EB tresos issue - module cannot be installed
3,295 次查看
Yang_C
Hi all,
I have a problem with EB tresos, hope someone can give some hints. Thank you in advance.
I want to open a project on EB, the EB version i am using is 27.1.0. When I tried to open the module, an error pop up as below, it says Eth_43_PFE_TS_T40D11M12I0R0 is not installed:
I understanding when installing the EB tresos, I should link to the RTD folder, I indeed did:
Besides, I also cope paste the Eth_43_PFE_TS_T40D11M12I0R0 to RTD folder and EB plugins folder:
All the above actions make no difference, the error stays.
Do I miss some setup?
BR,
Yang
7 回复数
3,228 次查看
alejandro_e
Hello @Yang_C,
Sorry for the late reply. everything seems to be correct as you mentioned. Please help me with the following test:
  • Can you try opening one of the examples present in the PFE-DRV_S32G_M7_MCAL_1.2.0.\example_application folder? to check if you can open those projects without problems.
  • Remove the link file and use only the copied plugins in the Tresos directory. The S32G MCAL Driver Release Notes for version 1.2.0 mention the installation methods as mutually exclusive:
Let me know if you can open the example projects or if removing the link file changes de behavior for your project.
3,220 次查看
Yang_C
Hi alejandro_e,
Thank you for your reply.
Let me answer the result one by one.
  - Tried, didn't work, still the Eth module not installed
I also downloaded PFE-DRV_S32G_M7_MCAL_1.4.0 and tried opening one of the example projects in PFE-DRV_S32G_M7_MCAL_1.4.0, it works, either the Eth module is in NXP/RTD folder or in EB/tresos/plugins folder, both ways can open the project without any problems.
BR,
Yang
3,057 次查看
alejandro_e
Hello @Yang_C,
Sorry for the late reply. I tried to reproduce the issue on my side, however I was not able to do so. I copied the plugins and created the link file, I also copied the two PFE drivers versions you are using, 1.2.0 and 1.4.0. Can you run the following powershell command in C:\EB\tresos27\plugins andC:\NXP\SW32G_RTD_4.4_4.0.2_HF03\eclipse\plugins:
> Get-ChildItem -Depth 0
Here is the output from my setup:
PS C:\EB\tresos27\plugins> Get-ChildItem -Depth 0
    Directory: C:\EB\tresos27\plugins
Mode                 LastWriteTime         Length Name
d-----     15/12/2025  02:23 p. m.                Adc_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                BaseNXP_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                CanIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Can_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Crc_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                CryIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Crypto_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Csm_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Dem_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Det_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Dio_TS_T40D11M40I2R0
d-----     30/01/2025  04:42 p. m.                dreisoft.tresos.fibeximporter
d-----     30/01/2025  04:42 p. m.                dreisoft.tresos.generator.ng.api
d-----     15/12/2025  02:24 p. m.                EcuC_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                EcuM_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Eep_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                EthIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                EthSwt_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                EthTrcv_TS_T40D11M40I2R0
d-----     15/12/2025  02:35 p. m.                Eth_43_PFE_TS_T40D11M12I0R0
d-----     15/12/2025  03:04 p. m.                Eth_43_PFE_TS_T40D11M14I0R0
d-----     15/12/2025  02:24 p. m.                Eth_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Fee_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Fls_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                FrIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Fr_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Gpt_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                I2c_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Icu_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                LinIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Lin_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Mcl_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Mcu_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                MemIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Ocotp_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Ocu_TS_T40D11M40I2R0
d-----     30/01/2025  04:42 p. m.                org.apache.ant_1.9.6.v201510161327
d-----     30/01/2025  04:42 p. m.                org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.401.v20161122-1740
d-----     30/01/2025  04:42 p. m.                org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.401.v20161122-1740
d-----     30/01/2025  04:42 p. m.                org.eclipse.jdt.debug_3.10.1.v20160811-0441
d-----     30/01/2025  04:42 p. m.                org.eclipse.pde.build_3.9.200.v20160204-0642
d-----     30/01/2025  04:42 p. m.                org.eclipse.ui.themes_1.1.300.v20161107-1827
d-----     15/12/2025  02:24 p. m.                Os_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Pcie_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Platform_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Pmic_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Port_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Pwm_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Qdec_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Resource_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Rm_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Rte_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Serdes_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Spi_TS_T40D11M40I2R0
d-----     15/12/2025  02:24 p. m.                Thermal_TS_T40D11M40I2R0
d-----     15/12/2025  02:23 p. m.                Uart_TS_T40D11M40I2R0
d-----     15/12/2025  02:23 p. m.                WdgIf_TS_T40D11M40I2R0
d-----     15/12/2025  02:23 p. m.                Wdg_43_VR5510_TS_T40D11M40I2R0
d-----     15/12/2025  02:23 p. m.                Wdg_TS_T40D11M40I2R0
-a----     25/06/2020  10:09 a. m.         466201 com.collabnet.subversion.merge_3.0.12.jar
-a----     22/08/2024  10:06 a. m.           2746 com.freescale.tools.tresos.xpath.jar
-a----     25/06/2020  10:09 a. m.       11365876 com.ibm.icu_56.1.0.v201601250100.jar
-a----     25/06/2020  10:09 a. m.         301911 com.jcraft.jsch_0.1.53.v201508180515.jar
-a----     22/08/2024  10:23 a. m.           1757 com.nxp.tools.tresos.xpath.sqrt.jar
-a----     25/06/2020  10:09 a. m.          69600 dreisoft.tresos.application.core.jar
-a----     25/06/2020  10:09 a. m.        1203946 dreisoft.tresos.application.launcher2.jar
-a----     25/06/2020  10:09 a. m.          33385 dreisoft.tresos.autosar2.api.jar
-a----     25/06/2020  10:09 a. m.         258839 dreisoft.tresos.autosar2.jar
-a----     25/06/2020  10:09 a. m.       18350433 dreisoft.tresos.autosar2.parser.jar
-a----     25/06/2020  10:09 a. m.          90003 dreisoft.tresos.autosarimexporter.jar
-a----     25/06/2020  10:09 a. m.         120522 dreisoft.tresos.comimporter.api.jar
-a----     25/06/2020  10:09 a. m.          20061 dreisoft.tresos.comimporter.hooks.api.jar
-a----     25/06/2020  10:09 a. m.         100263 dreisoft.tresos.comimporter.jar
-a----     25/06/2020  10:09 a. m.        1967950 dreisoft.tresos.core.jar
-a----     25/06/2020  10:09 a. m.          21721 dreisoft.tresos.customization.jar
