S32G Bootloader Customzition
This doc explain how to modify the bootloader to boot linux&mcal, to solve the conflict between bootloader, mcal and linux
本文说明在S32G2 RDB2板上如何定制开发Bootloader,本文示例主要实现功能是:
  • Bootloader启动一个M核,MCAL驱动测试程序,本文分别测试了MCU,DIO,UART的MCAL驱动示例代码。
  • Bootloader同时启动A53 Linux
目录
1    需要的软件,工具,文档与说明... 3
1.1  软件与工具... 3
1.2  参考文档... 3
1.3  开发说明... 3
2    测试软件安装编译说明... 4
2.1  安装RTD_MCAL驱动... 4
2.2  编译MCAL驱动测试程序(以MCU为例) 5
2.3  优化重排M7 demo镜像及与MPU设置的配合... 5
2.4  去掉CLOCK INIT. 7
2.5  去掉MCU相关INIT. 8
2.6  DIO MCAL程序去掉PORT INIT. 9
2.7  UART MCAL程序去掉PORT INIT. 10
2.8  UART MCAL程序修改CLOCK TREE.. 10
2.9  解决中断冲突... 11
2.10 准备A53 Linux镜像... 12
3    Bootloader工程说明... 13
3.1  关掉XRDC支持... 13
3.2  关掉eMMC/SD支持(可选) 14
3.3  关掉secure boot(可选) 14
3.4  增加MCAL驱动所需要的PORT的初始化... 15
3.5  解决Bootloader,MCAL与Linux的clock冲突... 17
3.6  配置A53 Boot sources: 34
3.7  配置M7 Boot sources: 35
3.8  关闭调试软断点:... 36
3.9  编译Bootloader工程... 37
3.10 制造Bootloader的带IVT的镜像... 38
3.11 烧写镜像... 41
4    测试... 42
4.1  硬件连接... 42
4.2  MCU MCAL+Linux测试过程... 42
4.3  DIO MCAL+Linux测试过程... 43
4.4  UART MCAL+Linux测试过程... 43
5    Bootloader源代码说明... 43
6    Bootloader定制说明... 45
6.1  QSPI NOR驱动说明... 45
6.2  eMMC/SDcard启动支持... 46
6.3  DDR初始化... 46
6.4  Secure Boot支持... 46
7    调试说明... 46
7.1  Bootloader的调试... 46
7.2  MCAL驱动的调试... 46
add one more doc to explain how to modify atf to boot on G3.
添付
コメント
Hi John,
just curious - is this document available in english ?
Viktor
uploaded
Thanks a lot for the english version !
Hi John,
Do you have manual for S32G3 bootloader?
Thank you a lot!
which is the same way, just change the bootloader project version to G3.
Hi John
I upload the boot loader to QSPI at address 0 and fip.bin to QSPI at address 0x100000, the probe message is as follow:
NOTICE: Reset status: Power-On Reset
NOTICE: BL2: v2.5(release):bsp37.0-2.5
NOTICE: BL2: Built : 16:13:38, Nov 2 2023
Warning: Instruction at BL33_ENTRYPOINT (0xffaa0000) is 0x0, which is not a B or BL!
NOTICE: BL2: Booting BL31
Why should upload fip.bin to qspi? and the fip.bin seems can't be booted
Thank you!
Hi John
I also tried on S32G3EVB, the console can't probe information.
Hi @Johnli,
    您好!
    目前正在使用S32,您发布的文档对我帮助很大,非常感谢!
    请教您个问题,关于A53相关的clk(core和外设),ATF、uboot、linux三部分之间是什么关系?从您的文档上看,时钟的初始化都是在ATF中,那之后的uboot和linux只是使用者吗,还是说uboot和linux也会重新配置时钟?我的理解,linux也会建立时钟树,但是linux设备树中没有看到。这部分不是很清楚,烦请您帮忙解惑。如果有相关的文档,希望您能分享下。
谢谢!
1: 看一下时钟相关文档S32G_Supplemental_documentation_on_resolving_clock_conflicts_V1-2023.07.03.pdf
2: linux的时钟初始化与配置,是需要传到ATF里的,所以代码在ATF中。
Hi @Johnli
    您好!非常感谢~
    再请教您个问题。我在您分享文档中以及EB中,经常看到 "Under MCU Control",这个是什么作用?我在RM中没有找到相关描述。您能帮忙解答下吗?
谢谢!
就是本工程mcu模块不操作此时钟的意思,在eb中可以查看一个配置项的properties
Hi @Johnli
    您好!
