Issue with dpdk-l2fwd-crypto Application SW on Ubuntu 20.04 PC
sheikfaaruk
I am testing dpdk application in PC with PCI-E Dual-RJ45 gigabit NIC card to develop a network based application. I have started my project with dpdk 21.08 and Codewarrior IDE.
PC details :
uname -a
Linux mglocadmin-ThinkCentre-M73 5.15.0-105-generic #115~20.04.1-Ubuntu SMP Mon Apr 15 17:33:04 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
The following steps to install DPDK (Data Plane Development Kit) on Ubuntu 20.04:
sudo apt update
sudo apt install build-essential meson python3-pyelftools libnuma-dev pkgconf
wget https://fast.dpdk.org/rel/dpdk-21.08.tar.xz
tar -xf dpdk-21.08.tar.xz
meson build
ninja -C build
meson -Dexamples=all build
sudo ninja install
sudo ldconfig
Setup hugepage in PC:
mkdir -p /dev/hugepages
mountpoint -q /dev/hugepages || mount -t hugetlbfs nodev /dev/hugepages
echo 64 > /sys/devices/system/node/node0/hugepages/hugepages-2048kB/nr_hugepages
Setup NIC card in PC:
sudo ifconfig enp2s0f1 down
sudo ifconfig enp2s0f0 down
cd /<Path>/dpdk-21.08/usertools/
sudo modprobe uio
sudo modprobe uio_pci_generic
sudo dpdk-devbind.py -b uio_pci_generic 02:00.0
sudo dpdk-devbind.py -b uio_pci_generic 02:00.1
dpdk-devbind.py -s
Log "dpdk-devbind.py -s":
Network devices using DPDK-compatible driver
0000:02:00.0 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' drv=uio_pci_generic unused=e1000e,vfio-pci
0000:02:00.1 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' drv=uio_pci_generic unused=e1000e,vfio-pci
Network devices using kernel driver
0000:03:00.0 'RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller 8168' if=enp3s0 drv=r8169 unused=vfio-pci,uio_pci_generic *Active*
cd /<PATH>/dpdk-21.08/build/examples
sudo ./dpdk-l2fwd -c 0x3 -n 4 -- -p 0x3 -q 8 --no-mac-updating
Openssl and cryptodev details:
mglocadmin@mglocadmin$ sudo modprobe cryptodev
[sudo] password for mglocadmin:
mglocadmin@mglocadmin$ openssl version
OpenSSL 1.1.1f 31 Mar 2020
mglocadmin@mglocadmin$ ls /dev/crypto
/dev/crypto
NOTE : DPDK-L2fwd application is working
But ,I am unable to get dpdk-l2fwd-crypto to function properly on my Ubuntu 20.04 system. I've checked the dependencies, ensured that DPDK is properly configured, and attempted various troubleshooting steps, but to no avail.
ERROR log:
sudo ./dpdk-l2fwd-crypto -l 1 -n 2 --vdev "crypto_openssl0" --vdev "crypto_openssl1" -- -p 0x3 --chain CIPHER_ONLY --cdev_type SW --cipher_algo aes-cbc --cipher_op ENCRYPT --cipher_key 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --cipher_iv 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --no-mac-updating
EAL: Detected 4 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Detected static linkage of DPDK
EAL: failed to parse device "crypto_openssl0"
EAL: Unable to parse device 'crypto_openssl0'
EAL: Error - exiting with code: 1
Cause: Invalid EAL arguments
kindly help us to resolve this issue.
yipingwang
After configuring PKG_CONFIG_PATH, you need to recompiling DPDK with "meson arm64-build" command.
For details, please refer to section "Compiling DPDK using meson" in LSDK 21.08 user manual.
yipingwang
Can you please check whether DPDK is being compiled with "openssl" library.
Below path is must to compile DPDK with openssl:
export PKG_CONFIG_PATH=<OpenSSL lib path>/lib/pkgconfig:$PKG_CONFIG_PATH
Please refer to the following line in flexbuild_lsdk2108_github/packages/apps/networking/dpdk.mk
export PKG_CONFIG_PATH=$(DESTDIR)/usr/local/lib/pkgconfig:$(PKG_CONFIG_PATH) && \
sheikfaaruk
Thank you for reply @yipingwang ...
But I was tried to build and run dpdk-l2fwd-crypto application in PC .so I am directly install DPDK not with flex-builder.
