Programmer for WCT1013.
5,524 次查看
stproj18
I need to know what programmer I can use for WCT1013. Somebody can help me?
标记 (1)
5,222 次查看
fortunely
Hello Flavio Caruso,
I guess you maybe need a programmer for production.
Maybe you can use PEMicro U-Cyclone (Fx), pls refer:
PEmicro | Experts in Embedded tools for Flash Programming and Development
You can query all device supported from the following link:
It doesn't include MWCT1013, but the PC software for U-Cyclone can support it. Pls update your PC software if there is no PN MWCT1013 in your PC software.
7 回复数
5,223 次查看
fortunely
5,222 次查看
stproj18
Hi Martin,
   Many thanks for the answer! This is exactly what I need!
   Exist an other options too? I mean other devices like this?
Regrads,
Flavio
5,222 次查看
fortunely
Hi Flavio,
Surely there are other options. But I didn't test other programmers.
Maybe you have to valid it by yourself.
This programmer for freescale DSC MCU comes from China, supporting MWCT family.
Ref: http://www.lunkedz.com/?/goods/id-14/index.html
5,222 次查看
guoweisun
Please consider about CodeWarrior for mcu ver10.x tools.
5,222 次查看
stproj18
Thank you for your answer but I think I express myself wrong...
I meant hardware programmer, or hardware device for programming in circuit.
5,222 次查看
guoweisun
Sorry that I don't understand what you mean about hardware programmer?
Can you give a example?
5,222 次查看
stproj18
I mean a ICSP (in circuit system programmer) to download the firmware in the internal flash without using a bootloader or to write the bootloader.
For example, Microchip has a ICD3 or PICKit3 MPLAB ICD 4 In-Circuit Debugger
ATMEL has one too Atmel-ICE
