FS26 S32K3 FLT_ERR_CNT cannot decrease to 0 in Sbc_fs26_InitDevice();
7,845 次查看
kate___
when i initialized FS26 with S32K311,
watchdog period = 32ms, watchdog duty cycle = 37.5%OPEN, watchdog recovery = 64ms,
but in " Decrease FLT_ERR_CNT to 0 with WD_ERR_LIMIT good WD refresh",
I got u8ErrorCounter = 1 in below codes.
I don't know the meaning about "with WD_ERR_LIMIT good WD refresh", is that means it need to plus a WDrefresh routine code?
Hope your answer!
Kate
7,685 次查看
guoweisun
Finally you must use the normal mode not the debug mode,you can refer to below  for feed WD:
12 回复数
7,811 次查看
guoweisun
For your question:
1: Is that means it need to plus a WDrefresh routine code?
[gw]Correct,you need continue to refresh WD till the fault error counter decrease into 0.
7,747 次查看
kate___
Hi guoweisun,
Thanks for your reply.
How would I continue refresh WD?
If I use a timer to count, it will shut down in Sbc_fs26_TimeWaitClearFault().
Or is there a watchdog duty open example?
In S32DK, there is only a infinite watchdog example.
标记 (1)
7,744 次查看
guoweisun
You can refer to below:
Sequence to enter normal mode with a Watchdog Simple
//INIT FS and simple WD enabled required
//Open WD window
SET_REG:FS26:Safety:FS_WDW_DURATION:0x008B
SET_REG:FS26:Safety:FS_NOT_WDW_DURATION:0xF144
//Send 1 good wd refresh to close INIT window
SET_REG:FS26:Safety:FS_WD_ANSWER:0x5AB2
//clean fault error counter
//Exit dbg mode
SET_REG:FS26:Safety:FS_STATES:0x4000
//release FS0B and FS1B
SET_REG:FS26:Safety:FS_RELEASE_FS0B_FS1B:0xB2A5
Sequence to enter normal mode with a Watchdog Challenger
//INIT FS and WD Challenger required
//Open WD window
//Send 1 ZD refresh to close INIT window
SET_REG:FS26:Safety:FS_WD_ANSWER:0xa54d
SET_REG:FS26:Safety:FS_WD_ANSWER:0x4a9a
SET_REG:FS26:Safety:FS_WD_ANSWER:0x9535
SET_REG:FS26:Safety:FS_WD_ANSWER:0x2a6a
SET_REG:FS26:Safety:FS_WD_ANSWER:0x54d4
SET_REG:FS26:Safety:FS_WD_ANSWER:0xa9a9
SET_REG:FS26:Safety:FS_WD_ANSWER:0x5353
//Exit dbg mode
SET_REG:FS26:Safety:FS_RELEASE_FS0B_FS1B:0xA565
7,742 次查看
kate___
Hi guoweisun,
I used "Sequence to enter normal mode with a Watchdog Challenger" because of S32K311.
The change timing of FS_WD_ANSWER is when Sbc_fs26_WdChangeToken be used, right?
But now my code used Sbc_fs26_WdChangeToken when Sbc_fs26_InitFSConfigure is used.
That means it just one time to change the wd answer.
Where should i add Sbc_fs26_WdChangeToken to occur the wd answer changing?
标记 (1)
7,739 次查看
guoweisun
HI Kate
Don't understand you wrote only one time to change the WD.
If you define the FS_WD_TOKEN register content, you have to calculate and feed the WD answer each time.
7,735 次查看
kate___
Hi guoweisun,
Thanks for your patience!
I means what can make FS_WD_ANSWER change.
If I just refresh one time, FS_WD_ANSWER is changed from 0xa54d to 0x4a9a.
What can I  change FS_WD_ANSWER from 0x4a9a to 0x9535?
标记 (1)
7,730 次查看
guoweisun
Please see below:
7,698 次查看
kate___
Hi guoweisun,
If I was in Debug mode, I can have a good WDfresh like below.
Then I can get SBC initialize OK.
But in Normal mode, I got a bad WDfresh like below.
Then I can't initialize SBC.
What states I need to set ?
7,686 次查看
guoweisun
7,681 次查看
kate___
Hi guoweisun,
Thanks for the description!
About the pic, open duty is 50% but there is 3/4 on the timeline.
To my understanding, if it set 50% duty , it will be 1/2 between WD refresh and WD refresh 1.