Is there any configuration in DPDK i need to change or modify for enable openssl ?
yipingwang
As I mentioned previously, please execute the following before building DPDK.
sheikfaaruk
The step which i followed is below :
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08$ export PKG_CONFIG_PATH=/usr/local/ssl/lib/pkgconfig:$PKG_CONFIG_PATH
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08$ cd build/
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build$ sudo ninja install
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build$ cd examples/
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ sudo modprobe cryptodev
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ ls /dev/crypto
/dev/crypto
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ openssl engine
(rdrand) Intel RDRAND engine
(dynamic) Dynamic engine loading support
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ sudo ./dpdk-l2fwd-crypto -l 1 -n 2 --vdev "crypto_openssl0" --vdev "crypto_openssl1" -- -p 0x3 --chain CIPHER_ONLY --cdev_type SW --cipher_algo aes-cbc --cipher_op ENCRYPT --cipher_key 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --cipher_iv 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --no-mac-updating
Still same issue @yipingwang
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-1854492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIssue%20with%20dpdk-l2fwd-crypto%20Application%20SW%20on%20Ubuntu%2020.04%20PC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20testing%20dpdk%20application%20in%20PC%20with%20PCI-E%20Dual-RJ45%20gigabit%20NIC%20card%20to%20develop%20a%20network%20based%20application.%20I%20have%20started%20my%20project%20with%20dpdk%2021.08%20and%20Codewarrior%20IDE.%3C%2FP%3E%3CP%3E%3CSTRONG%3EPC%20details%20%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Euname%20-a%3CBR%20%2F%3ELinux%20mglocadmin-ThinkCentre-M73%205.15.0-105-generic%20%23115~20.04.1-Ubuntu%20SMP%20Mon%20Apr%2015%2017%3A33%3A04%20UTC%202024%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CP%3E%3CSTRONG%3EThe%20following%20steps%20to%20install%20DPDK%20(Data%20Plane%20Development%20Kit)%20on%20Ubuntu%2020.04%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3Esudo%20apt%20update%3CBR%20%2F%3Esudo%20apt%20install%20build-essential%20meson%20python3-pyelftools%20libnuma-dev%20pkgconf%3CBR%20%2F%3Ewget%20%3CA%20href%3D%22https%3A%2F%2Ffast.dpdk.org%2Frel%2Fdpdk-21.08.tar.xz%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Ffast.dpdk.org%2Frel%2Fdpdk-21.08.tar.xz%3C%2FA%3E%3CBR%20%2F%3Etar%20-xf%20dpdk-21.08.tar.xz%3CBR%20%2F%3Emeson%20build%3CBR%20%2F%3Eninja%20-C%20build%3CBR%20%2F%3Emeson%20-Dexamples%3Dall%20build%3CBR%20%2F%3Esudo%20ninja%20install%3CBR%20%2F%3Esudo%20ldconfig%3C%2FP%3E%3CP%3E%3CSTRONG%3ESetup%20hugepage%20in%20PC%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Emkdir%20-p%20%2Fdev%2Fhugepages%3CBR%20%2F%3Emountpoint%20-q%20%2Fdev%2Fhugepages%20%7C%7C%20mount%20-t%20hugetlbfs%20nodev%20%2Fdev%2Fhugepages%3CBR%20%2F%3Eecho%2064%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fnode%2Fnode0%2Fhugepages%2Fhugepages-2048kB%2Fnr_hugepages%3C%2FP%3E%3CP%3E%3CSTRONG%3ESetup%20NIC%20card%20in%20PC%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Esudo%20ifconfig%20enp2s0f1%20down%3CBR%20%2F%3Esudo%20ifconfig%20enp2s0f0%20down%3C%2FP%3E%3CP%3Ecd%20%2F%3CPATH%3E%2Fdpdk-21.08%2Fusertools%2F%3CBR%20%2F%3Esudo%20modprobe%20uio%3CBR%20%2F%3Esudo%20modprobe%20uio_pci_generic%3CBR%20%2F%3Esudo%20dpdk-devbind.py%20-b%20uio_pci_generic%2002%3A00.0%3CBR%20%2F%3Esudo%20dpdk-devbind.py%20-b%20uio_pci_generic%2002%3A00.1%3CBR%20%2F%3Edpdk-devbind.py%20-s%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