    在ATF中,部分时钟为什么没有定义具体的时钟值,如下图红框中。像这种时钟,系统如何确定最终的时钟值?我跟了下ARM_PLL_VCO的相关寄存器,发现该时钟的大小和允许的最大值相同。
谢谢!
check:
doc&project explain the G3 bootloader customizaiton(similar with G2) to run logger demo https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/S32G-Bootloader-G3-Customization/ta-p/176952...
after bootloader, how to solve the clock conflict to boot ATF https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/S32G-Bootloader-Customzition/ta-p/1519838
你好,请教个问题,我使用BSP38镜像,启动之后在uboot中使用clk dump查询 llce_can_pe的时钟值,显示为0,我看了一下ATF中的设备树配置并没有发现什么问题。
ATF设备树配置
mc_cgm0: mc_cgm0@40030000 {
compatible = "nxp,s32cc-mc_cgm0";
reg = <0x0 0x40030000 0x0 0x3000>;
assigned-clocks =
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX0>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX1>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX2>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX3>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX4>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX5>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX7>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX8>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX9>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX10>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX12>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX14>,
<&plat_clks S32GEN1_CLK_MC_CGM0_MUX16>,
<&plat_clks S32GEN1_CLK_XBAR_2X>,
<&plat_clks S32GEN1_CLK_PER>,
<&plat_clks S32GEN1_CLK_FTM0_REF>,
<&plat_clks S32GEN1_CLK_FTM1_REF>,
<&plat_clks S32GEN1_CLK_CAN_PE>,
<&plat_clks S32GEN1_CLK_LIN_BAUD>,
<&plat_clks S32GEN1_CLK_GMAC0_TS>,
<&plat_clks S32GEN1_CLK_SPI>,
<&plat_clks S32GEN1_CLK_SDHC>,
<&plat_clks S32GEN1_CLK_QSPI_2X>;
assigned-clock-parents =
<&plat_clks S32GEN1_CLK_ARM_PLL_DFS1>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI0>,
<&plat_clks S32GEN1_CLK_FXOSC>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI1>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI2>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI3>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI4>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI5>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_DFS1>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_DFS3>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_PHI7>;
assigned-clock-rates =
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<0>,
<80000000>,
<40000000>,
<40000000>,
<40000000>,
<125000000>,
<200000000>,
<100000000>,
<400000000>,
<S32GEN1_QSPI_2X_CLK_FREQ>;
periphpll: periphpll@4003c000 {
compatible = "nxp,s32cc-periphpll";
reg = <0x0 0x4003c000 0x0 0x3000>;
assigned-clocks =
<&plat_clks S32GEN1_CLK_PERIPH_PLL_MUX>,
<&plat_clks S32GEN1_CLK_PERIPH_PLL_VCO>,
<&plat_clks S32GEN1_CLK_FXOSC>;
<0>,
<S32GEN1_PERIPH_PLL_VCO_FREQ>, <100000000>,
<80000000>, <40000000>,
<125000000>, <200000000>,
<125000000>, <100000000>;
accelpll: accelpll@40040000 {
compatible = "nxp,s32cc-accelpll";
reg = <0x0 0x40040000 0x0 0x3000>;
check the doc: make sure you have load the llce driver ko.
S32G_Bootloader_G3_LLCELOGGER doc&project explain the G3 bootloader customizaiton(similar with G2) to run logger demo https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/S32G-Bootloader-G3-Customization/ta-p/176952...
谢谢!
我在M核发送Can报文,多核启动过程中在Uboot时,Can报文停止了发送。我的ATF配置和@learnx时一样的,麻烦分析一下是什么原因呢?谢谢!@Johnli
Is there an English version of the supplemental document?
