TJA1103 soft reset timeout and wrong phy address
3,423件の閲覧回数
veljko_v
I'm trying to connect the TJA1103 evaluation board to my custom imx93 board. I get this error message on boot
Starting network: [    4.078772] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[    4.168819] imx-dwmac 428a0000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[    4.439182] NXP C45 TJA1103 stmmac-1:01: nxp_c45_soft_reset failed: -110
[    4.446593] imx-dwmac 428a0000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -110)
ip: SIOCSIFFLAGS: Connection timed out
FAIL
I am running a 6.12 linux kernel.
CONFIG_NXP_C45_TJA11XX_PHY is enabled and my device tree entry looks like this:
&eqos {
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_eqos>;
    phy-handle = <&ethphy1>;
    phy-mode = "rgmii";
    status = "okay";
    mdio {
        compatible = "snps,dwmac-mdio";
        #address-cells = <1>;
        #size-cells = <0>;
        clock-frequency = <5000000>;
       ethphy1: ethernet-phy@1 {
            compatible = "ethernet-phy-ieee802.3-c45";
            reg = <1>;
I found a thread saying there is a bug in the nxp-c45-tja11xx driver, I implemented the fix (one flag to true instead of false) but the issue still persists.
Another maybe connected issue is that with mdio tools, I see the address of the device as 2 (even though I set it to 1 using the jumpers on the eval board).
# mdio stmmac-1
 DEV      PHY-ID  LINK
0x02  0x001bb013  down
I tried a lot of different jumper configurations since I am no mdio expert. Master/slave mode, rgmii, rgmii-id etc. Nothing helps. Any insights would be very appreciated, thanks!
3,289件の閲覧回数
joanxie
sorry for my late, I've taken my annual leave this week, I don't find exist example for TJA1103 with imx93, but maybe you can refer to the attachment, if still failed, I will try to help you when I come back to office
6 返答(返信)
3,379件の閲覧回数
joanxie
it seems this issue isn't related to the imx93 side, you can refer to the link as Pavel mentioned
3,355件の閲覧回数
veljko_v
I'm sorry I don't know which link you are referring to nor who Pavel is?
3,342件の閲覧回数
joanxie
3,332件の閲覧回数
veljko_v
As already mentioned, the patch is implemented but the error persists. And it doesn't solve the wrong address issue. I also observed that resetting the board sometimes leads to the change in the PHY address. The board is behaving very incosistent. This is the furthest I got at one moment, but reseting the device again just leads again to either error -19 or -110 .
[    2.380307] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
[    2.386173] imx-dwmac 428a0000.ethernet: IRQ sfty not found
[    2.392701] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[    2.399546] imx-dwmac 428a0000.ethernet: 	DWMAC4/5
[    2.404334] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
[    2.411463] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
[    2.418586] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
[    2.425281] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
[    2.431423] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.439075] imx-dwmac 428a0000.ethernet: device MAC address 32:d1:4d:11:05:97
[    2.446202] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[    2.452977] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.459765] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.467321] imx-dwmac 428a0000.ethernet: Using 32/32 bits DMA host/device width
[    2.611033] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
[    2.616884] imx-dwmac 428a0000.ethernet: IRQ sfty not found
[    2.623405] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[    2.630203] imx-dwmac 428a0000.ethernet: 	DWMAC4/5
[    2.634986] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
[    2.642108] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
[    2.649231] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
[    2.655923] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
[    2.662006] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.669657] imx-dwmac 428a0000.ethernet: device MAC address 92:8e:ee:e0:a7:37
[    2.676785] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[    2.683565] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.690352] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.697920] imx-dwmac 428a0000.ethernet: Using 32/32 bits DMA host/device width
[    4.746055] imx-dwmac 428a0000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[    4.791287] imx-dwmac 428a0000.ethernet eth0: PHY [stmmac-1:02] driver [NXP C45 TJA1103] (irq=POLL)
[    5.106134] usbcore: registered new interface driver cdc_ether
[    5.802180] imx-dwmac 428a0000.ethernet: Failed to reset the dma
[    5.808264] imx-dwmac 428a0000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[    5.816985] imx-dwmac 428a0000.ethernet eth0: __stmmac_open: Hw setup failed
3,290件の閲覧回数
joanxie
3,282件の閲覧回数
veljko_v
Thank you for your response, and the attached example. I made it work, the main issue was I cross connected the Tx to Rx and vice versa. The correct connection is Tx - Tx and Rx - Rx
This was probably causing voltage fluctuations and pin strapping the phy address was unstable because of it.
