MPC555LFAZP40 Temperature
2,521 次查看
yonim
Whats is the operating temperature range of MPC555LFAZP40 - not packaged ?
Jonathan Mach
2,446 次查看
lukaszadrapa
That's one spec for two parameters:
One specification is Operating temperature range for die, second specification is Maximum junction temperature for packaged devices.
Lukas
2,446 次查看
lukaszadrapa
Hi Jonathan,
it can be found in the user manual:
Lukas
2,446 次查看
yonim
Are you sure?
Because under your yellow mark, they write down "for packaged devices".
Jonathan
2,447 次查看
lukaszadrapa
Lukas
