Extract firmware
Extract firmware
2,163 次查看
KhangVA
Dear all,
I wanna extract firmware from MK60FN1M0VLQ12. But I can not find solution.
Can anyone help me. Thanks all!
2,120 次查看
PabloAvalos
Hi @KhangVA
Thank you so much for using our community, and thanks a lot for your patience. We have some backlog on the requests.
Regarding what you are asking for, if that mcu is bricked or has the firmware assured you won't be able to extract the firmware from that, otherwise, if chip is new and it is yours, please let me know which debugger and software you are using for so I could help you.
Please let me know any update and your comments. Of course if you have more questions, I will be more than happy to assist you.
Thank you in advance.
Best Regards.
Pablo Avalos.
2,083 次查看
KhangVA
Dear,
Chip on board still active and run as picture below.z3531732940676_5f2e8bc2b71c60720add866d29b1a009.jpg
2,080 次查看
PabloAvalos
Hi @KhangVA
Thanks for sharing.
In order to help you, may I know which debug interface and software you are using to extract the firmware from your chip? And as I see, you are using a custom board, so please I would like to suggest you to check very well your hardware to be able to flash and extract firmware from your mcu.
Please let me know if you have more questions.
Best Regards.
Pablo Avalos.
