MPC555LFAZP40 Temperature
2,557件の閲覧回数
yonim
Whats is the operating temperature range of MPC555LFAZP40 - not packaged ?
Jonathan Mach
2,482件の閲覧回数
lukaszadrapa
That's one spec for two parameters:
One specification is Operating temperature range for die, second specification is Maximum junction temperature for packaged devices.
Lukas
3 返答(返信)
2,482件の閲覧回数
lukaszadrapa
Hi Jonathan,
it can be found in the user manual:
Lukas
2,482件の閲覧回数
yonim
Are you sure?
Because under your yellow mark, they write down "for packaged devices".
Jonathan
2,483件の閲覧回数
lukaszadrapa
Lukas
