FS26 S32K3 FLT_ERR_CNT cannot decrease to 0 in Sbc_fs26_InitDevice();
7,764件の閲覧回数
kate___
when i initialized FS26 with S32K311,
watchdog period = 32ms, watchdog duty cycle = 37.5%OPEN, watchdog recovery = 64ms,
but in " Decrease FLT_ERR_CNT to 0 with WD_ERR_LIMIT good WD refresh",
I got u8ErrorCounter = 1 in below codes.
I don't know the meaning about "with WD_ERR_LIMIT good WD refresh", is that means it need to plus a WDrefresh routine code?
Hope your answer!
Kate
7,604件の閲覧回数
guoweisun
Finally you must use the normal mode not the debug mode,you can refer to below  for feed WD:
12 返答(返信)
7,730件の閲覧回数
guoweisun
For your question:
1: Is that means it need to plus a WDrefresh routine code?
[gw]Correct,you need continue to refresh WD till the fault error counter decrease into 0.
7,666件の閲覧回数
kate___
Hi guoweisun,
Thanks for your reply.
How would I continue refresh WD?
If I use a timer to count, it will shut down in Sbc_fs26_TimeWaitClearFault().
Or is there a watchdog duty open example?
In S32DK, there is only a infinite watchdog example.
タグ(1)
7,663件の閲覧回数
guoweisun
You can refer to below:
Sequence to enter normal mode with a Watchdog Simple
//INIT FS and simple WD enabled required
//Open WD window
SET_REG:FS26:Safety:FS_WDW_DURATION:0x008B
SET_REG:FS26:Safety:FS_NOT_WDW_DURATION:0xF144
//Send 1 good wd refresh to close INIT window
SET_REG:FS26:Safety:FS_WD_ANSWER:0x5AB2
//clean fault error counter
//Exit dbg mode
SET_REG:FS26:Safety:FS_STATES:0x4000
//release FS0B and FS1B
SET_REG:FS26:Safety:FS_RELEASE_FS0B_FS1B:0xB2A5
Sequence to enter normal mode with a Watchdog Challenger
//INIT FS and WD Challenger required
//Open WD window
//Send 1 ZD refresh to close INIT window
SET_REG:FS26:Safety:FS_WD_ANSWER:0xa54d
SET_REG:FS26:Safety:FS_WD_ANSWER:0x4a9a
SET_REG:FS26:Safety:FS_WD_ANSWER:0x9535
SET_REG:FS26:Safety:FS_WD_ANSWER:0x2a6a
SET_REG:FS26:Safety:FS_WD_ANSWER:0x54d4
SET_REG:FS26:Safety:FS_WD_ANSWER:0xa9a9
SET_REG:FS26:Safety:FS_WD_ANSWER:0x5353
//Exit dbg mode
SET_REG:FS26:Safety:FS_RELEASE_FS0B_FS1B:0xA565
7,661件の閲覧回数
kate___
Hi guoweisun,
I used "Sequence to enter normal mode with a Watchdog Challenger" because of S32K311.
The change timing of FS_WD_ANSWER is when Sbc_fs26_WdChangeToken be used, right?
But now my code used Sbc_fs26_WdChangeToken when Sbc_fs26_InitFSConfigure is used.
That means it just one time to change the wd answer.
Where should i add Sbc_fs26_WdChangeToken to occur the wd answer changing?
タグ(1)
7,658件の閲覧回数
guoweisun
HI Kate
Don't understand you wrote only one time to change the WD.
If you define the FS_WD_TOKEN register content, you have to calculate and feed the WD answer each time.
7,654件の閲覧回数
kate___
Hi guoweisun,
Thanks for your patience!
I means what can make FS_WD_ANSWER change.
If I just refresh one time, FS_WD_ANSWER is changed from 0xa54d to 0x4a9a.
What can I  change FS_WD_ANSWER from 0x4a9a to 0x9535?
タグ(1)
7,649件の閲覧回数
guoweisun
Please see below:
7,617件の閲覧回数
kate___
Hi guoweisun,
If I was in Debug mode, I can have a good WDfresh like below.
Then I can get SBC initialize OK.
But in Normal mode, I got a bad WDfresh like below.
Then I can't initialize SBC.
What states I need to set ?
7,605件の閲覧回数
guoweisun
7,600件の閲覧回数
kate___
Hi guoweisun,
Thanks for the description!
