Issue with flexbuild_lsdk2108
1,726 次查看
gsuresh_12
I am using LS1088ARDB_PB platform for my development. I could able to compile and port the flexbuild_lsdk2108 latest build on that platform.
I have tried to modify the .config file for virtual address space for 39 bits, at the end of the compilation, I am seeing below mentioned error.
MODPOST Module.symvers
ERROR: modpost: "linflex_string_write" [drivers/tty/serial/fsl_linflexuart.ko] undefined!
make[4]: *** [/home/suresh/Public/MyCodes/flexbuild_lsdk2108M39/flexbuild_lsdk2108/components/linux/linux/scripts/Makefile.modpost:111: Module.symvers] Error 1
make[4]: *** Deleting file 'Module.symvers'
make[3]: *** [/home/suresh/Public/MyCodes/flexbuild_lsdk2108M39/flexbuild_lsdk2108/components/linux/linux/Makefile:1412: modules] Error 2
make[2]: *** [Makefile:185: __sub-make] Error 2
make[1]: *** [kernel.mk:13: kernel] Error 2
make: *** [Makefile:22: linux] Error 2
Please suggest the solution for this issue, in fact once modify the configuration file this issue is arising.
Suresh
1,713 次查看
yipingwang
Would you please provide your Linux Kernel configuration file(.config)?