-a----     25/06/2020  10:09 a. m.         227643 dreisoft.tresos.datamodel2.api.jar
-a----     25/06/2020  10:09 a. m.        3963165 dreisoft.tresos.datamodel2.jar
-a----     25/06/2020  10:09 a. m.         236687 dreisoft.tresos.datamodeldiffer.jar
-a----     25/06/2020  10:09 a. m.         147890 dreisoft.tresos.dbcimporter.jar
-a----     25/06/2020  10:09 a. m.           1291 dreisoft.tresos.doc.eclipse.reference.jar
-a----     25/06/2020  10:09 a. m.        2444638 dreisoft.tresos.formulalanguage.parser.jar
-a----     25/06/2020  10:09 a. m.          49013 dreisoft.tresos.generator.api.jar
-a----     25/06/2020  10:09 a. m.        1153378 dreisoft.tresos.guidedconfig.api.jar
-a----     25/06/2020  10:09 a. m.       14012053 dreisoft.tresos.help.api.jar
-a----     25/06/2020  10:09 a. m.          64742 dreisoft.tresos.launcher2.api.jar
-a----     25/06/2020  10:09 a. m.        8040376 dreisoft.tresos.launcher2.jar
-a----     25/06/2020  10:09 a. m.         147897 dreisoft.tresos.ldfimporter.jar
-a----     25/06/2020  10:09 a. m.          26974 dreisoft.tresos.lib2.api.jar
-a----     25/06/2020  10:09 a. m.        7555679 dreisoft.tresos.lib2.jar
-a----     25/06/2020  10:09 a. m.         183484 dreisoft.tresos.oilparser.jar
-a----     25/06/2020  10:09 a. m.       15842637 dreisoft.tresos.sysdimporter.jar
-a----     25/06/2020  10:09 a. m.         298269 dreisoft.tresos.tdbupgradev1v2.jar
-a----     25/06/2020  10:09 a. m.       33723980 dreisoft.tresos.tresosdb.api.jar
-a----     25/06/2020  10:09 a. m.          27076 dreisoft.tresos.tresosdbimporter.jar
-a----     25/06/2020  10:09 a. m.         134233 dreisoft.tresos.workflow.api.jar
-a----     30/01/2025  04:41 p. m.        5307122 eb.tresos.doc.studio.developers.documentation.en.jar
-a----     30/01/2025  04:41 p. m.           1001 eb.tresos.doc.studio.developers.documentation.jar
-a----     30/01/2025  04:41 p. m.       13325591 eb.tresos.doc.studio.documentation.en.jar
-a----     30/01/2025  04:41 p. m.            965 eb.tresos.doc.studio.documentation.jar
-a----     22/08/2024  10:31 a. m.          29240 freescale.tresos.flexray.jar
-a----     25/06/2020  10:09 a. m.        2442625 guava-20.0.jar
-a----     25/06/2020  10:09 a. m.          29148 javax.annotation_1.2.0.v201602091430.jar
-a----     25/06/2020  10:09 a. m.          55399 javax.el_2.2.0.v201303151357.jar
-a----     25/06/2020  10:09 a. m.          16996 javax.inject_1.0.0.v20091030.jar
-a----     25/06/2020  10:09 a. m.         111144 javax.servlet.jsp_2.2.0.v201112011158.jar
-a----     25/06/2020  10:09 a. m.         105237 javax.servlet_3.1.0.v201410161800.jar
-a----     25/06/2020  10:09 a. m.         252201 javax.xml_1.3.4.v201005080400.jar
-a----     25/06/2020  10:09 a. m.         356012 org.apache.batik.css_1.7.0.v201011041433.jar
-a----     25/06/2020  10:09 a. m.         212351 org.apache.batik.util.gui_1.7.0.v200903091627.jar
-a----     25/06/2020  10:09 a. m.         158140 org.apache.batik.util_1.7.0.v201011041433.jar
-a----     25/06/2020  10:09 a. m.         253506 org.apache.commons.jxpath.studio.jar
-a----     25/06/2020  10:09 a. m.         315491 org.apache.commons.jxpath_1.3.0.v200911051830.jar
-a----     25/06/2020  10:09 a. m.        2435771 org.apache.jasper.glassfish_2.2.2.v201501141630.jar
-a----     25/06/2020  10:09 a. m.         908681 org.apache.lucene.analysis_3.5.0.v20120725-1805.jar
-a----     25/06/2020  10:09 a. m.        1550172 org.apache.lucene.core_3.5.0.v20120725-1805.jar
-a----     25/06/2020  10:09 a. m.         108529 org.eclipse.ant.core_3.4.100.v20160505-0642.jar
-a----     25/06/2020  10:09 a. m.          66969 org.eclipse.compare.core_3.6.0.v20160418-1534.jar
-a----     25/06/2020  10:09 a. m.         799554 org.eclipse.compare_3.7.0.v20161024-1724.jar
-a----     25/06/2020  10:09 a. m.         115077 org.eclipse.core.commands_3.8.0.v20160316-1921.jar
-a----     25/06/2020  10:09 a. m.         101190 org.eclipse.core.contenttype_3.5.100.v20160418-1621.jar
-a----     25/06/2020  10:09 a. m.          80155 org.eclipse.core.databinding.beans_1.3.100.v20160509-1025.jar
-a----     25/06/2020  10:09 a. m.         354911 org.eclipse.core.databinding.observable_1.6.0.v20160511-1747.jar
-a----     25/06/2020  10:09 a. m.         196421 org.eclipse.core.databinding.property_1.6.0.v20160427-0852.jar
-a----     25/06/2020  10:09 a. m.         204409 org.eclipse.core.databinding_1.6.0.v20160412-0910.jar
-a----     25/06/2020  10:09 a. m.          91504 org.eclipse.core.expressions_3.5.100.v20160418-1621.jar
-a----     25/06/2020  10:09 a. m.         122203 org.eclipse.core.filebuffers_3.6.0.v20160503-1849.jar
-a----     25/06/2020  10:09 a. m.          10538 org.eclipse.core.filesystem.linux.x86_64_1.2.200.v20140124-1940.jar
-a----     25/06/2020  10:09 a. m.          31937 org.eclipse.core.filesystem.win32.x86_64_1.4.0.v20140124-1940.jar
-a----     25/06/2020  10:09 a. m.          66579 org.eclipse.core.filesystem_1.6.1.v20161113-2349.jar
-a----     25/06/2020  10:09 a. m.         111093 org.eclipse.core.jobs_3.8.0.v20160509-0411.jar
-a----     25/06/2020  10:09 a. m.          39432 org.eclipse.core.net.linux.x86_64_1.2.0.v20160323-1650.jar
-a----     25/06/2020  10:09 a. m.          29884 org.eclipse.core.net.win32.x86_64_1.1.0.v20160323-1650.jar
-a----     25/06/2020  10:09 a. m.          74341 org.eclipse.core.net_1.3.0.v20160418-1534.jar
-a----     25/06/2020  10:09 a. m.         882701 org.eclipse.core.resources_3.11.1.v20161107-2032.jar
-a----     25/06/2020  10:09 a. m.          75728 org.eclipse.core.runtime_3.12.0.v20160606-1342.jar
-a----     25/06/2020  10:09 a. m.          36017 org.eclipse.core.variables_3.3.0.v20160419-1720.jar
-a----     25/06/2020  10:09 a. m.         369550 org.eclipse.debug.core_3.10.100.v20160419-1720.jar
-a----     25/06/2020  10:09 a. m.        3111927 org.eclipse.debug.ui_3.11.202.v20161114-0338.jar
-a----     25/06/2020  10:09 a. m.          26000 org.eclipse.e4.core.commands_0.11.100.v20160506-0804.jar
-a----     25/06/2020  10:09 a. m.          48129 org.eclipse.e4.core.contexts_1.5.0.v20160504-0909.jar
-a----     25/06/2020  10:09 a. m.          11576 org.eclipse.e4.core.di.annotations_1.5.0.v20151127-1241.jar
-a----     25/06/2020  10:09 a. m.          27795 org.eclipse.e4.core.di.extensions_0.14.0.v20160211-1614.jar
-a----     25/06/2020  10:09 a. m.          54696 org.eclipse.e4.core.di_1.6.1.v20160712-0927.jar
-a----     25/06/2020  10:09 a. m.          54479 org.eclipse.e4.core.services_2.0.100.v20160509-1032.jar
-a----     25/06/2020  10:09 a. m.          50089 org.eclipse.e4.emf.xpath_0.1.200.v20160506-0804.jar
-a----     25/06/2020  10:09 a. m.          50737 org.eclipse.e4.ui.bindings_0.11.100.v20160509-1025.jar
-a----     25/06/2020  10:09 a. m.         215924 org.eclipse.e4.ui.css.core_0.12.1.v20161114-0210.jar
-a----     25/06/2020  10:09 a. m.          27497 org.eclipse.e4.ui.css.swt.theme_0.10.100.v20160523-0836.jar
-a----     25/06/2020  10:09 a. m.         259445 org.eclipse.e4.ui.css.swt_0.12.100.v20160517-1505.jar
-a----     25/06/2020  10:09 a. m.          16800 org.eclipse.e4.ui.di_1.1.100.v20160506-0759.jar
-a----     25/06/2020  10:09 a. m.         385199 org.eclipse.e4.ui.model.workbench_1.2.0.v20160229-1459.jar
-a----     25/06/2020  10:09 a. m.          28151 org.eclipse.e4.ui.services_1.2.100.v20160506-0759.jar
-a----     25/06/2020  10:09 a. m.          10605 org.eclipse.e4.ui.swt.gtk_1.0.100.v20160301-1001.jar
-a----     25/06/2020  10:09 a. m.          15378 org.eclipse.e4.ui.widgets_1.1.100.v20160506-0759.jar
-a----     25/06/2020  10:09 a. m.         152398 org.eclipse.e4.ui.workbench.addons.swt_1.2.100.v20160831-1151.jar
