%92%8C%20nfs%20%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%EF%BC%9B%E8%BF%90%E8%A1%8C%20nfsbootargs%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadtftpimage%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadtftpfdt%EF%BC%9B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%EF%BC%9B%3CBR%20%2F%3E%20nfsbootargs%20%3D%20setenv%20bootargs%20console%20%3D%20%24%7Bconsole%7D%20%EF%BC%8C%20%24%7Bbaudrate%7D%20root%20%3D%20%2F%20dev%20%2F%20nfs%20rw%20ip%20%3D%20%24%7Bipaddr%7D%20%EF%BC%9A%20%24%7Bserverip%7D%20%3A%3A%20%24%7Bnetmask%7D%20%3A%3A%20eth0%EF%BC%9Aoff%20nfsroot%20%3D%20%24%7Bserverip%7D%20%EF%BC%9A%2F%20tftpboot%20%2F%20rfs%EF%BC%8Cnolock%EF%BC%8Cv3%EF%BC%8Ctcp%20earlycon%20nohz%20%3D%20off%20coherent_pool%20%3D%2064M%3CBR%20%2F%3E%20pfe1_phy_addr%3D8%3CBR%20%2F%3E%20pfe1addr%3D00%3A01%3Abe%3Abe%3Aef%3A22%3CBR%20%2F%3E%20pfe2addr%3D00%3A01%3Abe%3Abe%3Aef%3A33%3CBR%20%2F%3E%20pfeaddr%3D00%3A01%3A%E6%98%AF%3A%E6%98%AF%3Aef%3A11%3CBR%20%2F%3E%20pfeng_mode%3D%E5%90%AF%E7%94%A8%EF%BC%8Csgmii%EF%BC%8Csgmii%EF%BC%8Crgmii%3CBR%20%2F%3E%20pfengemac%3D0%3CBR%20%2F%3E%20ramdisk_addr%3D0x90000000%3CBR%20%2F%3E%20s32cc_gmac_mode%3D%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%E8%84%9A%E6%9C%AC%3Dboot.scr%3CBR%20%2F%3E%E6%9C%8D%E5%8A%A1%E5%99%A8IP%3D10.0.0.1%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E9%94%99%E8%AF%AF%3D%E4%B8%B2%E8%A1%8C%40401c8000%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E8%BE%93%E5%85%A5%3D%E4%B8%B2%E8%A1%8C%40401c8000%3CBR%20%2F%3E%E6%A0%87%E5%87%86%E8%BE%93%E5%87%BA%3D%E4%B8%B2%E8%A1%8C%40401c8000%3CBR%20%2F%3E%20update_sd_firmware%3D%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bip_dyn%7D%20%3D%20%E6%98%AF%EF%BC%9B%E5%88%99%20setenv%20get_cmd%20dhcp%EF%BC%9B%E5%90%A6%E5%88%99%20setenv%20get_cmd%20tftp%EF%BC%9Bfi%EF%BC%9B%E5%A6%82%E6%9E%9C%20mmc%20dev%20%24%7Bmmcdev%7D%20%EF%BC%9B%E5%88%99%E5%A6%82%E6%9E%9C%24%7Bget_cmd%7D%20%24%7Bupdate_sd_firmware_filename%7D%20%EF%BC%9B%E5%88%99%20setexpr%20fw_sz%20%24%7Bfilesize%7D%20%2F%200x200%EF%BC%9Bsetexpr%20fw_sz%20%24%7Bfw_sz%7D%20-%207%EF%BC%9Bsetexpr%20loadaddr%20%24%7Bloadaddr%7D%20%2B%200x1000%EF%BC%9Bmmc%20write%20%24%7Bloadaddr%7D%200x8%20%24%7Bfw_sz%7D%20%EF%BC%9Bfi%EF%BC%9Bfi%3CBR%20%2F%3E%20update_sd_firmware_filename%3Dfip.s32%3C%2FP%3E%3CP%3E%E7%8E%AF%E5%A2%83%E5%A4%A7%E5%B0%8F%EF%BC%9A3538%2F8188%20%E5%AD%97%E8%8A%82%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%3D%26gt%3B%20printenvbaudrate%3D115200board_rev%3DFboot_fdt%3Dtryboot_mtd%3Dbootibootargs%3Droot%3D%2Fdev%2Fram%20rw%20earlycon%20loglevel%3D7bootcmd%3Dmmc%20dev%20%24%7Bmmcdev%7D%20%3B%20%E5%A6%82%E6%9E%9C%20mmc%20%E9%87%8D%E6%96%B0%E6%89%AB%E6%8F%8F%EF%BC%9B%E5%88%99%E5%A6%82%E6%9E%9C%E8%BF%90%E8%A1%8C%20loadimage%EF%BC%9B%E5%88%99%E8%BF%90%E8%A1%8C%20mmcboot%EF%BC%9B%E5%90%A6%E5%88%99%E8%BF%90%E8%A1%8C%20netboot%EF%BC%9Bfi%EF%BC%9B%E5%90%A6%E5%88%99%E8%BF%90%E8%A1%8C%20netboot%EF%BC%9Bfibootdelay%3D2bootscript%3Decho%20%E4%BB%8E%20mmc%20%E8%BF%90%E8%A1%8C%E5%90%AF%E5%8A%A8%E8%84%9A%E6%9C%AC...