QI-Wireless power receiver MWPR1516
2,113件の閲覧回数
Prabhath
In my custom wireless power receiver board using MWPR1516. I have a problem: after connecting the battery and attempting to charge it wirelessly for a few seconds, the power abruptly shuts off. Then I looked at the transmitter fault, which stated "Abrupt End of Power Transfer(EPT) initiated by the receiver." Does anyone have any ideas?
Thank you in advance.
1,986件の閲覧回数
guoweisun
For the software issue please submit ticket here:
Home (nxp.com)
7 返答(返信)
1,911件の閲覧回数
Prabhath
I just add a series resistor with the battery then the power reception from the coil takes place. Then I reduce the value of the resistor up to a minimum of 0.4 Ohms(Only the lowest value in hand) and the power transfer still takes place. The measured voltage across the series 0.4 Ohm resistor was 1.48V.
Additionally what changes I will need in the MWPR1516 demo application for achieving the 15W wireless charging? because I am suspecting the issue is related to the OCP or over-temperature.
2,048件の閲覧回数
guoweisun
You can refer to user guide for better understand and use it:
WPR1500BUCKMPUG.fm (nxp.com)
1,998件の閲覧回数
Prabhath
"Is there any issue with using the CodeWarrior free trial and the MWPR1516 software package provided by NXP? Because now I'm using this combination.
1,987件の閲覧回数
guoweisun
Home (nxp.com)
2,077件の閲覧回数
guoweisun
Do you change any transmitter board to try?
1,965件の閲覧回数
Prabhath
Is there any specification for coil
2,073件の閲覧回数
Prabhath
Yes, I tried 3 different transmitters.