%3CLINGO-SUB%20id%3D%22lingo-sub-2165910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETJA1103%20%E3%82%BD%E3%83%95%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E7%89%A9%E7%90%86%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20TJA1103%20%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20imx93%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EStarting%20network%3A%20%5B%20%20%20%204.078772%5D%20usb%202-1%3A%20new%20high-speed%20USB%20device%20number%202%20using%20ci_hdrc%0A%5B%20%20%20%204.168819%5D%20imx-dwmac%20428a0000.ethernet%20eth0%3A%20Register%20MEM_TYPE_PAGE_POOL%20RxQ-0%0A%5B%20%20%20%204.439182%5D%20NXP%20C45%20TJA1103%20stmmac-1%3A01%3A%20nxp_c45_soft_reset%20failed%3A%20-110%0A%5B%20%20%20%204.446593%5D%20imx-dwmac%20428a0000.ethernet%20eth0%3A%20__stmmac_open%3A%20Cannot%20attach%20to%20PHY%20(error%3A%20-110)%0Aip%3A%20SIOCSIFFLAGS%3A%20Connection%20timed%20out%0AFAIL%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%A7%81%E3%81%AF%206.12%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3ECONFIG_NXP_C45_TJA11XX_PHY%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Beqos%20%7B%0A%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos%26gt%3B%3B%0A%20%20%20%20phy-handle%20%3D%20%26lt%3B%26amp%3Bethphy1%26gt%3B%3B%0A%20%20%20%20phy-mode%20%3D%20%22rgmii%22%3B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20mdio%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22snps%2Cdwmac-mdio%22%3B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B5000000%26gt%3B%3B%0A%0A%20%20%20%20%20%20%20ethphy1%3A%20ethernet-phy%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22ethernet-phy-ieee802.3-c45%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Enxp-c45-tja11xx%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%83%90%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86Thread%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E4%BF%AE%E6%AD%A3%E3%82%92%E5%AE%9F%E6%96%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AE%201%20%E3%81%A4%E3%82%92%20false%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20true%20%E3%81%AB%E8%A8%AD%E5%AE%9A)%20%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81mdio%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%202%20%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20(%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A)%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23%20mdio%20stmmac-1%0A%20DEV%20%20%20%20%20%20PHY-ID%20%20LINK%0A0x02%20%200x001bb013%20%20down%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%20MDIO%20%E3%81%AE%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E6%A7%8B%E6%88%90%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81rgmii%E3%80%81rgmii-id%20%E3%81%AA%E3%81%A9%E3%80%82%E4%BD%95%E3%82%82%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E6%84%8F%E8%A6%8B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2165910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1103%20soft%20reset%20timeout%20and%20wrong%20phy%20address%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%A8%E6%B7%BB%E4%BB%98%E3%81%AE%E4%BE%8B%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%B8%BB%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AF%20Tx%20%E3%81%A8%20Rx%20%E3%82%92%E7%9B%B8%E4%BA%92%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E6%AD%A3%E3%81%97%E3%81%84%E6%8E%A5%E7%B6%9A%E3%81%AFTx%20-%20Tx%E3%81%A8Rx%20-%20Rx%E3%81%A7%E3%81%99%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%93%E3%82%8C%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E9%9B%BB%E5%9C%A7%E5%A4%89%E5%8B%95%E3%81%A8%E3%83%94%E3%83%B3%E3%82%B9%E3%83%88%E3%83%A9%E3%83%83%E3%83%97%E3%81%AE%20PHY%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1103%20soft%20reset%20timeout%20and%20wrong%20phy%20address%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%81%85%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%8A%E9%80%B1%E3%81%AF%E5%B9%B4%E6%AC%A1%E4%BC%91%E6%9A%87%E3%82%92%E5%8F%96%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81imx93%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20TJA1103%20%E3%81%AE%E4%BE%8B%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%9F%E3%82%89%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1103%20soft%20reset%20timeout%20and%20wrong%20phy%20address%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%99%E3%81%A7%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E4%BD%8F%E6%89%80%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81PHY%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%8C%E4%B8%80%E5%BA%A6%E3%81%AB%E5%88%B0%E9%81%94%E3%81%97%E3%81%9F%E6%9C%80%E5%96%84%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%20-19%20%E3%81%BE%E3%81%9F%E3%81%AF%20-110%20%E3%81%8C%E5%86%8D%E3%81%B3%