-a----     25/06/2020  10:09 a. m.         299608 org.eclipse.e4.ui.workbench.renderers.swt_0.14.0.v20160525-0940.jar
-a----     25/06/2020  10:09 a. m.         191811 org.eclipse.e4.ui.workbench.swt_0.14.1.v20160829-0832.jar
-a----     25/06/2020  10:09 a. m.          10954 org.eclipse.e4.ui.workbench3_0.13.100.v20160506-0759.jar
-a----     25/06/2020  10:09 a. m.         249245 org.eclipse.e4.ui.workbench_1.4.0.v20160517-1624.jar
-a----     25/06/2020  10:09 a. m.         289125 org.eclipse.emf.codegen_2.11.0.v20160526-0356.jar
-a----     25/06/2020  10:09 a. m.         357670 org.eclipse.emf.common_2.12.0.v20160420-0247.jar
-a----     25/06/2020  10:09 a. m.          87096 org.eclipse.emf.ecore.change_2.11.0.v20160420-0247.jar
-a----     25/06/2020  10:09 a. m.         230424 org.eclipse.emf.ecore.xmi_2.12.0.v20160420-0247.jar
-a----     25/06/2020  10:09 a. m.        1190945 org.eclipse.emf.ecore_2.12.0.v20160420-0247.jar
-a----     25/06/2020  10:09 a. m.          87568 org.eclipse.equinox.app_1.3.400.v20150715-1528.jar
-a----     25/06/2020  10:09 a. m.          49755 org.eclipse.equinox.bidi_1.0.0.v20160307-1318.jar
-a----     25/06/2020  10:09 a. m.         120435 org.eclipse.equinox.common_3.8.0.v20160509-1230.jar
-a----     25/06/2020  10:09 a. m.         196894 org.eclipse.equinox.ds_1.4.400.v20160226-2036.jar
-a----     25/06/2020  10:09 a. m.          34366 org.eclipse.equinox.event_1.3.200.v20160324-1850.jar
-a----     25/06/2020  10:09 a. m.          64629 org.eclipse.equinox.frameworkadmin.equinox_1.0.700.v20160102-2223.jar
-a----     25/06/2020  10:09 a. m.          37428 org.eclipse.equinox.frameworkadmin_2.0.300.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.          29927 org.eclipse.equinox.http.jetty_3.3.0.v20160324-1850.jar
-a----     25/06/2020  10:09 a. m.          46284 org.eclipse.equinox.http.registry_1.1.400.v20150715-1528.jar
-a----     25/06/2020  10:09 a. m.         185781 org.eclipse.equinox.http.servlet_1.3.1.v20160808-1329.jar
-a----     25/06/2020  10:09 a. m.          11992 org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar
-a----     25/06/2020  10:09 a. m.          27958 org.eclipse.equinox.jsp.jasper_1.0.500.v20150119-1358.jar
-a----     25/06/2020  10:09 a. m.          51766 org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
-a----     25/06/2020  10:09 a. m.         141186 org.eclipse.equinox.p2.artifact.repository_1.1.500.v20160419-0834.jar
-a----     25/06/2020  10:09 a. m.          73322 org.eclipse.equinox.p2.core_2.4.100.v20160419-0834.jar
-a----     25/06/2020  10:09 a. m.          54805 org.eclipse.equinox.p2.director.app_1.0.500.v20160419-0834.jar
-a----     25/06/2020  10:09 a. m.         104577 org.eclipse.equinox.p2.director_2.3.300.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.         207690 org.eclipse.equinox.p2.engine_2.4.100.v20160419-0834.jar
-a----     25/06/2020  10:09 a. m.          25987 org.eclipse.equinox.p2.garbagecollector_1.0.300.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.          72608 org.eclipse.equinox.p2.jarprocessor_1.0.500.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.         122479 org.eclipse.equinox.p2.metadata.repository_1.2.300.v20160419-0834.jar
-a----     25/06/2020  10:09 a. m.         343607 org.eclipse.equinox.p2.metadata_2.3.100.v20160427-2220.jar
-a----     25/06/2020  10:09 a. m.         233445 org.eclipse.equinox.p2.publisher.eclipse_1.2.100.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.          96264 org.eclipse.equinox.p2.publisher_1.4.100.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.         245107 org.eclipse.equinox.p2.repository.tools_2.1.300.v20160421-0324.jar
-a----     25/06/2020  10:09 a. m.         134293 org.eclipse.equinox.p2.repository_2.3.200.v20160421-0324.jar
-a----     25/06/2020  10:09 a. m.         128908 org.eclipse.equinox.p2.touchpoint.eclipse_2.1.400.v20160419-0834.jar
-a----     25/06/2020  10:09 a. m.          96069 org.eclipse.equinox.p2.updatesite_1.0.600.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.         133114 org.eclipse.equinox.preferences_3.6.1.v20160815-1406.jar
-a----     25/06/2020  10:09 a. m.         186860 org.eclipse.equinox.registry_3.6.100.v20160223-2218.jar
-a----     25/06/2020  10:09 a. m.         185694 org.eclipse.equinox.security.ui_1.1.300.v20150803-1225.jar
-a----     25/06/2020  10:09 a. m.          35190 org.eclipse.equinox.security.win32.x86_64_1.0.100.v20130327-1442.jar
-a----     25/06/2020  10:09 a. m.         109600 org.eclipse.equinox.security_1.2.200.v20150715-1528.jar
-a----     25/06/2020  10:09 a. m.          26379 org.eclipse.equinox.simpleconfigurator.manipulator_2.0.200.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.          44424 org.eclipse.equinox.simpleconfigurator_1.1.200.v20160504-1450.jar
-a----     25/06/2020  10:09 a. m.          77626 org.eclipse.equinox.util_1.0.500.v20130404-1337.jar
-a----     25/06/2020  10:09 a. m.         429486 org.eclipse.help.base_4.1.1.v20161124-1400.jar
-a----     25/06/2020  10:09 a. m.         508193 org.eclipse.help.ui_4.0.200.v20160510-0758.jar
-a----     25/06/2020  10:09 a. m.         637639 org.eclipse.help.webapp_3.8.0.v20160504-0839.jar
-a----     25/06/2020  10:09 a. m.         269916 org.eclipse.help_3.7.0.v20160602-1307.jar
-a----     25/06/2020  10:09 a. m.         169161 org.eclipse.jdt.compiler.apt_1.2.100.v20160418-1457.jar
-a----     25/06/2020  10:09 a. m.          69155 org.eclipse.jdt.compiler.tool_1.1.100.v20160418-1457.jar
-a----     25/06/2020  10:09 a. m.        5826018 org.eclipse.jdt.core_3.12.2.v20161117-1814.jar
-a----     25/06/2020  10:09 a. m.         343515 org.eclipse.jdt.launching_3.8.101.v20161111-2014.jar
-a----     25/06/2020  10:09 a. m.         159462 org.eclipse.jetty.http_9.3.9.v20160517.jar
-a----     25/06/2020  10:09 a. m.         119392 org.eclipse.jetty.io_9.3.9.v20160517.jar
-a----     25/06/2020  10:09 a. m.         105193 org.eclipse.jetty.security_9.3.9.v20160517.jar
-a----     25/06/2020  10:09 a. m.         512378 org.eclipse.jetty.server_9.3.9.v20160517.jar
-a----     25/06/2020  10:09 a. m.         126755 org.eclipse.jetty.servlet_9.3.9.v20160517.jar
-a----     25/06/2020  10:09 a. m.         458691 org.eclipse.jetty.util_9.3.9.v20160517.jar
-a----     25/06/2020  10:09 a. m.         290885 org.eclipse.jface.databinding_1.8.1.v20161026-1531.jar
-a----     25/06/2020  10:09 a. m.        1070533 org.eclipse.jface.text_3.11.2.v20161113-1700.jar
-a----     25/06/2020  10:09 a. m.        1086977 org.eclipse.jface_3.12.1.v20160923-1528.jar
-a----     25/06/2020  10:09 a. m.          42230 org.eclipse.jsch.core_1.3.0.v20160422-1917.jar
-a----     25/06/2020  10:09 a. m.         104621 org.eclipse.jsch.ui_1.3.0.v20160323-1650.jar
-a----     25/06/2020  10:09 a. m.         345037 org.eclipse.ltk.core.refactoring_3.7.0.v20160419-0705.jar
-a----     25/06/2020  10:09 a. m.         503766 org.eclipse.ltk.ui.refactoring_3.8.0.v20160518-1817.jar
-a----     25/06/2020  10:09 a. m.          28717 org.eclipse.nebula.widgets.pshelf_1.1.0.201609231530.jar
-a----     25/06/2020  10:09 a. m.          34486 org.eclipse.ocl.common_1.4.100.v20160613-1351.jar
-a----     25/06/2020  10:09 a. m.         244042 org.eclipse.osgi.compatibility.state_1.0.200.v20160504-1419.jar
-a----     25/06/2020  10:09 a. m.         111152 org.eclipse.osgi.services_3.5.100.v20160504-1419.jar
-a----     25/06/2020  10:09 a. m.        1383928 org.eclipse.osgi_3.11.2.v20161107-1947.jar
-a----     25/06/2020  10:09 a. m.        1304527 org.eclipse.pde.core_3.11.1.v20161115-1951.jar
-a----     25/06/2020  10:09 a. m.         169036 org.eclipse.pde.runtime_3.5.0.v20160418-1724.jar
-a----     25/06/2020  10:09 a. m.        8810009 org.eclipse.platform.doc.user_4.6.1.v20160727-2009.jar