%EF%BC%9Bsourceconsole%3DttyLF0eth1addr%3D00%3A01%3Abe%3Abe%3Aef%3A11ethact%3Deth_pfengfdt_addr%3D0x83000000fdt_enable_hs400es%3Dfdt%20addr%20%24%7Bfdt_addr%7D%20%3B%20fdt%20rm%20%2Fsoc%2Fmmc%20no-1-8-v%3B%20fdt%20%E8%B0%83%E6%95%B4%E5%A4%A7%E5%B0%8F%EF%BC%9Bfdt_file%3Ds32g399a-rdb3.dtbfdt_high%3D0xffffffffffffffffffdt_override%3D%EF%BC%9Bfdtcontroladdr%3Dffa97000flashboot%3Decho%E4%BB%8E%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8...%EF%BC%9B%E8%BF%90%E8%A1%8C%20flashbootargs%EF%BC%9Bmtd%20%E8%AF%BB%E5%8F%96%E5%86%85%E6%A0%B8%24%7Bloadaddr%7D%20%EF%BC%9Bmtd%20%E8%AF%BB%E5%8F%96%20DTB%20%24%7Bfdt_addr%7D%20%EF%BC%9Bmtd%20%E8%AF%BB%E5%8F%96%20Rootfs%20%24%7Bramdisk_addr%7D%20%EF%BC%9B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%20%3Bflashbootargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fram%20rw%20earlycon%20nohz%3Doff%20coherent_pool%3D64M%3Bsetenv%20flashsize%200x04000000%3Bhwconfig%3Dserdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D2G5image%3DImageinitrd_high%3D0xffffffffffffffffffipaddr%3D10.0.0.100jtagboot%3Decho%E4%BD%BF%E7%94%A8%20jtag%20%E5%90%AF%E5%8A%A8...%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%20jtagsdboot%3Decho%20%E4%BB%8E%20SD%20%E5%90%AF%E5%8A%A8%E4%BD%BF%E7%94%A8%20ramdisk%20%E5%8A%A0%E8%BD%BD%20Linux...%3B%20%E8%BF%90%E8%A1%8C%20loadimage%3B%20%E8%BF%90%E8%A1%8C%20loadramdisk%3B%20%E8%BF%90%E8%A1%8C%20loadfdt%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%20loadaddr%3D0x80000000loadbootscript%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bscript%7D%20%3Bloadfdt%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%E8%BF%90%E8%A1%8C%20fdt_override%EF%BC%9Bloadimage%3Dfatload%20mmc%20%24%7Bmmcdev%7D%20%3A%20%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%20loadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%EF%BC%9Bloadtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%20%EF%BC%9Bmmcargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%20%24%7Bmmcroot%7D%20earlycon%20nohz%3Doff%20coherent_pool%3D64Mmmcboot%3Decho%20%E4%BB%8E%20mmc%20%E5%90%AF%E5%8A%A8...%EF%BC%9B%E8%BF%90%E8%A1%8C%20mmcargs%EF%BC%9B%E5%A6%82%E6%9E%9C%E8%BF%90%E8%A1%8C%20loadfdt%EF%BC%9B%E5%88%99%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%EF%BC%9B%E5%90%A6%E5%88%99%E5%9B%9E%E6%98%BE%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%20DT%EF%BC%9B%20fi%3Bmmcdev%3D0mmcpart%3D1mmcroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20rwnetargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%20%24%7Bserverip%7D%20%3A%20%24%7Bnfsroot%7D%20%2Cv3%2Ctcp%20earlycon%20nohz%3Doff%20coherent_pool%3D64Mnetboot%3Decho%20%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%3B%20%E8%BF%90%E8%A1%8C%20netargs%3B%20%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bip_dyn%7D%20%3D%20%E6%98%AF%3B%20%E5%88%99%20setenv%20get_cmd%20dhcp%3B%20%E5%90%A6%E5%