Hello community,
On my board, SJA1110 is configured in QSPI flash boot mode, but SJA1110 will not execute the pre-burned firmware in QSPI flash.
I couldn't use QSPI flash boot mode until I booted SJA1110 once using SDL boot mode.
What are the prerequisites for using QSPI flash boot mode for the first time? Do I need to access BootROM first?
Hello Ethan,
We understand that the local FAE and DFAE are already working on this case and will provide direct support to you.
Best regards, 99
