RF Circuit Collection
3,452 次查看
Anand_C
Hi, I have been trying to download RF Design files from the RF Circuit Collection area after logging in, but it goes to nxp.webapp/Download page and the stays there for ever (blank page). I am not able to download any design file. Really upset about this. How we can solve this issue?
Kind regards,
Anand Chemmunda
3,420 次查看
Anand_C
Hi  Andrei,
I   tried different browsers, cleared cache and cookies and tried all those - unfortunately it did not work.
Then I tried on two different computers, still there was no luck.
Hence I thought the issue might be related to my account. So I went to My NXP - My Account - Change user information and checked the entries. There, I found some fields with asterisk were not filled up. I just filled up all required fields, saved and then tried the download - To my surprise it downloaded straight away without any issues. I am so happy :).
Thanks so much for your support and patience on this. Hope this will help other friends in this forum.
Kind regards,  Anand C
5 回复数
3,430 次查看
andrei_skok
I am able to download files using the IE, Chrome, Firefox. Try to clear cache, cookies, check your browser settings, try different browser.
If it doesn't work, you can tell me what files you need and I will send them to you.
3,421 次查看
Anand_C
Hi  Andrei,
3,426 次查看
Anand_C
Hi Andrei,
Thanks so much for your response. Got it, let me try your suggestions and will update you shortly on the outcome.
Kind regards,
Anand Chemmunda.
3,445 次查看
andrei_skok
It works on my side. Please try again. If it doen't work, please tell me what design files you try to download.
3,442 次查看
Anand_C
Hi Andrei,
Thanks for your response.
I tried to download several RF circuits till now, but every time it goes to the download page which is blank and stays there for ever (nothing happens - just blank screen).  After reading your reply, I tried again this morning to download MRF1K50H 13.56 MHz circuit as an example, but exactly same thing happened.
No idea why this is happening??
Kind regards,
Anand Chemmunda
