VisionSDK_S32V2 demo make error
1,996件の閲覧回数
17816877475
Hello everyone,
I have installed VisionSDK_S32V2_RTM_1_4_0 on my computer, and I want to build project with it  by make tool. So I watched the doc Vision SDK Programming Examples to see how to build an example. I select the most simplest example in /path/to/s32v234_sdk/demos/other/hello, but after I use make command,  the error occured!
My OS is Ubuntu16.04 64-bit, what's wrong with my operation? Any reply is OK.
I think my problem is the compiler, I have read the VisionSDK_UserGuide.pdf, whose chapter 3 describes the Build Environment, I have already add gcc-6.3.1-linaro-Earmv7-eabi/i686-linux/bin/ and gcc-6.3.1-linaro-Xarmv8-linux/i686-linux/bin to the PATH variable and setup the APU_TOOLS. But I don't how to set correct GNU GCC like below.
ywq,
2019.10.15
1,893件の閲覧回数
bpe
Please be aware, that support to APEX, ISP and Vision SDK is currently provided via Tickets only. You will
receive a more detailed response by e-Mail, but for future requests regarding these features and related software,
please use only the link above.
Platon.