88%99%20setenv%20get_cmd%20tftp%3B%20fi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%20%3B%20%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bboot_fdt%7D%20%3D%20%E6%98%AF%20%7C%7C%20%E6%B5%8B%E8%AF%95%24%7Bboot_fdt%7D%20%3D%20%E5%B0%9D%E8%AF%95%3B%20%E7%84%B6%E5%90%8E%E5%A6%82%E6%9E%9C%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%20%3B%20%E7%84%B6%E5%90%8E%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%3B%20%E5%90%A6%E5%88%99%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bboot_fdt%7D%20%3D%20%E5%B0%9D%E8%AF%95%3B%20%E7%84%B6%E5%90%8E%24%7Bboot_mtd%7D%20%3B%20else%20echo%20WARN%3A%20%E6%97%A0%E6%B3%95%E5%8A%A0%E8%BD%BD%20DT%EF%BC%9Bfi%EF%BC%9Bfi%EF%BC%9Belse%20%24%7Bboot_mtd%7D%20%EF%BC%9Bfi%EF%BC%9Bnetmask%3D255.255.255.0nfsboot%3Decho%E4%BD%BF%E7%94%A8%20tftp%20%E5%92%8C%20nfs%20%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%90%AF%E5%8A%A8...%EF%BC%9B%E8%BF%90%E8%A1%8C%20nfsbootargs%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadtftpimage%EF%BC%9B%E8%BF%90%E8%A1%8C%20loadtftpfdt%EF%BC%9B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%EF%BC%9Bnfsbootargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%EF%BC%8C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20rw%20ip%3D%20%24%7Bipaddr%7D%20%EF%BC%9A%20%24%7Bserverip%7D%20%3A%3A%20%24%7Bnetmask%7D%20%3A%3Aeth0%3Aoff%20nfsroot%3D%20%24%7Bserverip%7D%20%EF%BC%9A%2Ftftpboot%2Frfs%EF%BC%8Cnolock%EF%BC%8Cv3%EF%BC%8Ctcp%20earlycon%20nohz%3Doff%20coherent_pool%3D64Mpfe1_phy_addr%3D8pfe1addr%3D00%3A01%3Abe%3Abe%3Aef%3A22pfe2addr%3D00%3A01%3Abe%3Abe%3Aef%3A33pfeaddr%3D00%3A01%3Abe%3Abe%3Aef%3A11pfeng_mode%3Denable%2Csgmii%2Csgmii%2Crgmiipfengemac%3D0ramdisk_addr%3D0x90000000s32cc_gmac_mode%3Denablescript%3Dboot.scrserverip%3D10.0.0.1stderr%3Dserial%40401c8000stdin%3Dserial%40401c8000stdout%3Dserial%40401c8000update_sd_firmware%3D%E5%A6%82%E6%9E%9C%E6%B5%8B%E8%AF%95%24%7Bip_dyn%7D%20%3D%20%E6%98%AF%3B%20%E7%84%B6%E5%90%8E%20setenv%20get_cmd%20dhcp%3B%20%E5%90%A6%E5%88%99%20setenv%20get_cmd%20tftp%3B%20fi%3B%E5%A6%82%E6%9E%9C%20mmc%20dev%20%24%7Bmmcdev%7D%20%3B%20%E7%84%B6%E5%90%8E%E5%A6%82%E6%9E%9C%24%7Bget_cmd%7D%20%24%7Bupdate_sd_firmware_filename%7D%20%3B%20%E7%84%B6%E5%90%8E%20setexpr%20fw_sz%20%24%7Bfilesize%7D%20%2F%200x200%3B%20setexpr%20fw_sz%20%24%7Bfw_sz%7D%20-%207%3B%20setexpr%20loadaddr%20%24%7Bloadaddr%7D%20%2B%200x1000%3B%20mmc%20write%20%24%7Bloadaddr%7D%200x8%20%24%7Bfw_sz%7D%20%3B%20fi%3B%20fiupdate_sd_firmware_filename%3Dfip.s32Environment%E5%A4%A7%E5%B0%8F%EF%BC%9A3538%2F8188%20%E5%AD%97%E8%8A%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20sja1110%20gPTP%20%E6%97%B6%E5%8F%91%E7%94%9F%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231689%22%20target%3D%22_blank%22%3E%40xiaoshumiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E6%A3%80%E6%9F%A5%E6%82%A8%E6%B7%BB%E5%8A%A0%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%8C%E4%BC%BC%E4%B9%8E%E9%97%AE%E9%A2%98%E4%BB%85%E5%87%BA%E5%9C%A8%E5%8A%A0%E8%BD%BD%E4%B8%8A%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20gPTP%20%E9%85%8D%E7%BD%AE%E4%B8%8A%E3%80%82%E8%AF%B7%E6%A3%80%E6%9F%A5%20J198%20%E4%B8%AD%E7%9A%84%E8%B7%B3%E7%BA%BF%E5%B9%B6%E7%A1%AE%E4%BF%9D%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1745266247187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1745266247187.