56F8323 PWM problem
56F8323 PWM problem
kobi
I'm trying to run PWM0 (PWMA0_GPIOA0) in independent center-aligned mode under CW v8.0
I added and configured PWM bean - compilation without any errors - but when I'm trying
to enable output pads it's cause progam reset (doesn't matter if I enable this property
in bean inspector or use OutputPadEnable() command). What could be wrong?
Tags (2)
kobi
ok, problem solved - there was a little shortcircuit on PCB board between PWM and RESET tracks
kobi