-a----     25/06/2020  10:09 a. m.         510112 org.eclipse.search_3.11.1.v20161113-1700.jar
-a----     25/06/2020  10:09 a. m.        2767389 org.eclipse.swt.gtk.linux.x86_64_3.105.2.v20161122-0613.jar
-a----     25/06/2020  10:09 a. m.        2872411 org.eclipse.swt.win32.win32.x86_64_3.105.2.v20161122-0613.jar
-a----     25/06/2020  10:09 a. m.          19649 org.eclipse.swt_3.105.2.v20161122-0613.jar
-a----     25/06/2020  10:09 a. m.         426162 org.eclipse.team.core_3.8.0.v20160418-1534.jar
-a----     25/06/2020  10:09 a. m.         614115 org.eclipse.team.cvs.core_3.4.0.v20160418-1534.jar
-a----     25/06/2020  10:09 a. m.          30941 org.eclipse.team.cvs.ssh2_3.3.0.v20160418-1534.jar
-a----     25/06/2020  10:09 a. m.        1790551 org.eclipse.team.cvs.ui_3.4.0.v20160518-1906.jar
-a----     25/06/2020  10:09 a. m.        1536964 org.eclipse.team.ui_3.8.0.v20160518-1906.jar
-a----     25/06/2020  10:09 a. m.         269227 org.eclipse.text_3.6.0.v20160503-1849.jar
-a----     25/06/2020  10:09 a. m.         213276 org.eclipse.ui.console_3.6.201.v20161107-0337.jar
-a----     25/06/2020  10:09 a. m.         612214 org.eclipse.ui.editors_3.10.1.v20161106-1856.jar
-a----     25/06/2020  10:09 a. m.         348108 org.eclipse.ui.forms_3.7.0.v20160518-1929.jar
-a----     25/06/2020  10:09 a. m.          95438 org.eclipse.ui.ide.application_1.1.101.v20160829-0827.jar
-a----     25/06/2020  10:09 a. m.        2384816 org.eclipse.ui.ide_3.12.2.v20161115-1450.jar
-a----     25/06/2020  10:09 a. m.         328326 org.eclipse.ui.intro_3.5.2.v20161116-1147.jar
-a----     25/06/2020  10:09 a. m.         162342 org.eclipse.ui.navigator.resources_3.5.101.v20161006-0640.jar
-a----     25/06/2020  10:09 a. m.         437132 org.eclipse.ui.navigator_3.6.101.v20161006-1120.jar
-a----     25/06/2020  10:09 a. m.          51165 org.eclipse.ui.net_1.3.0.v20160426-1633.jar
-a----     25/06/2020  10:09 a. m.          71747 org.eclipse.ui.trace_1.0.400.v20160509-1055.jar
-a----     25/06/2020  10:09 a. m.         110526 org.eclipse.ui.views.properties.tabbed_3.7.0.v20160310-0903.jar
-a----     25/06/2020  10:09 a. m.         110524 org.eclipse.ui.views_3.8.101.v20160816-1954.jar
-a----     25/06/2020  10:09 a. m.          25969 org.eclipse.ui.win32_3.3.0.v20160505-1310.jar
-a----     25/06/2020  10:09 a. m.         667595 org.eclipse.ui.workbench.texteditor_3.10.1.v20160818-1626.jar
-a----     25/06/2020  10:09 a. m.        4040836 org.eclipse.ui.workbench_3.108.2.v20161025-2029.jar
-a----     25/06/2020  10:09 a. m.         396072 org.eclipse.ui_3.108.1.v20160929-1045.jar
-a----     25/06/2020  10:09 a. m.          90345 org.eclipse.uml2.common_2.1.0.v20160822-0739.jar
-a----     25/06/2020  10:09 a. m.          18871 org.eclipse.uml2.types_2.0.0.v20160822-0739.jar
-a----     25/06/2020  10:09 a. m.         102634 org.eclipse.update.configurator_3.3.400.v20160506-0750.jar
-a----     25/06/2020  10:09 a. m.         362968 org.sat4j.core_2.3.5.v201308161310.jar
-a----     25/06/2020  10:09 a. m.         241956 org.sat4j.pb_2.3.5.v201404071733.jar
-a----     25/06/2020  10:09 a. m.        3280108 org.tigris.subversion.clientadapter.javahl.win64_1.7.8.jar
-a----     25/06/2020  10:09 a. m.         167688 org.tigris.subversion.clientadapter.javahl_1.7.8.1.jar
-a----     25/06/2020  10:09 a. m.          83885 org.tigris.subversion.clientadapter_1.8.3.jar
-a----     25/06/2020  10:09 a. m.         328109 org.tigris.subversion.subclipse.core_1.8.16.jar
-a----     25/06/2020  10:09 a. m.        2342932 org.tigris.subversion.subclipse.doc_1.3.0.jar
-a----     25/06/2020  10:09 a. m.        2054352 org.tigris.subversion.subclipse.ui_1.8.18.jar
-a----     25/06/2020  10:09 a. m.         109753 org.tukaani.xz_1.3.0.v201308270617.jar
-a----     25/06/2020  10:09 a. m.          38584 org.w3c.css.sac_1.3.1.v200903091627.jar
-a----     25/06/2020  10:09 a. m.          18205 org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar
-a----     25/06/2020  10:09 a. m.          20106 org.w3c.dom.smil_1.0.1.v200903091627.jar
-a----     25/06/2020  10:09 a. m.          97382 org.w3c.dom.svg_1.1.0.v201011041433.jar
PS C:\NXP\SW32G_RTD_4.4_4.0.2_HF03\eclipse\plugins> Get-ChildItem -Depth 0
    Directory: C:\NXP\SW32G_RTD_4.4_4.0.2_HF03\eclipse\plugins
d-----     12/12/2025  04:47 p. m.                Adc_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                BaseNXP_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                CanIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Can_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Crc_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                CryIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Crypto_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Csm_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Dem_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Det_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Dio_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                EcuC_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                EcuM_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                Eep_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                EthIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                EthSwt_TS_T40D11M40I2R0
d-----     12/12/2025  04:48 p. m.                EthTrcv_TS_T40D11M40I2R0
d-----     15/12/2025  03:08 p. m.                Eth_43_PFE_TS_T40D11M12I0R0
d-----     12/12/2025  04:49 p. m.                Eth_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                Fee_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                Fls_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                FrIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                Fr_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                Gpt_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                I2c_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                Icu_TS_T40D11M40I2R0
d-----     12/12/2025  04:49 p. m.                LinIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Lin_TS_T40D11M40I2R0
d-----     15/12/2025  03:08 p. m.                Mcl_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Mcu_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                MemIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Ocotp_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Ocu_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Os_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Pcie_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Platform_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Pmic_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Port_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Pwm_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Qdec_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Resource_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Rm_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Rte_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Serdes_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Spi_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Thermal_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                Uart_TS_T40D11M40I2R0
d-----     12/12/2025  04:50 p. m.                WdgIf_TS_T40D11M40I2R0
d-----     12/12/2025  04:51 p. m.                Wdg_43_VR5510_TS_T40D11M40I2R0
d-----     12/12/2025  04:51 p. m.                Wdg_TS_T40D11M40I2R0
Then you can compare if there is any relevant difference in our plugin installation.
