I am currently using the 1169 SBC and have encountered an issue while working with this chip. To trigger an over-voltage event, I continuously inject a 7V voltage into the VEXT pin. The software successfully detects the VEXTO event in the Supply Event Status Register.
However, after I clear the event by writing a 1 to the register, I can no longer detect the VEXTO event again. The event only appears again if I stop the fault injection and re-inject it. Why is this happening?
I was hoping to implement a debounce mechanism by continuously polling the VEXTO bit, but this approach doesn't seem to be feasible.Can you help me?
UJA1169TK
