CodeWarrior on Ubuntu 24
boematic2007
I'm trying to connect to a LS1046ARDB using CodeWarrior on Ubuntu 24 - had to install libssl1.1 and libtinfo5.  When using the Connection Diagnostic tool in CodeWarrior I'm getting an error in the "Connect to CodeWarrior Connection Server" step.  Window shows:
CCS: connection to server refused
Failed to connect to locally started CodeWarrior Connection Server
Any ideas on how to get past this?  Using a CodeWarrior TAP USB connection if that helps.
boematic2007
Found the issue.  I had to follow the instructions in the Resolution.docx here:
https://community.nxp.com/t5/Other-NXP-Products/USB-open-failure-with-CodeWarrior-TAP-on-Linux/m-p/1...
After following the instructions I've been able to connect to the target using CodeWarrrior Tap on Ubuntu 24.
boematic2007
June_Lu
In the INSTALL DIR, run the command "ccs", see the example below to check if you could run ccs.
tic@tic-Latitude-7480:~/Freescale/CW4NET_v2020.06/Common/CCS/bin$ ./ccs
%3CLINGO-SUB%20id%3D%22lingo-sub-2292027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%20on%20Ubuntu%2024%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20trying%20to%20connect%20to%20a%20LS1046ARDB%20using%20CodeWarrior%20on%20Ubuntu%2024%20-%20had%20to%20install%20libssl1.1%20and%20libtinfo5.%26nbsp%3B%20When%20using%20the%20Connection%20Diagnostic%20tool%20in%20CodeWarrior%20I'm%20getting%20an%20error%20in%20the%20%22Connect%20to%20CodeWarrior%20Connection%20Server%22%20step.%26nbsp%3B%20Window%20shows%3A%3C%2FP%3E%3CP%3ECCS%3A%20connection%20to%20server%20refused%3C%2FP%3E%3CP%3EFailed%20to%20connect%20to%20locally%20started%20CodeWarrior%20Connection%20Server%3C%2FP%3E%3CP%3EAny%20ideas%20on%20how%20to%20get%20past%20this%3F%26nbsp%3B%20Using%20a%20CodeWarrior%20TAP%20USB%20connection%20if%20that%20helps.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20on%20Ubuntu%2024%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EIn%20the%20INSTALL%20DIR%2C%20run%20the%20command%20%22ccs%22%2C%20see%20the%20example%20below%20to%20check%20if%20you%20could%20run%20ccs.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3Etic%40tic-Latitude-7480%3A~%2FFreescale%2FCW4NET_v2020.06%2FCommon%2FCCS%2Fbin%24%20.%2Fccs%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2293438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20on%20Ubuntu%2024%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2293438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFound%20the%20issue.%26nbsp%3B%20I%20had%20to%20follow%20the%20instructions%20in%20the%20Resolution.docx%20here%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FUSB-open-failure-with-CodeWarrior-TAP-on-Linux%2Fm-p%2F1952954%23M25444%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FUSB-open-failure-with-CodeWarrior-TAP-on-Linux%2Fm-p%2F1952954%23M25444%3C%2FA%3E%3CBR%20%2F%3EAfter%20following%20the%20instructions%20I've%20been%20able%20to%20connect%20to%20the%20target%20using%20CodeWarrrior%20Tap%20on%20Ubuntu%2024.%3C%2FP%3E%3C%2FLINGO-BODY%3E