你好,我正在调试mcu读写flash,我目前遇到A核启动到uboot阶段,norflash读写正常,但是到linux阶段,norflash功能会异常
uboot阶段 clk dump查看 qspi_flash2x是266666666
linux里dump /sys/kernel/debug/clk/clk_summary里qspi_flash2x是266666666然后变为0
查看dfs1寄存器,dfs1在被reset
请问这个问题如何定位
最终定位到问题为uboot 中board_common.c,在start kernel时board_cleanup_before_linux调用scmi_reset_agent导致,请问如果注释调会由什么影响
%3CLINGO-SUB%20id%3D%22lingo-sub-1519838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1519838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6Linux%E3%81%A8MCAL%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81MCAL%E3%80%81Linux%E9%96%93%E3%81%AE%E7%AB%B6%E5%90%88%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%AC%E6%96%87%E8%AF%B4%E6%98%8E%E5%9C%A8S32G2%20RDB2%E6%9D%BF%E4%B8%8A%E5%A6%82%E4%BD%95%E5%AE%9A%E5%88%B6%E5%BC%80%E5%8F%91Bootloader%EF%BC%8C%E6%9C%AC%E6%96%87%E7%A4%BA%E4%BE%8B%E4%B8%BB%E8%A6%81%E5%AE%9E%E7%8E%B0%E5%8A%9F%E8%83%BD%E6%98%AF%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EBootloader%E5%90%AF%E5%8A%A8%E4%B8%80%E4%B8%AAM%E6%A0%B8%EF%BC%8CMCAL%E9%A9%B1%E5%8A%A8%E6%B5%8B%E8%AF%95%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%9C%AC%E6%96%87%E5%88%86%E5%88%AB%E6%B5%8B%E8%AF%95%E4%BA%86MCU%EF%BC%8CDIO%EF%BC%8CUART%E7%9A%84MCAL%E9%A9%B1%E5%8A%A8%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FLI%3E%0A%3CLI%3EBootloader%E5%90%8C%E6%97%B6%E5%90%AF%E5%8A%A8A53%20Linux%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E7%9B%AE%E5%BD%95%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629623%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E1%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E9%9C%80%E8%A6%81%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%B7%A5%E5%85%B7%EF%BC%8C%E6%96%87%E6%A1%A3%E4%B8%8E%E8%AF%B4%E6%98%8E...%203%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629624%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E1.1%26nbsp%3B%20%E8%BD%AF%E4%BB%B6%E4%B8%8E%E5%B7%A5%E5%85%B7...%203%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629625%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E1.2%26nbsp%3B%20%E5%8F%82%E8%80%83%E6%96%87%E6%A1%A3...%203%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629626%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E1.3%26nbsp%3B%20%E5%BC%80%E5%8F%91%E8%AF%B4%E6%98%8E...%203%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629627%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%B5%8B%E8%AF%95%E8%BD%AF%E4%BB%B6%E5%AE%89%E8%A3%85%E7%BC%96%E8%AF%91%E8%AF%B4%E6%98%8E...%204%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629628%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.1%26nbsp%3B%20%E5%AE%89%E8%A3%85RTD_MCAL%E9%A9%B1%E5%8A%A8...%204%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629629%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.2%26nbsp%3B%20%E7%BC%96%E8%AF%91MCAL%E9%A9%B1%E5%8A%A8%E6%B5%8B%E8%AF%95%E7%A8%8B%E5%BA%8F(%E4%BB%A5MCU%E4%B8%BA%E4%BE%8B)%205%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629630%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.3%26nbsp%3B%20%E4%BC%98%E5%8C%96%E9%87%8D%E6%8E%92M7%20demo%E9%95%9C%E5%83%8F%E5%8F%8A%E4%B8%8EMPU%E8%AE%BE%E7%BD%AE%E7%9A%84%E9%85%8D%E5%90%88...%205%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629631%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.4%26nbsp%3B%20%E5%8E%BB%E6%8E%89CLOCK%20INIT.%207%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629632%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.5%26nbsp%3B%20%E5%8E%BB%E6%8E%89MCU%E7%9B%B8%E5%85%B3INIT.%208%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629633%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.6%26nbsp%3B%20DIO%20MCAL%E7%A8%8B%E5%BA%8F%E5%8E%BB%E6%8E%89PORT%20INIT.%209%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629634%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.7%26nbsp%3B%20UART%20MCAL%E7%A8%8B%E5%BA%8F%E5%8E%BB%E6%8E%89PORT%20INIT.%2010%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629635%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.8%20UART%20MCAL%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AECLOCK%20TREE%E3%81%AE%E4%BF%AE%E6%AD%A3..%2010%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629636%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.9%26nbsp%3B%20%E8%A7%A3%E5%86%B3%E4%B8%AD%E6%96%AD%E5%86%B2%E7%AA%81...%2011%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629637%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E2.10%20%E5%87%86%E5%A4%87A53%20Linux%E9%95%9C%E5%83%8F...%2012%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629638%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bootloader%E5%B7%A5%E7%A8%8B%E8%AF%B4%E6%98%8E...%2013%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629639%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.1%26nbsp%3B%20%E5%85%B3%E6%8E%89XRDC%E6%94%AF%E6%8C%81...%2013%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629640%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.2%26nbsp%3B%20%E5%85%B3%E6%8E%89eMMC%2FSD%E6%94%AF%E6%8C%81(%E5%8F%AF%E9%80%89)%2014%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629641%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.3%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%EF%BC%88%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%8914%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629642%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.4%26nbsp%3B%20%E5%A2%9E%E5%8A%A0MCAL%E9%A9%B1%E5%8A%A8%E6%89%80%E9%9C%80%E8%A6%81%E7%9A%84PORT%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96...%2015%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629643%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.5%26nbsp%3B%20%E8%A7%A3%E5%86%B3Bootloader%2CMCAL%E4%B8%8ELinux%E7%9A%84clock%E5%86%B2%E7%AA%81...%2017%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629644%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.6%26nbsp%3B%20%E9%85%8D%E7%BD%AEA53%20Boot%20sources%3A%2034%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629645%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.7%26nbsp%3B%20%E9%85%8D%E7%BD%AEM7%20Boot%20sources%3A%2035%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629646%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.8%26nbsp%3B%20%E5%85%B3%E9%97%AD%E8%B0%83%E8%AF%95%E8%BD%AF%E6%96%AD%E7%82%B9%EF%BC%9A...