Sub-GHz Remote Control Dimmer: KW01 IEEE 802.15.4 Reference Design
Overview
The Sub-GHz Remote Control Dimmer reference design based on the MKW01Z128 MCU operates in a custom IEEE 802.15.4 star network for home automation applications. Users can control various RGB bulbs connected to a network using the KW01-RCD-RD board as a remote control. Controlled devices are USB-KW019032 boards, and each board simulates an RGB bulb in a GUI.
Features
  • Low-cost MKW01Z128 sub-1GHz wireless node solution with an FSK, GFSK, MSK or OOK modulation-capable transceiver
  • Reference design area with small footprint, low-cost RF node
    • Unbalanced input/output port
    • Flexible RF-Front End for different bands operation
    • Programmable output power from -18 dBm to +13 dBm in 1dB steps (RFIO output)
  • Integrated dual band chip antenna for 800MHz and 900MHz ISM bands
  • Micro-miniature coaxial connector (MMCX) for conducted RF measurements
Block Diagram
Board
Design Resources
%3CLINGO-SUB%20id%3D%22lingo-sub-1118092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESub-GHz%20Remote%20Control%20Dimmer%3A%20KW01%20IEEE%20802.15.4%20Reference%20Design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FSub-GHz-Remote-Control-Dimmer-KW01-IEEE-802-15-4-Reference%2Fta-p%2F1118092%23toc-hId-381647105%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FSub-GHz-Remote-Control-Dimmer-KW01-IEEE-802-15-4-Reference%2Fta-p%2F1118092%23toc-hId--1425807358%22%20target%3D%22_blank%22%3EFeatures%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FSub-GHz-Remote-Control-Dimmer-KW01-IEEE-802-15-4-Reference%2Fta-p%2F1118092%23toc-hId-1061705475%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FSub-GHz-Remote-Control-Dimmer-KW01-IEEE-802-15-4-Reference%2Fta-p%2F1118092%23toc-hId--745748988%22%20target%3D%22_blank%22%3EBoard%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FSub-GHz-Remote-Control-Dimmer-KW01-IEEE-802-15-4-Reference%2Fta-p%2F1118092%23toc-hId-1741763845%22%20target%3D%22_blank%22%3EDesign%20Resources%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381647105%22%20id%3D%22toc-hId-1297609785%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20Sub-GHz%20Remote%20Control%20Dimmer%20reference%20design%20based%20on%20the%20MKW01Z128%20MCU%20operates%20in%20a%20custom%20IEEE%20802.15.4%20star%20network%20for%20home%20automation%20applications.%20Users%20can%20control%20various%20RGB%20bulbs%20connected%20to%20a%20network%20using%20the%20KW01-RCD-RD%20board%20as%20a%20remote%20control.%20Controlled%20devices%20are%20USB-KW019032%20boards%2C%20and%20each%20board%20simulates%20an%20RGB%20bulb%20in%20a%20GUI.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425807358%22%20id%3D%22toc-hId--509844678%22%3EFeatures%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ELow-cost%20MKW01Z128%20sub-1GHz%20wireless%20node%20solution%20with%20an%20FSK%2C%20GFSK%2C%20MSK%20or%20OOK%20modulation-capable%20transceiver%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EReference%20design%20area%20with%20small%20footprint%2C%20low-cost%20RF%20node%20%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EUnbalanced%20input%2Foutput%20port%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EFlexible%20RF-Front%20End%20for%20different%20bands%20operation%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EProgrammable%20output%20power%20from%20-18%20dBm%20to%20%2B13%20dBm%20in%201dB%20steps%20(RFIO%20output)%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EIntegrated%20dual%20band%20chip%20antenna%20for%20800MHz%20and%20900MHz%20ISM%20bands%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMicro-miniature%20coaxial%20connector%20(MMCX)%20for%20conducted%20RF%20measurements%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061705475%22%20id%3D%22toc-hId-1977668155%22%3EBlock%20Diagram%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22REMOTE-CONTROL-DIMER-BD.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22REMOTE-CONTROL-DIMER-BD.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110191i5640FB22D9DC8CA2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22REMOTE-CONTROL-DIMER-BD.png%22%20alt%3D%22REMOTE-CONTROL-DIMER-BD.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EREMOTE-CONTROL-DIMER-BD.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745748988%22%20id%3D%22toc-hId-170213692%22%3EBoard%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RCD_top.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RCD_top.jpg%22%20style%3D%22width%3A%20734px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110215i147767473D86C852%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RCD_top.jpg%22%20alt%3D%22RCD_top.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERCD_top.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RCD_bottom.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RCD_bottom.jpg%22%20style%3D%22width%3A%20837px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110090iB7E91D5FC36FD778%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RCD_bottom.jpg%22%20alt%3D%22RCD_bottom.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERCD_bottom.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1741763845%22%20id%3D%22toc-hId--1637240771%22%3EDesign%20Resources%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELegacy%20Designs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-12-2020 09:34 AM
Updated by:
