CodeWarrior on Ubuntu 24
1,306 次查看
boematic2007
I'm trying to connect to a LS1046ARDB using CodeWarrior on Ubuntu 24 - had to install libssl1.1 and libtinfo5.  When using the Connection Diagnostic tool in CodeWarrior I'm getting an error in the "Connect to CodeWarrior Connection Server" step.  Window shows:
CCS: connection to server refused
Failed to connect to locally started CodeWarrior Connection Server
Any ideas on how to get past this?  Using a CodeWarrior TAP USB connection if that helps.
标记 (1)
1,209 次查看
boematic2007
Found the issue.  I had to follow the instructions in the Resolution.docx here:
https://community.nxp.com/t5/Other-NXP-Products/USB-open-failure-with-CodeWarrior-TAP-on-Linux/m-p/1...
After following the instructions I've been able to connect to the target using CodeWarrrior Tap on Ubuntu 24.
1,210 次查看
boematic2007
1,234 次查看
June_Lu
In the INSTALL DIR, run the command "ccs", see the example below to check if you could run ccs.
tic@tic-Latitude-7480:~/Freescale/CW4NET_v2020.06/Common/CCS/bin$ ./ccs
%3CLINGO-SUB%20id%3D%22lingo-sub-2292027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUbuntu%2024%20%E4%B8%8A%E7%9A%84%20CodeWarrior%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E5%9B%BE%E5%9C%A8%20Ubuntu%2024%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E8%BF%9E%E6%8E%A5%20LS1046ARDB%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%AE%89%E8%A3%85%20libssl1.1%20%E5%92%8C%20libtinfo5%E3%80%82%20%E5%9C%A8%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%AD%E7%9A%84%E8%BF%9E%E6%8E%A5%E8%AF%8A%E6%96%AD%E5%B7%A5%E5%85%B7%E6%97%B6%EF%BC%8C%E6%88%91%E5%9C%A8%22%E8%BF%9E%E6%8E%A5%E5%88%B0%20CodeWarrior%20%E8%BF%9E%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%22%20%E6%AD%A5%E9%AA%A4%E4%B8%AD%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%E3%80%82%20%E7%AA%97%E5%8F%A3%E6%98%BE%E7%A4%BA%3C%2FP%3E%3CP%3ECCS%EF%BC%9A%E6%8B%92%E7%BB%9D%E8%BF%9E%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%E6%9C%AC%E5%9C%B0%E5%90%AF%E5%8A%A8%E7%9A%84%20CodeWarrior%20%E8%BF%9E%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%20%E5%A6%82%E6%9E%9C%E6%9C%89%E5%B8%AE%E5%8A%A9%E7%9A%84%E8%AF%9D%EF%BC%8C%E4%BD%BF%E7%94%A8%20CodeWarrior%20TAP%20USB%20%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20on%20Ubuntu%2024%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%89%BE%E5%88%B0%E9%97%AE%E9%A2%98%E4%BA%86%20%E6%88%91%E5%BF%85%E9%A1%BB%E6%8C%89%E7%85%A7%E8%BF%99%E9%87%8C%E7%9A%84%20Resolution.docx%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FUSB-open-failure-with-CodeWarrior-TAP-on-Linux%2Fm-p%2F1952954%23M25444%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FUSB-open-failure-with-CodeWarrior-TAP-on-Linux%2Fm-p%2F1952954%23M25444%3C%2FA%3E%3CBR%20%2F%3E%E6%8C%89%E7%85%A7%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E5%90%8E%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E5%9C%A8%20Ubuntu%2024%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20CodeWarrrior%20Tap%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20on%20Ubuntu%2024%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3E%E5%9C%A8%20INSTALL%20DIR%20%E4%B8%AD%EF%BC%8C%E8%BF%90%E8%A1%8C%E5%91%BD%E4%BB%A4%22ccs%22%20%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%E4%B8%8B%E9%9D%A2%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%20ccs%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3Etic%40tic-Latitude-7480%3A~%2FFreescale%2FCW4NET_v2020.06%2FCommon%2FCCS%2Fbin%24%20.%2Fccs%3C%2FP%3E%3C%2FLINGO-BODY%3E