About the pic, open duty is 50% but there is 3/4 on the timeline.
To my understanding, if it set 50% duty , it will be 1/2 between WD refresh and WD refresh 1.
That is, if I want to set the time between WD refresh and WD refresh 1, the function must be WindowPeriod * WindowDc.
Above all, is there something wrong?
タグ(1)
7,597件の閲覧回数
guoweisun
Hi Kate
Please following the above picture to feed WD,you can try and should be no problem.
7,574件の閲覧回数
kate___
Thanks a lot !
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1840103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%20%E3%81%A7%200%20%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1840103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EFS26%E3%82%92S32K311%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E5%91%A8%E6%9C%9F%3D32ms%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3D37.5%25OPEN%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%BC%3D64ms%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%80%8C%E8%89%AF%E3%81%84WD%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7FLT_ERR_CNT%E3%82%920%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%80%8DWD_ERR_LIMIT%E3%80%81%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7u8ErrorCounter%20%3D%201%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____0-1712135589491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____0-1712135589491.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F271788iE6D384A31046ED70%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____0-1712135589491.png%22%20alt%3D%22kate____0-1712135589491.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekate____0-1712135589491.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%80%8C%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E%E8%89%AF%E3%81%84WD%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%3C%2FSTRONG%3E%3C%2FFONT%3E%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8CWD_ERR_LIMIT%E3%81%9D%E3%82%8C%E3%81%AFWDrefresh%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____1-1712135731347.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____1-1712135731347.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F271789i96F7E51952620D8F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____1-1712135731347.png%22%20alt%3D%22kate____1-1712135731347.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekate____1-1712135731347.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%AD%94%E3%81%88%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B1%E3%82%A4%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1843838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1843838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B1%E3%82%A4%E3%83%88%3C%2FP%3E%0A%3CP%3E%E4%B8%8A%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6WD%E3%82%92%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20guoweisun%2C%3C%2FP%3E%3CP%3E%E8%AA%AC%E6%98%8E%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FP%3E%3CP%3E%E5%86%99%E7%9C%9F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%BC%E3%81%AF50%25%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF3%2F4%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%8150%25%E3%81%AE%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81WD%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A8WD%E3%83%AA%E3%83%95%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A51%E3%81%AE%E9%96%93%E3%81%AE1%2F2%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81WD%20refresh%20%E3%81%A8%20WD%20refresh%201%20%E3%81%AE%E9%96%93%E3%81%AE%E6%99%82%E9%96%93%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E9%96%A2%E6%95%B0%E3%81%AF%20%3CSTRONG%3EWindowPeriod%20*%20WindowDc%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%82%88%E3%82%8A%E3%82%82%E3%80%81%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89WD%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1712645513182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1712645513182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272680iEF0E54D58F63008F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1712645513182.png%22%20alt%3D%22guoweisun_0-1712645513182.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eguoweisun_0-1712645513182.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842841%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20guoweisun%2C%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%89%AF%E3%81%84WDfresh%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81SBC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92OK%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____0-1712633757777.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____0-1712633757777.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272628iA85001228F999C2C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____0-1712633757777.png%22%20alt%3D%22kate____0-1712633757777.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekate____0-1712633757777.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%82%AA%E3%81%84WDfresh%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81SBC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kate____1-1712633851918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kate____1-1712633851918.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272630i5D37442EDAE39C05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kate____1-1712633851918.png%22%20alt%3D%22kate____1-1712633851918.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekate____1-1712633851918.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%85%8B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1712565103610.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1712565103610.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F272469iC26FD74CABD6635B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1712565103610.png%22%20alt%3D%22guoweisun_0-1712565103610.