Stack Analysis in MCUXPRESSO IDE
2,189件の閲覧回数
prasannanaik
I am using MCUXPESSO IDE to develop a Protection Relay with LPC54608J512BD208 microcontroller. I want to analyze the stack usage of the Firmware.
Is there any feature in MCUXpresso through which i can find stack usage of different functions and interrupts.
Thanks & Regards,
Prasanna
タグ(1)
2,180件の閲覧回数
gusarambula
Hello Prasanna,
There is a heap and stack view on MCUXpresso IDE, you can find a brief description on the MCUXpresso IDE User Guide (link below).
https://www.nxp.com/docs/en/user-guide/MCUXpresso_IDE_User_Guide.pdf
For a more hands-on approach, please check the Advanced Debugging with MCUXpresso IDE training (link below, you may need to login to access it). Particularly Part 5.
Part 1: Building Debugging and Direct Flashing
https://www.nxp.com/design/training/advanced-debugging-with-mcuxpresso-ide-part-1-building-debugging...
Part 2: Accessing Data and Peripherals
https://www.nxp.com/design/training/advanced-debugging-with-mcuxpresso-ide-part-2-accessing-data-and...
Part 3: Code & Data Breakpoints
https://www.nxp.com/design/training/advanced-debugging-with-mcuxpresso-ide-part-3-code-data-breakpoi...
Part 4: Instruction Trace
https://www.nxp.com/design/training/advanced-debugging-with-mcuxpresso-ide-part-4-instruction-trace:...
Part 5:  FreeRTOS Task Aware Debug
https://www.nxp.com/design/training/advanced-debugging-with-mcuxpresso-ide-part-5-freertos-task-awar...
Part 6: SWO trace
https://www.nxp.com/design/training/advanced-debugging-with-mcuxpresso-ide-part-6-swo-trace:TIP-ADVA...
I hope that this information helps!
Gustavo
