Error with MCIMX31 Flash Programming using Advance Toolkit Ver 1.6 Source Code
1,788 次查看
maria_m
Hello Everyone,
I have two version of Advance Toolkit, 1.4 and 1.6 (source code). Erase and Programming flash has no problem with ver1.4. Did anyone experience having error when programming flash with version1.6(source code)?
Really need your help with this.
Thank you in advance,
Maria
1,093 次查看
fabio_estevam
I have used ATK1.6 with MX31 and it worked fine. Make sure you are selecting the correct MX31 silicon version in the 'i.MX CPU' window.
Fabio Estevam