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eguoweisun_0-1712565103610.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3Eguoweisun%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%81%94%E8%BE%9B%E6%8A%B1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E4%BD%95%E3%81%8CFS_WD_ANSWER%E3%82%92%E5%A4%89%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E1%E5%9B%9E%E3%81%A0%E3%81%91%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81FS_WD_ANSWER%20%3CSPAN%3E0xa54d%3C%2FSPAN%3E%20%E3%81%8B%E3%82%890x4a9a%E3%81%AB%E5%A4%89%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3EFS_WD_ANSWER%200x4a9a%E3%81%8B%E3%82%890x9535%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B1%E3%82%A4%E3%83%88%3C%2FP%3E%0A%3CP%3EWD%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%B8%80%E5%BA%A6%E3%81%A0%E3%81%91%E6%9B%B8%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EFS_WD_TOKEN%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AF%8E%E5%9B%9EWD%E3%81%AE%E5%9B%9E%E7%AD%94%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%A6%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3Eguoweisun%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%80%8C%3CU%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%83%81%E3%83%A3%E3%83%AC%E3%83%B3%E3%82%B8r%E3%81%A7%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%3C%2FU%3E%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81S32K311%E3%81%AE%E3%81%9F%E3%82%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3EFS_WD_ANSWER%3C%2FSTRONG%3E%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AF%E3%80%81%3CSTRONG%3ESbc_fs26_WdChangeToken%3C%2FSTRONG%3E%E3%81%8C%E4%BD%BF%E3%82%8F%E3%82%8C%E3%82%8B%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%A7%E3%81%AF%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%3CSTRONG%3ESbc_fs26_InitFSConfigure%3C%2FSTRONG%3E%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%3CSTRONG%3ESbc_fs26_WdChangeToken%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81wd%E3%81%AE%E7%AD%94%E3%81%88%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF1%E5%9B%9E%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewd%E3%81%AE%E7%AD%94%E3%81%88%E3%81%8C%E5%A4%89%E3%82%8F%E3%82%8B%20%3CSTRONG%3ESbc_fs26_WdChangeToken%3C%2FSTRONG%3E%E3%82%92%E3%81%A9%E3%81%93%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%3CBR%20%2F%3EINIT%20FS%E3%81%8A%E3%82%88%E3%81%B3Simple%20WD%E5%AF%BE%E5%BF%9C%E3%81%8C%E5%BF%85%E8%A6%81%3CBR%20%2F%3EWD%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%8B%E3%81%8F%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WDW_DURATION%3A0x008B%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_NOT_WDW_DURATION%3A0xF144%3CBR%20%2F%3E1%20%E5%9B%9E%E9%81%A9%E5%88%87%E3%81%AA%20wd%20refresh%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%20INIT%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3EClean%20Fault%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5AB2%3CBR%20%2F%3Edbg%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_STATES%3A0x4000%3CBR%20%2F%3EFS0B%E3%81%8A%E3%82%88%E3%81%B3FS1B%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_RELEASE_FS0B_FS1B%3A0xB2A5%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%83%81%E3%83%A3%E3%83%AC%E3%83%B3%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%A7%E3%83%8E%E3%83%BC%E3%83%9E%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%3CBR%20%2F%3EINIT%20FS%E3%81%8A%E3%82%88%E3%81%B3WD%20Challenger%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3CBR%20%2F%3EWD%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%8B%E3%81%8F%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WDW_DURATION%3A0x008B%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_NOT_WDW_DURATION%3A0xF144%3CBR%20%2F%3EZD%20refresh%20%E3%82%92%201%20%E5%9B%9E%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%20INIT%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0xa54d%3CBR%20%2F%3EClean%20Fault%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x4a9a%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x9535%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x2a6a%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x54d4%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0xa9a9%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_WD_ANSWER%3A0x5353%3CBR%20%2F%3Edbg%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_STATES%3A0x4000%3CBR%20%2F%3EFS0B%E3%81%8A%E3%82%88%E3%81%B3FS1B%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3CBR%20%2F%3ESET_REG%3AFS26%3A%E5%AE%89%E5%85%A8%E6%80%A7%3AFS_RELEASE_FS0B_FS1B%3A0xA565%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%20class%3D%22%22%3Eguoweisun%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3EWD%E3%81%AE%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%E3%82%92%E7%B6%9A%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Sbc_fs26_TimeWaitClearFault()%E3%81%A7%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%81%AA%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3ES32DK%E3%81%AB%E3%81%AF%E3%80%81%E7%84%A1%E9%99%90%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%AE%E4%BE%8B%E3%81%97%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1841545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AFS26%20S32K3%20FLT_ERR_CNT%20Sbc_fs26_InitDevice()%E3%81%A70%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%3A%E3%81%9D%E3%82%8C%E3%81%AFWDrefresh%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%5BGW%E3%81%AE%5D%E6%AD%A3%E3%81%97%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%9A%9C%E5%AE%B3%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%8C0%E3%81%AB%E6%B8%9B%E5%B0%91%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7WD%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E7%B6%9A%E3%81%91%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