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5B%20%20%20%202.380307%5D%20imx-dwmac%20428a0000.ethernet%3A%20IRQ%20eth_lpi%20not%20found%0A%5B%20%20%20%202.386173%5D%20imx-dwmac%20428a0000.ethernet%3A%20IRQ%20sfty%20not%20found%0A%5B%20%20%20%202.392701%5D%20imx-dwmac%20428a0000.ethernet%3A%20User%20ID%3A%200x10%2C%20Synopsys%20ID%3A%200x52%0A%5B%20%20%20%202.399546%5D%20imx-dwmac%20428a0000.ethernet%3A%20%09DWMAC4%2F5%0A%5B%20%20%20%202.404334%5D%20imx-dwmac%20428a0000.ethernet%3A%20DMA%20HW%20capability%20register%20supported%0A%5B%20%20%20%202.411463%5D%20imx-dwmac%20428a0000.ethernet%3A%20RX%20Checksum%20Offload%20Engine%20supported%0A%5B%20%20%20%202.418586%5D%20imx-dwmac%20428a0000.ethernet%3A%20TX%20Checksum%20insertion%20supported%0A%5B%20%20%20%202.425281%5D%20imx-dwmac%20428a0000.ethernet%3A%20Wake-Up%20On%20Lan%20supported%0A%5B%20%20%20%202.431423%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enable%20RX%20Mitigation%20via%20HW%20Watchdog%20Timer%0A%5B%20%20%20%202.439075%5D%20imx-dwmac%20428a0000.ethernet%3A%20device%20MAC%20address%2032%3Ad1%3A4d%3A11%3A05%3A97%0A%5B%20%20%20%202.446202%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabled%20L3L4%20Flow%20TC%20(entries%3D8)%0A%5B%20%20%20%202.452977%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabled%20RFS%20Flow%20TC%20(entries%3D10)%0A%5B%20%20%20%202.459765%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabling%20HW%20TC%20(entries%3D256%2C%20max_off%3D256)%0A%5B%20%20%20%202.467321%5D%20imx-dwmac%20428a0000.ethernet%3A%20Using%2032%2F32%20bits%20DMA%20host%2Fdevice%20width%0A%5B%20%20%20%202.611033%5D%20imx-dwmac%20428a0000.ethernet%3A%20IRQ%20eth_lpi%20not%20found%0A%5B%20%20%20%202.616884%5D%20imx-dwmac%20428a0000.ethernet%3A%20IRQ%20sfty%20not%20found%0A%5B%20%20%20%202.623405%5D%20imx-dwmac%20428a0000.ethernet%3A%20User%20ID%3A%200x10%2C%20Synopsys%20ID%3A%200x52%0A%5B%20%20%20%202.630203%5D%20imx-dwmac%20428a0000.ethernet%3A%20%09DWMAC4%2F5%0A%5B%20%20%20%202.634986%5D%20imx-dwmac%20428a0000.ethernet%3A%20DMA%20HW%20capability%20register%20supported%0A%5B%20%20%20%202.642108%5D%20imx-dwmac%20428a0000.ethernet%3A%20RX%20Checksum%20Offload%20Engine%20supported%0A%5B%20%20%20%202.649231%5D%20imx-dwmac%20428a0000.ethernet%3A%20TX%20Checksum%20insertion%20supported%0A%5B%20%20%20%202.655923%5D%20imx-dwmac%20428a0000.ethernet%3A%20Wake-Up%20On%20Lan%20supported%0A%5B%20%20%20%202.662006%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enable%20RX%20Mitigation%20via%20HW%20Watchdog%20Timer%0A%5B%20%20%20%202.669657%5D%20imx-dwmac%20428a0000.ethernet%3A%20device%20MAC%20address%2092%3A8e%3Aee%3Ae0%3Aa7%3A37%0A%5B%20%20%20%202.676785%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabled%20L3L4%20Flow%20TC%20(entries%3D8)%0A%5B%20%20%20%202.683565%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabled%20RFS%20Flow%20TC%20(entries%3D10)%0A%5B%20%20%20%202.690352%5D%20imx-dwmac%20428a0000.ethernet%3A%20Enabling%20HW%20TC%20(entries%3D256%2C%20max_off%3D256)%0A%5B%20%20%20%202.697920%5D%20imx-dwmac%20428a0000.ethernet%3A%20Using%2032%2F32%20bits%20DMA%20host%2Fdevice%20width%0A%5B%20%20%20%204.746055%5D%20imx-dwmac%20428a0000.ethernet%20eth0%3A%20Register%20MEM_TYPE_PAGE_POOL%20RxQ-0%0A%5B%20%20%20%204.791287%5D%20imx-dwmac%20428a0000.ethernet%20eth0%3A%20PHY%20%5Bstmmac-1%3A02%5D%20driver%20%5BNXP%20C45%20TJA1103%5D%20(irq%3DPOLL)%0A%5B%20%20%20%205.106134%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ether%0A%5B%20%20%20%205.802180%5D%20imx-dwmac%20428a0000.ethernet%3A%20Failed%20to%20reset%20the%20dma%0A%5B%20%20%20%205.808264%5D%20imx-dwmac%20428a0000.ethernet%20eth0%3A%20stmmac_hw_setup%3A%20DMA%20engine%20initialization%20failed%0A%5B%20%20%20%205.816985%5D%20imx-dwmac%20428a0000.ethernet%20eth0%3A%20__stmmac_open%3A%20Hw%20setup%20failed%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1103%20soft%20reset%20timeout%20and%20wrong%20phy%20address%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FNXP-C45-TJA11XX-Driver-Soft-Reset-Issue%2Fm-p%2F2028298%23M233019%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FNXP-C45-TJA11XX-Driver-Soft-Reset-Issue%2Fmp%2F2028298%23M233019%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1103%20soft%20reset%20timeout%20and%20wrong%20phy%20address%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%A9%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%20Pavel%20%E3%81%8C%E8%AA%B0%E3%81%AA%E3%81%AE%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1103%20soft%20reset%20timeout%20and%20wrong%20phy%20address%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFimx93%E5%81%B4%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82Pavel%E3%81%8C%E8%BF%B0%E3%81%B9%E3%81%9F%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92CAN%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