3ELog%20%22dpdk-devbind.py%20-s%22%3A%3C%2FSTRONG%3E%3CBR%20%2F%3ENetwork%20devices%20using%20DPDK-compatible%20driver%3CBR%20%2F%3E0000%3A02%3A00.0%20'82571EB%2F82571GB%20Gigabit%20Ethernet%20Controller%20D0%2FD1%20(copper%20applications)%20105e'%20drv%3Duio_pci_generic%20unused%3De1000e%2Cvfio-pci%3CBR%20%2F%3E0000%3A02%3A00.1%20'82571EB%2F82571GB%20Gigabit%20Ethernet%20Controller%20D0%2FD1%20(copper%20applications)%20105e'%20drv%3Duio_pci_generic%20unused%3De1000e%2Cvfio-pci%3CBR%20%2F%3ENetwork%20devices%20using%20kernel%20driver%3CBR%20%2F%3E0000%3A03%3A00.0%20'RTL8111%2F8168%2F8411%20PCI%20Express%20Gigabit%20Ethernet%20Controller%208168'%20if%3Denp3s0%20drv%3Dr8169%20unused%3Dvfio-pci%2Cuio_pci_generic%20*Active*%3CBR%20%2F%3E%3CBR%20%2F%3Ecd%20%2F%3CPATH%3E%2Fdpdk-21.08%2Fbuild%2Fexamples%3CBR%20%2F%3Esudo%20.%2Fdpdk-l2fwd%20-c%200x3%20-n%204%20--%20-p%200x3%20-q%208%20--no-mac-updating%3C%2FPATH%3E%3C%2FPATH%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EOpenssl%20and%20cryptodev%20details%3A%3C%2FSTRONG%3E%3CBR%20%2F%3Emglocadmin%40mglocadmin%24%20sudo%20modprobe%20cryptodev%3CBR%20%2F%3E%5Bsudo%5D%20password%20for%20mglocadmin%3A%3CBR%20%2F%3Emglocadmin%40mglocadmin%24%20openssl%20version%3CBR%20%2F%3EOpenSSL%201.1.1f%2031%20Mar%202020%3CBR%20%2F%3Emglocadmin%40mglocadmin%24%20ls%20%2Fdev%2Fcrypto%3CBR%20%2F%3E%2Fdev%2Fcrypto%3C%2FP%3E%3CP%3E%3CSTRONG%3ENOTE%20%3A%20DPDK-L2fwd%20application%20is%20working%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EBut%20%2CI%20am%20unable%20to%20get%20dpdk-l2fwd-crypto%20to%20function%20properly%20on%20my%20Ubuntu%2020.04%20system.%20I've%20checked%20the%20dependencies%2C%20ensured%20that%20DPDK%20is%20properly%20configured%2C%20and%20attempted%20various%20troubleshooting%20steps%2C%20but%20to%20no%20avail.%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3EERROR%20log%3A%3C%2FSTRONG%3E%3CBR%20%2F%3Esudo%20.%2Fdpdk-l2fwd-crypto%20-l%201%20-n%202%20--vdev%20%22crypto_openssl0%22%20--vdev%20%22crypto_openssl1%22%20--%20-p%200x3%20--chain%20CIPHER_ONLY%20--cdev_type%20SW%20--cipher_algo%20aes-cbc%20--cipher_op%20ENCRYPT%20--cipher_key%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--cipher_iv%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--no-mac-updating%3CBR%20%2F%3EEAL%3A%20Detected%204%20lcore(s)%3CBR%20%2F%3EEAL%3A%20Detected%201%20NUMA%20nodes%3CBR%20%2F%3EEAL%3A%20Detected%20static%20linkage%20of%20DPDK%3CBR%20%2F%3EEAL%3A%20failed%20to%20parse%20device%20%22crypto_openssl0%22%3CBR%20%2F%3EEAL%3A%20Unable%20to%20parse%20device%20'crypto_openssl0'%3CBR%20%2F%3EEAL%3A%20Error%20-%20exiting%20with%20code%3A%201%3CBR%20%2F%3ECause%3A%20Invalid%20EAL%20arguments%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3Ekindly%20help%20us%20to%20resolve%20this%20issue.%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issue%20with%20dpdk-l2fwd-crypto%20Application%20SW%20on%20Ubuntu%2020.04%20PC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20configuring%26nbsp%3BPKG_CONFIG_PATH%2C%20you%20need%20to%20recompiling%20DPDK%20with%20%22meson%20arm64-build%22%20command.%3C%2FP%3E%0A%3CP%3EFor%20details%2C%20please%20refer%20to%20section%20%22Compiling%20DPDK%20using%20meson%22%20in%20LSDK%2021.08%20user%20manual.