Sign or encrypt with SE050
bi_jian
The picture below is from "AN12413-SE050_APDU_specification" , if I want to sign or encrypt more than 256 bytes, what should I do?
Kan_Li
Hi Bi Jian,
RSA crypto operations will be available for certain bit lengths, defined in RSABitLength. Please refer to  the following for details.
Hope that helps,
Kan
Kan_Li
Hi Bi Jian,
Hope that helps,
Kan