If you do not find any important difference, I would recommend trying reinstalling EB Tresos, if you have not already.
Please let me know if you find any information that might help me narrow down the problem.
3,051 次查看
Yang_C
Hi alejandro_e,
Following your suggestion, I did the comparison, here is the result:
The output for C:\EB\tresos27\plugins, there're loads of differences.
As for the output for C:\NXP\SW32G_RTD_4.4_4.0.2_HF03\eclipse\plugins,  they are completely the same.
I will try reinstall the EB tresos on my end. Any updates I will let you know.
Thank you very much.
BR,
Yang
2,965 次查看
alejandro_e
Hello @Yang_C,
Were you able solve the problem after reinstalling EB Tresos Studio or were you able to get more information related to the issue?
2,948 次查看
Yang_C
Hi alejandro_e,
Sorry for the late response.
Unfortunately, I reinstalled EB tresos but the problem still persists. The issue is weird, I have decided to move on using Eth_43_PFE_TS_T40D11M14I0R0 for PFE configration.
Thank you for your support anyway.
BR,
Yang
2,942 次查看
alejandro_e
Hello @Yang_C,
I am glad you were able to find a workaround for your problem. It is quite weird as you mentioned and I am sorry for not being of much help.
If in the future you encounter any other problem do not hesitate in creating a new post.
%3CLINGO-SUB%20id%3D%22lingo-sub-2258489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEB%20tresos%20%E9%97%AE%E9%A2%98%20-%20%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%E6%A8%A1%E5%9D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2258489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20EB%20tresos%20%E6%96%B9%E9%9D%A2%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B8%8C%E6%9C%9B%E6%9C%89%E4%BA%BA%E8%83%BD%E7%BB%99%E7%82%B9%E6%8F%90%E7%A4%BA%E3%80%82%E5%9C%A8%E6%AD%A4%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%9C%A8%20EB%20%E4%B8%8A%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%20EB%20%E7%89%88%E6%9C%AC%E6%98%AF%2027.1.0%E3%80%82%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%E6%A8%A1%E5%9D%97%E6%97%B6%EF%BC%8C%E5%BC%B9%E5%87%BA%E4%BA%86%E5%A6%82%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8C%E6%8F%90%E7%A4%BA%3CSTRONG%3EEth_43_PFE_TS_T40D11M12I0R0%20%3C%2FSTRONG%3E%E6%9C%AA%E5%AE%89%E8%A3%85%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369210i5F147BB996BD1B67%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22error.png%22%20alt%3D%22error.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E5%9C%A8%E5%AE%89%E8%A3%85%20EB%20tresos%20%E6%97%B6%EF%BC%8C%E5%BA%94%E8%AF%A5%E9%93%BE%E6%8E%A5%E5%88%B0%20RTD%20%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E8%BF%99%E4%B9%88%E5%81%9A%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22link.png%22%20style%3D%22width%3A%20595px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369211iAE3768363CA7371C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22link.png%22%20alt%3D%22link.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%BF%98%E5%B0%86%3CSTRONG%3EEth_43_PFE_TS_T40D11M12I0R0%3C%2FSTRONG%3E%E5%A4%8D%E5%88%B6%E5%88%B0%20RTD%20%E6%96%87%E4%BB%B6%E5%A4%B9%E5%92%8C%20EB%20%E6%8F%92%E4%BB%B6%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTD%20folder.png%22%20style%3D%22width%3A%20995px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369214i5319D421828F0250%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RTD%20folder.png%22%20alt%3D%22RTD%20folder.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22tresos%20folder.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369213iCF7607EADAE88D16%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22tresos%20folder.png%22%20alt%3D%22tresos%20folder.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%89%80%E6%9C%89%E4%B8%8A%E8%BF%B0%E6%93%8D%E4%BD%9C%E9%83%BD%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%EF%BC%8C%E9%94%99%E8%AF%AF%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%94%99%E8%BF%87%E4%BA%86%E4%BB%80%E4%B9%88%E8%AE%BE%E7%BD%AE%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3E%E6%9D%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242651%22%20target%3D%22_blank%22%3E%40Yang_C%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E8%AF%B4%EF%BC%8C%E4%B8%80%E5%88%87%E4%BC%BC%E4%B9%8E%E9%83%BD%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E5%AE%8C%E6%88%90%E4%BB%A5%E4%B8%8B%E6%B5%8B%E8%AF%95%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%20PFE-DRV_S32G_M7_MCAL_1.2.0.%5Cexample_application%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLI%3E%0A%3CLI%3E%E5%88%A0%E9%99%A4%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E5%8F%AA%E4%BD%BF%E7%94%A8%20Tresos%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%A4%8D%E5%88%B6%E7%9A%84%E6%8F%92%E4%BB%B6%E3%80%82%E7%89%88%E6%9C%AC%3CEM%3E%201.2.0%3C%2FEM%3E%3CEM%3E%20%E7%9A%84%20S32G%20MCAL%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%3C%2FEM%3E%20%E6%8F%90%E5%88%B0%E4%BA%86%E7%9B%B8%E4%BA%92%E6%8E%92%20%E6%96%A5%E7%9A%84%E5%AE%89%E8%A3%85%E6%96%B9%E6%B3%95%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1765490795933.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F369603i5564699AC3847EB7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1765490795933.png%22%20alt%3D%22alejandro_e_0-1765490795933.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E6%89%93%E5%BC%80%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%96%E8%80%85%E5%88%A0%E9%99%A4%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%E5%90%8E%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%A1%8C%E4%B8%BA%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20alejandro_e%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AE%A9%E6%88%91%E9%80%90%E4%B8%80%E5%9B%9E%E7%AD%94%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%20PFE-DRV_S32G_M7_MCAL_1.2.0.%5Cexample_application%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%20%20%3CSTRONG%3E-%20%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E6%B2%A1%E7%94%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E6%B2%A1%E6%9C%89%E5%AE%89%E8%A3%85%20Eth%20%E6%A8%A1%E5%9D%97%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%88%A0%E9%99%A4%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E5%8F%AA%E4%BD%BF%E7%94%A8%20Tresos%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E5%A4%8D%E5%88%B6%E7%9A%84%E6%8F%92%E4%BB%B6%E3%80%82%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%20%3CSTRONG%3E-%20%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E6%B2%A1%E7%94%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E6%B2%A1%E6%9C%89%E5%AE%89%E8%A3%85%20Eth%20%E6%A8%A1%E5%9D%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%BF%98%E4%B8%8B%E8%BD%BD%E4%BA%86%20PFE-DRV_S32G_M7_MCAL_1.4.0%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%20PFE-DRV_S32G_M7_MCAL_1.4.0%20%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%98%AF%20Eth%20%E6%A8%A1%E5%9D%97%E5%9C%A8%20NXP%2FRTD%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E8%BF%98%E6%98%AF%E5%9C%A8%20EB%2Ftresos%2Fplugins%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%8C%E9%83%BD%E5%8F%AF%E4%BB%A5%E9%A1%BA%E5%88%A9%E6%89%93%E5%BC%80%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3E%E6%9D%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20alejandro_e%E3%80%81%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%AF%94%E8%BE%83%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3EC%3A%5CEB%5Ctresos27%5Cplugins%3C%2FEM%3E%20%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%8C%E6%9C%89%E5%A4%A7%E9%87%8F%E4%B8%8D%E5%90%8C%E4%B9%8B%E5%A4%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B3%E4%BA%8E%3CEM%3EC%3A%5CNXP%5CSW32G_RTD_4.4_4.0.2_HF03%5Ceclipse%5Cplugins%20%E7%9A%84%20%3C%2FEM%3E%E8%BE%93%E5%87%BA%EF%BC%8C%20%E5%AE%83%E4%BB%AC%E5%AE%8C%E5%85%A8%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%88%91%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%8A%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20EB%20tresos%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%96%B0%EF%BC%8C%E6%88%91%E4%BC%9A%E9%80%9A%E7%9F%A5%E4%BD%A0%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3E%E6%9D%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2263092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242651%22%20target%3D%22_blank%22%3E%40Yang_C%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E7%9A%84%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%E6%88%91%E8%AF%95%E7%9D%80%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%E6%88%91%E5%A4%8D%E5%88%B6%E4%BA%86%E6%8F%92%E4%BB%B6%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%BA%86%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%EF%BC%8C%E8%BF%98%E5%A4%8D%E5%88%B6%E4%BA%86%E4%BD%A0%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B8%A4%E4%B8%AA%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%EF%BC%9A1.2.0%20%E5%92%8C%201.4.0%E3%80%82%E4%BD%A0%E8%83%BD%E5%9C%A8%3CEM%3EC%3A%5CEB%5Ctresos27%5Cplugins%20%3C%2FEM%3E%E5%92%8C%20C%3CEM%3E%3A%5CNXP%5CSW32G_RTD_4.4_4.0.2_HF03%5Ceclipse%5Cplugins%3C%2FEM%3E%E4%B8%AD%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%20powerhell%20%E5%91%BD%E4%BB%A4%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26gt%3B%20Get-ChildItem%20-Depth%200%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EPS%20C%3A%5CEB%5Ctresos27%5Cplugins%26gt%3B%20Get-ChildItem%20-Depth%200%0A%0A%0A%20%20%20%20Directory%3A%20C%3A%5CEB%5Ctresos27%5Cplugins%0A%0A%0AMode%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20LastWriteTime%20%20%20%20%20%20%20%20%20Length%20Name%0A----%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20-------------%20%20%20%20%20%20%20%20%20------%20----%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A23%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Adc_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20BaseNXP_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20CanIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Can_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Crc_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20CryIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Crypto_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Csm_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Dem_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Det_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Dio_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20dreisoft.tresos.fibeximporter%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20dreisoft.tresos.generator.ng.api%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EcuC_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EcuM_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eep_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EthIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EthSwt_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EthTrcv_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