Firmware extraction from S32K144
2,344件の閲覧回数
mario_rahal
Hi all,
I've started recently using the S32K144 evb, and first I need to back up a pre flashed firmware, i.e. extracting the hex file safely so that I can reflahsed again when needed. Is there any advice on how to do this? Thanks in advance.
s32k144
hexfile‌
hex‌
ラベル(3)
2,286件の閲覧回数
dianabatrlova
If you want to generate .hex file using S32 Design Studio, please, refer to the link below:
HOWTO: Generate S-Record/Intel HEX/Binary file
I hope it helps.
Diana
