BDM doubt
BDM doubt
994 次查看
isaacmartinezsa
if a program BDM HCS08 series.
can program the "MC9S08SE8CRL"?,
or is there except for a microcontroller?,
I'm new to microcontrollers
778 次查看
carloscuev
Contributor V
If I undestand your question correctly, you want to know if a HCS08 programmer will program a MC9S08SE8CRL. The answer is yes, there's nothing apecial about SE8, has S08 core.
779 次查看
carloscuev
Contributor V
778 次查看
isaacmartinezsa
Same thing that S08 HCS08,
if yes why they put HC?
778 次查看
carloscuev
Contributor V
Yes HCS08 and S08 is the same, what's not the same is HC08 and HCS08. HC08 is the old motorola core, which was updated and now it's called HCS08, or S08 for short.