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issue%20with%20dpdk-l2fwd-crypto%20Application%20SW%20on%20Ubuntu%2020.04%20PC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EThe%20step%20which%20i%20followed%20is%20below%20%3A%3C%2FSTRONG%3E%3CBR%20%2F%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%24%20export%20PKG_CONFIG_PATH%3D%2Fusr%2Flocal%2Fssl%2Flib%2Fpkgconfig%3A%24PKG_CONFIG_PATH%3C%2FP%3E%3CP%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%24%20cd%20build%2F%3CBR%20%2F%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%24%20sudo%20ninja%20install%3C%2FP%3E%3CP%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%24%20cd%20examples%2F%3CBR%20%2F%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24%20sudo%20modprobe%20cryptodev%3CBR%20%2F%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24%20ls%20%2Fdev%2Fcrypto%3CBR%20%2F%3E%2Fdev%2Fcrypto%3CBR%20%2F%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24%20openssl%20engine%3CBR%20%2F%3E(rdrand)%20Intel%20RDRAND%20engine%3CBR%20%2F%3E(dynamic)%20Dynamic%20engine%20loading%20support%3C%2FP%3E%3CP%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24%20sudo%20.%2Fdpdk-l2fwd-crypto%20-l%201%20-n%202%20--vdev%20%22crypto_openssl0%22%20--vdev%20%22crypto_openssl1%22%20--%20-p%200x3%20--chain%20CIPHER_ONLY%20--cdev_type%20SW%20--cipher_algo%20aes-cbc%20--cipher_op%20ENCRYPT%20--cipher_key%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--cipher_iv%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--no-mac-updating%3C%2FP%3E%3CP%3EEAL%3A%20Detected%204%20lcore(s)%3CBR%20%2F%3EEAL%3A%20Detected%201%20NUMA%20nodes%3CBR%20%2F%3EEAL%3A%20Detected%20static%20linkage%20of%20DPDK%3CBR%20%2F%3EEAL%3A%20failed%20to%20parse%20device%20%22crypto_openssl0%22%3CBR%20%2F%3EEAL%3A%20Unable%20to%20parse%20device%20'crypto_openssl0'%3CBR%20%2F%3EEAL%3A%20Error%20-%20exiting%20with%20code%3A%201%3CBR%20%2F%3ECause%3A%20Invalid%20EAL%20arguments%3C%2FP%3E%3CP%3E%3CSTRONG%3EStill%20same%20issue%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issue%20with%20dpdk-l2fwd-crypto%20Application%20SW%20on%20Ubuntu%2020.04%20PC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAs%20I%20mentioned%20previously%2C%20please%20execute%20the%20following%20before%20building%20DPDK.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eexport%20PKG_CONFIG_PATH%3D%3COPENSSL%20lib%3D%22%22%20path%3D%22%22%3E%2Flib%2Fpkgconfig%3A%24PKG_CONFIG_PATH%3C%2FOPENSSL%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issue%20with%20dpdk-l2fwd-crypto%20Application%20SW%20on%20Ubuntu%2020.04%20PC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20reply%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%26nbsp%3B...%3CBR%20%2F%3E%3CBR%20%2F%3EBut%20I%20was%20tried%20to%20build%20and%20run%20dpdk-l2fwd-crypto%20application%20in%20PC%20.so%20I%20am%20directly%20install%20DPDK%20not%20with%20flex-builder.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20any%20configuration%20in%20DPDK%20i%20need%20to%20change%20or%20modify%20for%20enable%20openssl%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Issue%20with%20dpdk-l2fwd-crypto%20Application%20SW%20on%20Ubuntu%2020.04%20PC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3ECan%20you%20please%20check%20whether%20DPDK%20is%20being%20compiled%20with%20%22openssl%22%20library.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3EBelow%20path%20is%20must%20to%20compile%20DPDK%20with%20openssl%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3Eexport%20PKG_CONFIG_PATH%3D%3COPENSSL%20lib%3D%22%22%20path%3D%22%22%3E%2Flib%2Fpkgconfig%3A%24PKG_CONFIG_PATH%3C%2FOPENSSL%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3EPlease%20refer%20to%20the%20following%20line%20in%26nbsp%3Bflexbuild_lsdk2108_github%2Fpackages%2Fapps%2Fnetworking%2Fdpdk.mk%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%3CCODE%20data-application%3D%22com.atlassian.bitbucket-server%22%20data-language%3D%22plain%20text%22%3Eexport%20PKG_CONFIG_PATH%3D%24(DESTDIR)%2Fusr%2Flocal%2Flib%2Fpkgconfig%3A%24(PKG_CONFIG_PATH)%20%26amp%3B%26amp%3B%20%5C%3C%2FCODE%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
