TEF8101 ADC data error?
2,287 次查看
longfeiwang
I am using TEF8101 (LVDS interface),When I set the decimation rate to 1, the ADC equivalent sampling rate is 40MHZ,The ADC data (DC component 2048 has been subtracted) seems to have a lot of sudden changes(-2048\-2045...), such as the figure below.
If I change the decimation rate to 2 and the equivalent sampling rate is 20MHZ, the abrupt data will not exist.
Has some filtering been done in the PDC?
2,271 次查看
petervlna
Could you please explain what your are intending to do?
Decimation factor of 1 is for test purposes only, as stated in the datasheet
Peter
2,272 次查看
petervlna
Peter
2,268 次查看
longfeiwang
The problem has been solved. After modifying the FPGA LVDS timing, the abrupt data no longer exists