A35%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eth_43_PFE_TS_T40D11M12I0R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2003%3A04%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eth_43_PFE_TS_T40D11M14I0R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eth_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Fee_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Fls_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20FrIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Fr_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Gpt_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20I2c_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Icu_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20LinIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Lin_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Mcl_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Mcu_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20MemIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Ocotp_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Ocu_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20org.apache.ant_1.9.6.v201510161327%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.401.v20161122-1740%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.401.v20161122-1740%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20org.eclipse.jdt.debug_3.10.1.v20160811-0441%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20org.eclipse.pde.build_3.9.200.v20160204-0642%0Ad-----%20%20%20%20%2030%2F01%2F2025%20%2004%3A42%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20org.eclipse.ui.themes_1.1.300.v20161107-1827%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Os_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Pcie_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Platform_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Pmic_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Port_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Pwm_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Qdec_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Resource_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Rm_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Rte_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Serdes_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Spi_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A24%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Thermal_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A23%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Uart_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A23%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20WdgIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A23%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Wdg_43_VR5510_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2002%3A23%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Wdg_TS_T40D11M40I2R0%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20466201%20com.collabnet.subversion.merge_3.0.12.jar%0A-a----%20%20%20%20%2022%2F08%2F2024%20%2010%3A06%20a.%20m.%20%20%20%20%20%20%20%20%20%20%202746%20com.freescale.tools.tresos.xpath.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%2011365876%20com.ibm.icu_56.1.0.v201601250100.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20301911%20com.jcraft.jsch_0.1.53.v201508180515.jar%0A-a----%20%20%20%20%2022%2F08%2F2024%20%2010%3A23%20a.%20m.%20%20%20%20%20%20%20%20%20%20%201757%20com.nxp.tools.tresos.xpath.sqrt.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2069600%20dreisoft.tresos.application.core.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201203946%20dreisoft.tresos.application.launcher2.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2033385%20dreisoft.tresos.autosar2.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20258839%20dreisoft.tresos.autosar2.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%2018350433%20dreisoft.tresos.autosar2.parser.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2090003%20dreisoft.tresos.autosarimexporter.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20120522%20dreisoft.tresos.comimporter.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2020061%20dreisoft.tresos.comimporter.hooks.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20100263%20dreisoft.tresos.comimporter.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201967950%20dreisoft.tresos.core.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2021721%20dreisoft.tresos.customization.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20227643%20dreisoft.tresos.datamodel2.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%203963165%20dreisoft.tresos.datamodel2.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20236687%20dreisoft.tresos.datamodeldiffer.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20147890%20dreisoft.tresos.dbcimporter.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%20%201291%20dreisoft.tresos.doc.eclipse.reference.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202444638%20dreisoft.tresos.formulalanguage.parser.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2049013%20dreisoft.tresos.generator.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201153378%20dreisoft.tresos.guidedconfig.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%2014012053%20dreisoft.tresos.help.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2064742%20dreisoft.tresos.launcher2.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%208040376%20dreisoft.tresos.launcher2.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20147897%20dreisoft.tresos.ldfimporter.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2026974%20dreisoft.tresos.lib2.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%207555679%20dreisoft.tresos.lib2.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20183484%20dreisoft.tresos.oilparser.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%2015842637%20dreisoft.tresos.sysdimporter.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20298269%20dreisoft.tresos.tdbupgradev1v2.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%2033723980%20dreisoft.tresos.tresosdb.api.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2027076%20dreisoft.tresos.tresosdbimporter.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20134233%20dreisoft.tresos.workflow.api.jar%0A-a----%20%20%20%20%2030%2F01%2F2025%20%2004%3A41%20p.%20m.%20%20%20%20%20%20%20%205307122%20eb.tresos.doc.studio.developers.documentation.en.jar%0A-a----%20%20%20%20%2030%2F01%2F2025%20%2004%3A41%20p.%20m.%20%20%20%20%20%20%20%20%20%20%201001%20eb.tresos.doc.studio.developers.documentation.jar%0A-a----%20%20%20%20%2030%2F01%2F2025%20%2004%3A41%20p.%20m.%20%20%20%20%20%20%2013325591%20eb.tresos.doc.studio.documentation.en.jar%0A-a----%20%20%20%20%2030%2F01%2F2025%20%2004%3A41%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20965%20eb.tresos.doc.studio.documentation.jar%0A-a----%20%20%20%20%2022%2F08%2F2024%20%2010%3A31%20a.%20m.%20%20%20%20%20%20%20%20%20%2029240%20freescale.tresos.flexray.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202442625%20guava-20.0.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2029148%20javax.annotation_1.2.0.v201602091430.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2055399%20javax.el_2.2.0.v201303151357.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2016996%20javax.inject_1.0.0.v20091030.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20111144%20javax.servlet.jsp_2.2.0.v201112011158.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20105237%20javax.servlet_3.1.0.v201410161800.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20252201%20javax.xml_1.3.4.v201005080400.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20356012%20org.apache.batik.css_1.7.0.v201011041433.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20212351%20org.apache.batik.util.gui_1.7.0.v200903091627.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20158140%20org.apache.batik.util_1.7.0.v201011041433.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20253506%20org.apache.commons.jxpath.studio.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20315491%20org.apache.commons.jxpath_1.3.0.v200911051830.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202435771%20org.apache.jasper.glassfish_2.2.2.v201501141630.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20908681%20org.apache.lucene.analysis_3.5.0.v20120725-1805.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201550172%20org.apache.lucene.core_3.5.0.v20120725-1805.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20108529%20org.eclipse.ant.core_3.4.100.v20160505-0642.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2066969%20org.eclipse.compare.core_3.6.0.v20160418-1534.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20799554%20org.eclipse.compare_3.7.0.v20161024-1724.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20115077%20org.eclipse.core.commands_3.8.0.v20160316-1921.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20101190%20org.eclipse.core.contenttype_3.5.100.v20160418-1621.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2080155%20org.eclipse.core.databinding.beans_1.3.100.v20160509-1025.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20354911%20org.eclipse.core.databinding.observable_1.6.0.v20160511-1747.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20196421%20org.eclipse.core.databinding.property_1.6.0.v20160427-0852.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20204409%20org.eclipse.core.databinding_1.6.0.v20160412-0910.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2091504%20org.eclipse.core.expressions_3.5.100.v20160418-1621.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20122203%20org.eclipse.core.filebuffers_3.6.0.v20160503-1849.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2010538%20org.eclipse.core.filesystem.linux.x86_64_1.2.200.v20140124-1940.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2031937%20org.eclipse.core.filesystem.win32.x86_64_1.4.0.v20140124-1940.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2066579%20org.eclipse.core.filesystem_1.6.1.v20161113-2349.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20111093%20org.eclipse.core.jobs_3.8.0.v20160509-0411.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2039432%20org.eclipse.core.net.linux.x86_64_1.2.0.v20160323-1650.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2029884%20org.eclipse.core.net.win32.x86_64_1.1.0.v20160323-1650.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2074341%20org.eclipse.core.net_1.3.0.v20160418-1534.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20882701%20org.eclipse.core.resources_3.11.1.v20161107-2032.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2075728%20org.eclipse.core.runtime_3.12.0.v20160606-1342.