MPC8349EA in Little Endian
2,851 次查看
silvereye
We use MPC8349 based design to basically transfer data between Gigabit Ethernet and PCI. We are developing an application based on MPC8349-miTXE reference board.
Since our GbE device and PCI are both little-endian, we are facing lot of problems in actual data exchange between GbE and MPC8349. Basically because MPC8349 in the mITX board is big-endian, by default, and GbE data is little-endian.
Is there any method of changing the endian-ness to Little Endian through a user-mode linux program  (my own C program) that would run on the Linux (FreeScale's flavour) on miTX? ie, after uboot & Linux is loaded?
Please help me.
Thank you.
Warm Regards
-silvereye
标记 (1)
1,748 次查看
silvereye
Well,
I did not find how to do this, I decided to use the processor in big-endian itself.
Warm
Please help me.
Thank you.
Warm Regards
-silvereye
1,749 次查看
silvereye
Well,
Warm
Please help me.
Thank you.
Warm Regards
-silvereye
