Firmware extraction from S32K144
2,417 次查看
mario_rahal
Hi all,
I've started recently using the S32K144 evb, and first I need to back up a pre flashed firmware, i.e. extracting the hex file safely so that I can reflahsed again when needed. Is there any advice on how to do this? Thanks in advance.
s32k144
hexfile‌
hex‌
1 回复
2,359 次查看
dianabatrlova
If you want to generate .hex file using S32 Design Studio, please, refer to the link below:
HOWTO: Generate S-Record/Intel HEX/Binary file
I hope it helps.
Diana