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2036017%20org.eclipse.core.variables_3.3.0.v20160419-1720.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20369550%20org.eclipse.debug.core_3.10.100.v20160419-1720.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%203111927%20org.eclipse.debug.ui_3.11.202.v20161114-0338.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2026000%20org.eclipse.e4.core.commands_0.11.100.v20160506-0804.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2048129%20org.eclipse.e4.core.contexts_1.5.0.v20160504-0909.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2011576%20org.eclipse.e4.core.di.annotations_1.5.0.v20151127-1241.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2027795%20org.eclipse.e4.core.di.extensions_0.14.0.v20160211-1614.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2054696%20org.eclipse.e4.core.di_1.6.1.v20160712-0927.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2054479%20org.eclipse.e4.core.services_2.0.100.v20160509-1032.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2050089%20org.eclipse.e4.emf.xpath_0.1.200.v20160506-0804.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2050737%20org.eclipse.e4.ui.bindings_0.11.100.v20160509-1025.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20215924%20org.eclipse.e4.ui.css.core_0.12.1.v20161114-0210.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2027497%20org.eclipse.e4.ui.css.swt.theme_0.10.100.v20160523-0836.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20259445%20org.eclipse.e4.ui.css.swt_0.12.100.v20160517-1505.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2016800%20org.eclipse.e4.ui.di_1.1.100.v20160506-0759.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20385199%20org.eclipse.e4.ui.model.workbench_1.2.0.v20160229-1459.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2028151%20org.eclipse.e4.ui.services_1.2.100.v20160506-0759.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2010605%20org.eclipse.e4.ui.swt.gtk_1.0.100.v20160301-1001.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2015378%20org.eclipse.e4.ui.widgets_1.1.100.v20160506-0759.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20152398%20org.eclipse.e4.ui.workbench.addons.swt_1.2.100.v20160831-1151.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20299608%20org.eclipse.e4.ui.workbench.renderers.swt_0.14.0.v20160525-0940.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20191811%20org.eclipse.e4.ui.workbench.swt_0.14.1.v20160829-0832.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2010954%20org.eclipse.e4.ui.workbench3_0.13.100.v20160506-0759.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20249245%20org.eclipse.e4.ui.workbench_1.4.0.v20160517-1624.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20289125%20org.eclipse.emf.codegen_2.11.0.v20160526-0356.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20357670%20org.eclipse.emf.common_2.12.0.v20160420-0247.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2087096%20org.eclipse.emf.ecore.change_2.11.0.v20160420-0247.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20230424%20org.eclipse.emf.ecore.xmi_2.12.0.v20160420-0247.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201190945%20org.eclipse.emf.ecore_2.12.0.v20160420-0247.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2087568%20org.eclipse.equinox.app_1.3.400.v20150715-1528.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2049755%20org.eclipse.equinox.bidi_1.0.0.v20160307-1318.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20120435%20org.eclipse.equinox.common_3.8.0.v20160509-1230.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20196894%20org.eclipse.equinox.ds_1.4.400.v20160226-2036.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2034366%20org.eclipse.equinox.event_1.3.200.v20160324-1850.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2064629%20org.eclipse.equinox.frameworkadmin.equinox_1.0.700.v20160102-2223.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2037428%20org.eclipse.equinox.frameworkadmin_2.0.300.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2029927%20org.eclipse.equinox.http.jetty_3.3.0.v20160324-1850.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2046284%20org.eclipse.equinox.http.registry_1.1.400.v20150715-1528.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20185781%20org.eclipse.equinox.http.servlet_1.3.1.v20160808-1329.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2011992%20org.eclipse.equinox.jsp.jasper.registry_1.0.300.v20130327-1442.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2027958%20org.eclipse.equinox.jsp.jasper_1.0.500.v20150119-1358.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2051766%20org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20141186%20org.eclipse.equinox.p2.artifact.repository_1.1.500.v20160419-0834.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2073322%20org.eclipse.equinox.p2.core_2.4.100.v20160419-0834.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2054805%20org.eclipse.equinox.p2.director.app_1.0.500.v20160419-0834.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20104577%20org.eclipse.equinox.p2.director_2.3.300.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20207690%20org.eclipse.equinox.p2.engine_2.4.100.v20160419-0834.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2025987%20org.eclipse.equinox.p2.garbagecollector_1.0.300.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2072608%20org.eclipse.equinox.p2.jarprocessor_1.0.500.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20122479%20org.eclipse.equinox.p2.metadata.repository_1.2.300.v20160419-0834.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20343607%20org.eclipse.equinox.p2.metadata_2.3.100.v20160427-2220.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20233445%20org.eclipse.equinox.p2.publisher.eclipse_1.2.100.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2096264%20org.eclipse.equinox.p2.publisher_1.4.100.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20245107%20org.eclipse.equinox.p2.repository.tools_2.1.300.v20160421-0324.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20134293%20org.eclipse.equinox.p2.repository_2.3.200.v20160421-0324.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20128908%20org.eclipse.equinox.p2.touchpoint.eclipse_2.1.400.v20160419-0834.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2096069%20org.eclipse.equinox.p2.updatesite_1.0.600.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20133114%20org.eclipse.equinox.preferences_3.6.1.v20160815-1406.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20186860%20org.eclipse.equinox.registry_3.6.100.v20160223-2218.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20185694%20org.eclipse.equinox.security.ui_1.1.300.v20150803-1225.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2035190%20org.eclipse.equinox.security.win32.x86_64_1.0.100.v20130327-1442.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20109600%20org.eclipse.equinox.security_1.2.200.v20150715-1528.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2026379%20org.eclipse.equinox.simpleconfigurator.manipulator_2.0.200.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2044424%20org.eclipse.equinox.simpleconfigurator_1.1.200.v20160504-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2077626%20org.eclipse.equinox.util_1.0.500.v20130404-1337.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20429486%20org.eclipse.help.base_4.1.1.v20161124-1400.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20508193%20org.eclipse.help.ui_4.0.200.v20160510-0758.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20637639%20org.eclipse.help.webapp_3.8.0.v20160504-0839.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20269916%20org.eclipse.help_3.7.0.v20160602-1307.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20169161%20org.eclipse.jdt.compiler.apt_1.2.100.v20160418-1457.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2069155%20org.eclipse.jdt.compiler.tool_1.1.100.v20160418-1457.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%205826018%20org.eclipse.jdt.core_3.12.2.v20161117-1814.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20343515%20org.eclipse.jdt.launching_3.8.101.v20161111-2014.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20159462%20org.eclipse.jetty.http_9.3.9.v20160517.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20119392%20org.eclipse.jetty.io_9.3.9.v20160517.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20105193%20org.eclipse.jetty.security_9.3.9.v20160517.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20512378%20org.eclipse.jetty.server_9.3.9.v20160517.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20126755%20org.eclipse.jetty.servlet_9.3.9.v20160517.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20458691%20org.eclipse.jetty.util_9.3.9.v20160517.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20290885%20org.eclipse.jface.databinding_1.8.1.v20161026-1531.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201070533%20org.eclipse.jface.text_3.11.2.v20161113-1700.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201086977%20org.eclipse.jface_3.12.1.v20160923-1528.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2042230%20org.eclipse.jsch.core_1.3.0.v20160422-1917.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20104621%20org.eclipse.jsch.ui_1.3.0.v20160323-1650.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20345037%20org.eclipse.ltk.core.refactoring_3.7.0.v20160419-0705.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20503766%20org.eclipse.ltk.ui.refactoring_3.8.0.v20160518-1817.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2028717%20org.eclipse.nebula.widgets.pshelf_1.1.0.201609231530.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2034486%20org.eclipse.ocl.common_1.4.100.v20160613-1351.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20244042%20org.eclipse.osgi.compatibility.state_1.0.200.v20160504-1419.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20111152%20org.eclipse.osgi.services_3.5.100.v20160504-1419.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201383928%20org.eclipse.osgi_3.11.2.v20161107-1947.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201304527%20org.eclipse.pde.core_3.11.1.v20161115-1951.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20169036%20org.eclipse.pde.runtime_3.5.0.v20160418-1724.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%208810009%20org.eclipse.platform.doc.user_4.6.1.v20160727-2009.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20510112%20org.eclipse.search_3.11.1.v20161113-1700.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202767389%20org.eclipse.swt.gtk.linux.x86_64_3.105.2.v20161122-0613.