That is, if I want to set the time between WD refresh and WD refresh 1, the function must be WindowPeriod * WindowDc.
Above all, is there something wrong?
标记 (1)
7,678 次查看
guoweisun
Hi Kate
Please following the above picture to feed WD,you can try and should be no problem.
7,655 次查看
kate___
Thanks a lot !
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1840103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%8F%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1840103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E7%94%A8S32K311%E5%88%9D%E5%A7%8B%E5%8C%96FS26%E6%97%B6%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%9C%8B%E9%97%A8%E7%8B%97%E5%91%A8%E6%9C%9F%3D32ms%EF%BC%8C%E7%9C%8B%E9%97%A8%E7%8B%97%E5%8D%A0%E7%A9%BA%E6%AF%94%3D37.5%25OPEN%EF%BC%8C%E7%9C%8B%E9%97%A8%E7%8B%97%E6%81%A2%E5%A4%8D%3D64ms%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%E2%80%9C%E4%BD%BF%E7%94%A8%20WD_ERR_LIMIT%20%E5%B0%86%20FLT_ERR_CNT%20%E5%87%8F%E5%B0%91%E5%88%B0%200%20%E8%89%AF%E5%A5%BD%E7%9A%84%20WD%20%E5%88%B7%E6%96%B0%E2%80%9D%E4%B8%AD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%BE%97%E5%88%B0%E4%BA%86%20u8ErrorCounter%20%3D%201%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____0-1712135589491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____0-1712135589491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F271788iE6D384A31046ED70%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____0-1712135589491.png%22%20alt%3D%22kate____0-1712135589491.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E2%80%9C%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E%E7%94%A8WD_ERR_LIMIT%E5%81%9A%E5%A5%BDWD%E5%88%B7%E6%96%B0%3C%2FSTRONG%3E%3C%2FFONT%3E%E2%80%9D%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%8C%E6%98%AF%E4%B8%8D%E6%98%AF%E6%84%8F%E5%91%B3%E7%9D%80%E9%9C%80%E8%A6%81%E5%8A%A0%E4%B8%8A%E4%B8%80%E4%B8%AAWDrefresh%E4%BE%8B%E7%A8%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____1-1712135731347.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____1-1712135731347.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F271789i96F7E51952620D8F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____1-1712135731347.png%22%20alt%3D%22kate____1-1712135731347.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%BE%97%E5%88%B0%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%87%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%9A%E8%B0%A2%20%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%87%AF%E7%89%B9%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%8C%89%E7%85%A7%E4%B8%8A%E5%9B%BE%E7%BB%99WD%E5%96%82%E9%A3%9F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20guoweisun%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%8F%8F%E8%BF%B0%EF%BC%81%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E5%9B%BE%E7%89%87%EF%BC%8C%E5%BC%80%E6%94%BE%E4%BB%BB%E5%8A%A1%E6%98%AF%2050%25%EF%BC%8C%E4%BD%86%E6%97%B6%E9%97%B4%E7%BA%BF%E4%B8%8A%E6%9C%89%203%2F4%E3%80%82%3C%2FP%3E%3CP%3E%E6%8D%AE%E6%88%91%E4%BA%86%E8%A7%A3%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%AE%BE%E7%BD%AE%E4%BA%86%2050%25%20%E5%8D%A0%E7%A9%BA%E6%AF%94%EF%BC%8C%E9%82%A3%E4%B9%88%20WD%20%E5%88%B7%E6%96%B0%E5%92%8C%20WD%20%E5%88%B7%E6%96%B0%201%20%E4%B9%8B%E9%97%B4%E7%9A%84%E5%8D%A0%E6%AF%94%E5%B0%86%E6%98%AF%201%2F2%E3%80%82%3C%2FP%3E%3CP%3E%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E6%83%B3%E8%AE%BE%E7%BD%AEWD%E5%88%B7%E6%96%B0%E5%92%8CWD%E5%88%B7%E6%96%B01%E4%B9%8B%E9%97%B4%E7%9A%84%E6%97%B6%E9%97%B4%EF%BC%8C%E9%82%A3%E4%B9%88%E5%87%BD%E6%95%B0%E5%BF%85%E9%A1%BB%E6%98%AF%3CSTRONG%3EWindowPeriod%20*%20WindowDc%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E9%87%8D%E8%A6%81%E7%9A%84%E6%98%AF%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E4%B8%8D%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E8%80%8C%E4%B8%8D%E6%98%AF%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%9C%89%E5%85%B3%20feed%20WD%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1712645513182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1712645513182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272680iEF0E54D58F63008F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1712645513182.png%22%20alt%3D%22guoweisun_0-1712645513182.