Reference schematics for connecting RST_N pin to host
已解决
跳至解决方案
2,591 次查看
masahirokiniwa
I'm considering to connect RST_N pin to host.
Could you give us the reference circuit for above use case?
In Fig4 of data sheet, RST_N is connected to GND by 1uF OPTIONAL capacitor.
Could you tell me the function of this capacitor and why you choose this value?
I think that I need to care the RST_N, if it is used for reducing noise or other effects.
M.Kiniwa
标记 (1)
1 解答
2,455 次查看
lisettelozano
Hi Masahiro,
I apologize for the delayed response. The capacitor on RST_N pin is a decoupling capacitor that helps to filter noise on this pin. We do not have any reference circuit besides the ones in the website in our application note AN11590 and user guide UM10837; however, you can connect RST_N pin to host, you should not have any inconveniences. Please check the characteristics of this pin on table 21 in the datasheet.
Paulina
在原帖中查看解决方案
3 回复数
2,455 次查看
lisettelozano
Hello Masahiro,
Please provide the device part number that you are using so we can address it correctly.
Paulina
2,455 次查看
masahirokiniwa
Hi Paulina-san,
Sorry, I use PTA3356.
Could you please confirm above requests?
M.Kiniwa
2,456 次查看
lisettelozano
Hi Masahiro,
Paulina
