Regarding Redboot Loader
5,650件の閲覧回数
sureshsgani
I want to build the Redboot Loader this requires the package,
ecostools_linux.tar.gz file, and also the toolchain needed to build Boot loader.
Please can any of you help me where I can get source code or binary files of this.
Thanking you
    Suresh
3 返答(返信)
2,587件の閲覧回数
arthas
hope these info can  help you
2,587件の閲覧回数
arthas
This is my doc .
Build redboot
Building for Windows
1. download config tools and arm-elf
ecos config tools -> http://www.ecoscentric.com/devzone/configtool.shtml
arm-elf-tool ->ftp://sources-redhat.mirror.redwire.net/pub/sources.redhat.com/ecos/gnutools
or use ecos-install.tcl
run to get gnu-tools for cross-compile
sh ecos-install.tcl /opt/ecos arm-elf i386-elf
1. set ecos env
export ECOS_RWEPOSITORY=/cygdrive/e/i.mx/mx27/ecos_20050912/packages
2. run configtool
 build menu-> templates -> select Freescale i.MX27 ADS broad; packages select redboot
 file menu-> import-> import hal\arm\mx27\ads\current\misc\redboot_ROMRAM.ecm
3. build
 build menu->Library (F7)
Building for Linux
2,587件の閲覧回数
rasheed
Hi i am using Redboot with i.mx 31 ADS board . The problem is i flashed the images from Linux onto the nand flash and changed the redboot source to boot these new images and i reset , but redboot is not able to boot these images can u provide any solution .
Thanks in advance
the error is
Checksum failure
invalid entry address