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202872411%20org.eclipse.swt.win32.win32.x86_64_3.105.2.v20161122-0613.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2019649%20org.eclipse.swt_3.105.2.v20161122-0613.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20426162%20org.eclipse.team.core_3.8.0.v20160418-1534.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20614115%20org.eclipse.team.cvs.core_3.4.0.v20160418-1534.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2030941%20org.eclipse.team.cvs.ssh2_3.3.0.v20160418-1534.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201790551%20org.eclipse.team.cvs.ui_3.4.0.v20160518-1906.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%201536964%20org.eclipse.team.ui_3.8.0.v20160518-1906.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20269227%20org.eclipse.text_3.6.0.v20160503-1849.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20213276%20org.eclipse.ui.console_3.6.201.v20161107-0337.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20612214%20org.eclipse.ui.editors_3.10.1.v20161106-1856.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20348108%20org.eclipse.ui.forms_3.7.0.v20160518-1929.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2095438%20org.eclipse.ui.ide.application_1.1.101.v20160829-0827.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202384816%20org.eclipse.ui.ide_3.12.2.v20161115-1450.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20328326%20org.eclipse.ui.intro_3.5.2.v20161116-1147.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20162342%20org.eclipse.ui.navigator.resources_3.5.101.v20161006-0640.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20437132%20org.eclipse.ui.navigator_3.6.101.v20161006-1120.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2051165%20org.eclipse.ui.net_1.3.0.v20160426-1633.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2071747%20org.eclipse.ui.trace_1.0.400.v20160509-1055.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20110526%20org.eclipse.ui.views.properties.tabbed_3.7.0.v20160310-0903.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20110524%20org.eclipse.ui.views_3.8.101.v20160816-1954.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2025969%20org.eclipse.ui.win32_3.3.0.v20160505-1310.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20667595%20org.eclipse.ui.workbench.texteditor_3.10.1.v20160818-1626.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%204040836%20org.eclipse.ui.workbench_3.108.2.v20161025-2029.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20396072%20org.eclipse.ui_3.108.1.v20160929-1045.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2090345%20org.eclipse.uml2.common_2.1.0.v20160822-0739.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2018871%20org.eclipse.uml2.types_2.0.0.v20160822-0739.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20102634%20org.eclipse.update.configurator_3.3.400.v20160506-0750.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20362968%20org.sat4j.core_2.3.5.v201308161310.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20241956%20org.sat4j.pb_2.3.5.v201404071733.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%203280108%20org.tigris.subversion.clientadapter.javahl.win64_1.7.8.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20167688%20org.tigris.subversion.clientadapter.javahl_1.7.8.1.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2083885%20org.tigris.subversion.clientadapter_1.8.3.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20328109%20org.tigris.subversion.subclipse.core_1.8.16.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202342932%20org.tigris.subversion.subclipse.doc_1.3.0.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%202054352%20org.tigris.subversion.subclipse.ui_1.8.18.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20109753%20org.tukaani.xz_1.3.0.v201308270617.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2038584%20org.w3c.css.sac_1.3.1.v200903091627.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2018205%20org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2020106%20org.w3c.dom.smil_1.0.1.v200903091627.jar%0A-a----%20%20%20%20%2025%2F06%2F2020%20%2010%3A09%20a.%20m.%20%20%20%20%20%20%20%20%20%2097382%20org.w3c.dom.svg_1.1.0.v201011041433.jar%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EPS%20C%3A%5CNXP%5CSW32G_RTD_4.4_4.0.2_HF03%5Ceclipse%5Cplugins%26gt%3B%20Get-ChildItem%20-Depth%200%0A%0A%0A%20%20%20%20Directory%3A%20C%3A%5CNXP%5CSW32G_RTD_4.4_4.0.2_HF03%5Ceclipse%5Cplugins%0A%0A%0AMode%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20LastWriteTime%20%20%20%20%20%20%20%20%20Length%20Name%0A----%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20-------------%20%20%20%20%20%20%20%20%20------%20----%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A47%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Adc_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20BaseNXP_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20CanIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Can_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Crc_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20CryIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Crypto_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Csm_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Dem_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Det_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Dio_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EcuC_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EcuM_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eep_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EthIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EthSwt_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A48%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20EthTrcv_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2003%3A08%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eth_43_PFE_TS_T40D11M12I0R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Eth_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Fee_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Fls_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20FrIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Fr_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Gpt_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20I2c_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Icu_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A49%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20LinIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Lin_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2015%2F12%2F2025%20%2003%3A08%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Mcl_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Mcu_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20MemIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Ocotp_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Ocu_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Os_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Pcie_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Platform_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Pmic_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Port_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Pwm_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Qdec_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Resource_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Rm_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Rte_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Serdes_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Spi_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Thermal_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Uart_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A50%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20WdgIf_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A51%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Wdg_43_VR5510_TS_T40D11M40I2R0%0Ad-----%20%20%20%20%2012%2F12%2F2025%20%2004%3A51%20p.%20m.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Wdg_TS_T40D11M40I2R0%0A-a----%20%20%20%20%2022%2F08%2F2024%20%2010%3A06%20a.%20m.%20%20%20%20%20%20%20%20%20%20%202746%20com.freescale.tools.tresos.xpath.jar%0A-a----%20%20%20%20%2022%2F08%2F2024%20%2010%3A23%20a.%20m.%20%20%20%20%20%20%20%20%20%20%201757%20com.nxp.tools.tresos.xpath.sqrt.jar%0A-a----%20%20%20%20%2022%2F08%2F2024%20%2010%3A31%20a.%20m.%20%20%20%20%20%20%20%20%20%2029240%20freescale.tresos.flexray.jar%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E6%82%A8%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%AF%94%E8%BE%83%E6%88%91%E4%BB%AC%E7%9A%84%E6%8F%92%E4%BB%B6%E5%AE%89%E8%A3%85%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E4%BB%BB%E4%BD%95%E7%9B%B8%E5%85%B3%E5%B7%AE%E5%BC%82%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%87%8D%E8%A6%81%E5%8C%BA%E5%88%AB%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%B0%9D%E8%AF%95%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20EB%20Tresos%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E5%8F%AF%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E7%BC%A9%E5%B0%8F%E9%97%AE%E9%A2%98%E8%8C%83%E5%9B%B4%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264129%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242651%22%20target%3D%22_blank%22%3E%40Yang_C%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20EB%20Tresos%20Studio%20%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E6%98%AF%E5%90%A6%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242651%22%20target%3D%22_blank%22%3E%40Yang_C%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E4%BD%A0%E8%83%BD%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E7%9A%84%E5%8A%9E%E6%B3%95%E3%80%82%E6%AD%A3%E5%A6%82%E4%BD%A0%E6%89%80%E8%AF%B4%EF%BC%8C%E8%BF%99%E5%BE%88%E5%A5%87%E6%80%AA%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E5%B8%AE%E4%B8%8D%E4%B8%8A%E4%BB%80%E4%B9%88%E5%BF%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%8A%E5%90%8E%E6%82%A8%E9%81%87%E5%88%B0%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%AB%8B%E5%8D%B3%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EB%20tresos%20issue%20-%20module%20cannot%20be%20installed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20alejandro_e%E3%80%81%3C%2FP%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E5%9B%9E%E5%A4%8D%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E4%BA%86%20EB%20tresos%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%BE%88%E5%A5%87%E6%80%AA%EF%BC%8C%E6%88%91%E5%86%B3%E5%AE%9A%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20Eth_43_PFE_TS_T40D11M14I0R0%20%E8%BF%9B%E8%A1%8C%20PFE%20%E9%85%8D%E7%BD%AE%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3E%E6%9D%A8%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