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20guoweisun%2C%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%A4%84%E4%BA%8E%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E7%9A%84%E8%89%AF%E5%A5%BD%20WDfresh%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%B1%E5%8F%AF%E4%BB%A5%E8%AE%A9%20SBC%20%E5%88%9D%E5%A7%8B%E5%8C%96%20OK%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____0-1712633757777.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____0-1712633757777.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272628iA85001228F999C2C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____0-1712633757777.png%22%20alt%3D%22kate____0-1712633757777.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E7%9A%84%E9%94%99%E8%AF%AF%20WDfresh%E3%80%82%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E6%88%91%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%20SBC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____1-1712633851918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____1-1712633851918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272630i5D37442EDAE39C05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____1-1712633851918.png%22%20alt%3D%22kate____1-1712633851918.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%E4%BB%80%E4%B9%88%E7%8A%B6%E6%80%81%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%8F%82%E8%A7%81%E4%B8%8B%E6%96%87%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1712565103610.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1712565103610.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272469iC26FD74CABD6635B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1712565103610.png%22%20alt%3D%22guoweisun_0-1712565103610.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3Eguoweisun%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E4%BB%80%E4%B9%88%E5%8F%AF%E4%BB%A5%E4%BD%BF%20FS_WD_ANSWER%20%E5%8F%91%E7%94%9F%E6%94%B9%E5%8F%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%8F%AA%E5%88%B7%E6%96%B0%E4%B8%80%E6%AC%A1%EF%BC%8CFS_WD_ANSWER%20%E5%B0%B1%E4%BC%9A%E4%BB%8E%3CSPAN%3E0xa54d%3C%2FSPAN%3E%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSPAN%3E0x4a9a%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%20FS_WD_ANSWER%20%E4%BB%8E%200x4a9a%20%E6%9B%B4%E6%94%B9%E4%B8%BA%200x9535%20%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%87%AF%E7%89%B9%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E6%98%8E%E7%99%BD%E4%BD%A0%E5%8F%AA%E5%86%99%E4%BA%86%E4%B8%80%E6%AC%A1%E6%9D%A5%E6%94%B9%E5%8F%98%20WD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%AE%9A%E4%B9%89%20FS_WD_TOKEN%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%86%85%E5%AE%B9%EF%BC%8C%E5%88%99%E6%AF%8F%E6%AC%A1%E9%83%BD%E5%BF%85%E9%A1%BB%E8%AE%A1%E7%AE%97%E5%B9%B6%E8%BE%93%E5%85%A5%20WD%20%E7%AD%94%E6%A1%88%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3Eguoweisun%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%94%B1%E4%BA%8E%20S32K311%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E2%80%9C%3CU%3E%E9%80%9A%E8%BF%87%E7%9C%8B%E9%97%A8%E7%8B%97%E6%8C%91%E6%88%98%20r%20%E8%BF%9B%E5%85%A5%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E7%9A%84%E5%BA%8F%E5%88%97%3C%2FU%3E%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3EFS_WD_ANSWER%3C%2FSTRONG%3E%E7%9A%84%E5%8F%98%E5%8C%96%E6%97%B6%E6%9C%BA%E6%98%AF%E4%BD%BF%E7%94%A8%3CSTRONG%3ESbc_fs26_WdChangeToken%3C%2FSTRONG%3E%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%E7%8E%B0%E5%9C%A8%E5%BD%93%E4%BD%BF%E7%94%A8%3CSTRONG%3ESbc_fs26_InitFSConfigure%3C%2FSTRONG%3E%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%E4%BA%86%3CSTRONG%3ESbc_fs26_WdChangeToken%3C%2FSTRONG%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%8F%AA%E9%9C%80%E6%9B%B4%E6%94%B9%E4%B8%80%E6%AC%A1%20wd%20%E7%AD%94%E6%A1%