MPC5744P core checker
2,330件の閲覧回数
李丽丽
what's the core checker mechanism of MPC5744P?
2 返答(返信)
2,268件の閲覧回数
lukaszadrapa
Checker Core_0s operates in lock step mode with Main Core_0, executing exactly the same instructions as Main Core_0. Thus, Checker Core_0s checks to insure that Main Core_0 is executing correctly. RCCU (Redundancy control checker unit) continuously monitor lock step and if it founds inconsistency it reports this fault to FCCU. In FCCU you can decide whenever you like to trigger interrupt, reset or signal it to outside world. The Checker core and RCCU are disabled in debug mode and it runs in normal mode (no need to enable it manually).
Lukas
2,268件の閲覧回数
李丽丽
OK, thanks.whether there is some details document for core checking
