Sign or encrypt with SE050
1,831 次查看
bi_jian
The picture below is from "AN12413-SE050_APDU_specification" , if I want to sign or encrypt more than 256 bytes, what should I do?
1,755 次查看
Kan_Li
Hi Bi Jian,
RSA crypto operations will be available for certain bit lengths, defined in RSABitLength. Please refer to  the following for details.
Hope that helps,
Kan
1,756 次查看
Kan_Li
Hi Bi Jian,
Hope that helps,
Kan