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E6%B7%BB%E5%8A%A0%3CSTRONG%3ESbc_fs26_WdChangeToken%3C%2FSTRONG%3E%E4%BB%A5%E4%BD%BF%20wd%20%E7%AD%94%E6%A1%88%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E7%9C%8B%E9%97%A8%E7%8B%97%E7%AE%80%E5%8D%95%E8%BF%9B%E5%85%A5%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E7%9A%84%E5%BA%8F%E5%88%97%3CBR%20%2F%3E%2F%2F%E9%9C%80%E8%A6%81%E5%90%AF%E7%94%A8%20INIT%20FS%20%E5%92%8C%E7%AE%80%E5%8D%95%20WD%3CBR%20%2F%3E%20%2F%2F%E6%89%93%E5%BC%80WD%E7%AA%97%E5%8F%A3%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WDW_DURATION%3A0x008B%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_NOT_WDW_DURATION%3A0xF144%3CBR%20%2F%3E%20%2F%2F%E5%8F%91%E9%80%811%E4%B8%AA%E5%A5%BD%E7%9A%84wd%E5%88%B7%E6%96%B0%E6%9D%A5%E5%85%B3%E9%97%ADINIT%E7%AA%97%E5%8F%A3%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20%2F%2F%E6%B8%85%E9%99%A4%E6%95%85%E9%9A%9C%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3E%20%2F%2F%E9%80%80%E5%87%BAdbg%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_STATES%3A0x4000%3CBR%20%2F%3E%20%2F%2F%E9%87%8A%E6%94%BE%20FS0B%20%E5%92%8C%20FS1B%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_RELEASE_FS0B_FS1B%3A0xB2A5%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20Watchdog%20Challenger%20%E8%BF%9B%E5%85%A5%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E7%9A%84%E9%A1%BA%E5%BA%8F%3CBR%20%2F%3E%2F%2F%E9%9C%80%E8%A6%81%20INIT%20FS%20%E5%92%8C%20WD%20Challenger%3CBR%20%2F%3E%20%2F%2F%E6%89%93%E5%BC%80WD%E7%AA%97%E5%8F%A3%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WDW_DURATION%3A0x008B%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_NOT_WDW_DURATION%3A0xF144%3CBR%20%2F%3E%20%2F%2F%E5%8F%91%E9%80%811%E4%B8%AAZD%E5%88%B7%E6%96%B0%E5%85%B3%E9%97%ADINIT%E7%AA%97%E5%8F%A3%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0xa54d%3CBR%20%2F%3E%20%2F%2F%E6%B8%85%E9%99%A4%E6%95%85%E9%9A%9C%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x4a9a%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x9535%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x2a6a%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x54d4%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0xa9a9%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_WD_ANSWER%3A0x5353%3CBR%20%2F%3E%20%2F%2F%E9%80%80%E5%87%BAdbg%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_STATES%3A0x4000%3CBR%20%2F%3E%20%2F%2F%E9%87%8A%E6%94%BE%20FS0B%20%E5%92%8C%20FS1B%3CBR%20%2F%3E%20SET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%3AFS_RELEASE_FS0B_FS1B%3A0xA565%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3Eguoweisun%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E7%BB%A7%E7%BB%AD%3CSPAN%3E%E5%88%B7%E6%96%B0%20WD%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E8%BF%9B%E8%A1%8C%E8%AE%A1%E6%95%B0%EF%BC%8C%E5%AE%83%E5%B0%86%E5%9C%A8%20Sbc_fs26_TimeWaitClearFault()%20%E4%B8%AD%E5%85%B3%E9%97%AD%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E6%88%96%E8%80%85%E6%9C%89%E7%9B%91%E7%9D%A3%E8%81%8C%E8%B4%A3%E5%BC%80%E6%94%BE%E7%9A%84%E4%BE%8B%E5%AD%90%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E5%9C%A8S32DK%E4%B8%AD%EF%BC%8C%E5%8F%AA%E6%9C%89%E4%B8%80%E4%B8%AA%E6%97%A0%E9%99%90%E7%9C%8B%E9%97%A8%E7%8B%97%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1841545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFS26%20S32K3%20FLT_ERR_CNT%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Sbc_fs26_InitDevice()%20%E4%B8%AD%E5%87%8F%E5%B0%91%E5%88%B0%200%EF%BC%9B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%EF%BC%9A%E6%98%AF%E4%B8%8D%E6%98%AF%E6%84%8F%E5%91%B3%E7%9D%80%E9%9C%80%E8%A6%81%E5%8A%A0%E4%B8%80%E4%B8%AAWDrefresh%E4%BE%8B%E7%A8%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%5Bgw%5D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E7%BB%A7%E7%BB%AD%E5%88%B7%E6%96%B0WD%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%95%85%E9%9A%9C%E9%94%99%E8%AF%AF%E8%AE%A1%E6%95%B0%E5%99%A8%E5%87%8F%E5%B0%91%E5%88%B00%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