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334109iFE46DF1EE00369C3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1745266247187.png%22%20alt%3D%22alejandro_e_0-1745266247187.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%8A%E8%BF%B0%E9%85%8D%E7%BD%AE%E6%B5%8B%E8%AF%95%E6%88%90%E5%8A%9F%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Es32g399ardb3%20login%3A%20root%0Aroot%40s32g399ardb3%3A~%23%20dmesg%20%7C%20grep%20-i%20%22sja%22%0A%5B%20%20%20%200.591985%5D%20gpio-345%20(sja1110-rst-phy-t1)%3A%20hogged%20as%20output%2Flow%0A%5B%20%20%20%200.597484%5D%20gpio-402%20(sja1110-rst-core)%3A%20hogged%20as%20output%2Flow%0A%5B%20%20%20%206.765011%5D%20sja1110%3A%20loading%20out-of-tree%20module%20taints%20kernel.%0A%5B%20%20%20%206.765512%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-switch%0A%5B%20%20%20%206.765516%5D%20SPI%20driver%20sja1110%20has%20no%20spi_device_id%20for%20nxp%2Csja1110-uc%0A%5B%20%20%20%206.765614%5D%20sja1110%20spi5.0%3A%20probing%20uc%0A%5B%20%20%20%206.765743%5D%20sja1110%20spi5.1%3A%20probing%20switch%0A%5B%20%20%20%206.766024%5D%20sja1110%20spi5.1%3A%20Could%20not%20get%20GPIO%20from%20device%20tree%0A%5B%20%20%20%206.766044%5D%20sja1110%20spi5.1%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20switch%0A%5B%20%20%20%206.766659%5D%20sja1110%20spi5.1%3A%20Direct%20firmware%20load%20for%20sja1110_switch.bin%20failed%20with%20error%20-2%0A%5B%20%20%20%206.766668%5D%20sja1110%20spi5.1%3A%20request_firmware%20failed%20with%20-2%0A%5B%20%20%20%206.766673%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_post_probe_upload_worker%5D%20Trying%20to%20initialize%20uC%0A%5B%20%20%20%206.769220%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_init_hw%5D%20loaded%20fw%20'sja1110_uc.bin'%0A%5B%20%20%20%206.769227%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20Found%20firmware%20of%20size%20125376%0A%5B%20%20%20%206.769302%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20firmware%20appears%20to%20be%20valid%0A%5B%20%20%20%206.769340%5D%20sja1110%20spi5.0%3A%20%5Bsja1110_pre_uc_upload%5D%20%5Cxc2%5Cxb5C%20not%20ready%20for%20download%20(Status%3D0x31)%0A%5B%20%20%20%206.769430%5D%20sja1110%20spi5.0%3A%20Uploading%20firmware...%0A%5B%20%20%20%207.061479%5D%20sja1110%20spi5.0%3A%20Upload%20successfully%20verified!%0Aroot%40s32g399ardb3%3A~%23%20ls%20%2Flib%2Ffirmware%2F%0As32g_pfe_class.fw%20%20s32g_pfe_util.fw%20%20sja1110_uc.bin%0Aroot%40s32g399ardb3%3A~%23%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%8D%E7%84%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
