Does MPC8548 support 4G or larger memory? How can I config MMU!
Plutus
As I know ,there are 36 address lines on MPC8548.
How can I use 4G or larger memory ?
Thank you!
genuap
Can you clarify what you're trying to do? Do you want to have > 4Gig of DDR on a single Chip Select? Or do you want to have two chip selects each ~3Gig. Or are you just asking in general if the part support > 4Gig memory (i.e. 2 gig on local bus, and 3 on DDR)