%2036%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629647%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.9%26nbsp%3B%20%E7%BC%96%E8%AF%91Bootloader%E5%B7%A5%E7%A8%8B...%2037%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629648%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.10%20%E5%88%B6%E9%80%A0Bootloader%E7%9A%84%E5%B8%A6IVT%E7%9A%84%E9%95%9C%E5%83%8F...%2038%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629649%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3.11%20%E7%83%A7%E5%86%99%E9%95%9C%E5%83%8F...%2041%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629650%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E4%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%B5%8B%E8%AF%95...%2042%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629651%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E4.1%26nbsp%3B%20%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5...%2042%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629652%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E4.2%26nbsp%3B%20MCU%20MCAL%2BLinux%E6%B5%8B%E8%AF%95%E8%BF%87%E7%A8%8B...%2042%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629653%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E4.3%26nbsp%3B%20DIO%20MCAL%2BLinux%E6%B5%8B%E8%AF%95%E8%BF%87%E7%A8%8B...%2043%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629654%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E4.4%26nbsp%3B%20UART%20MCAL%2BLinux%E6%B5%8B%E8%AF%95%E8%BF%87%E7%A8%8B...%2043%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629655%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E5%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bootloader%E6%BA%90%E4%BB%A3%E7%A0%81%E8%AF%B4%E6%98%8E...%2043%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629656%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E6%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Bootloader%E5%AE%9A%E5%88%B6%E8%AF%B4%E6%98%8E...%2045%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629657%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E6.1%26nbsp%3B%20QSPI%20NOR%E9%A9%B1%E5%8A%A8%E8%AF%B4%E6%98%8E...%2045%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629658%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E6.2%26nbsp%3B%20eMMC%2FSDcard%E5%90%AF%E5%8A%A8%E6%94%AF%E6%8C%81...%2046%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629659%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E6.3%26nbsp%3B%20DDR%E5%88%9D%E5%A7%8B%E5%8C%96...%2046%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629660%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E6.4%26nbsp%3B%20Secure%20Boot%E6%94%AF%E6%8C%81...%2046%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629661%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E7%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E8%B0%83%E8%AF%95%E8%AF%B4%E6%98%8E...%2046%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629662%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E7.1%26nbsp%3B%20Bootloader%E7%9A%84%E8%B0%83%E8%AF%95...%2046%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc113629663%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E7.2%26nbsp%3B%20MCAL%E9%A9%B1%E5%8A%A8%E7%9A%84%E8%B0%83%E8%AF%95...%2046%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EG3%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABATF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E6%96%87%E6%9B%B8%E3%82%92%E3%82%82%E3%81%861%E3%81%A4%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1519838%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1993404%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1993404%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%20uboot%20%E3%81%AE%20board_common.c%20%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%80%81board_cleanup_before_linux%20%E3%81%8C%20scmi_reset_agent%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992576%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992576%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82MCU%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81A%E3%82%B3%E3%82%A2%E3%81%8Cuboot%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8norflash%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Linux%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8norflash%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Euboot%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8clk%E3%83%80%E3%83%B3%E3%83%97%E3%83%93%E3%83%A5%E3%83%BCqspi_flash2x%E3%81%AF266666666%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3ELinux%E3%81%AE%E3%83%80%E3%83%B3%E3%83%97%2Fsys%2Fkernel%2Fdebug%2Fclk%2Fclk_summary%E3%81%A7%E3%81%AF%E3%80%81qspi_flash2x%E3%81%AF266666666%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C0%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edfs1%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81dfs1%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910430%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910430%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EM%E3%82%B3%E3%82%A2%E3%81%A7CAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Uboot%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%82%B3%E3%82%A2%E8%B5%B7%E5%8B%95%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%ABCAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AEATF%E8%A8%AD%E5%AE%9A%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F222781%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%40learnx%3C%2FSPAN%3E%3C%2FA%3E%E3%81%95%E3%82%93%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E5%8E%9F%E5%9B%A0%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24888%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%40Johnli%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1881306%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1881306%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9Allce%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90ko%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CTABLE%20width%3D%221166%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20width%3D%22285%22%3ES32G_Bootloader_G3_LLCELOGGER%3C%2FTD%3E%0A%3CTD%20width%3D%22162%22%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E3%83%AD%E3%82%AC%E3%83%BC%E3%83%BB%E3%83%87%E3%83%A2%E5%AE%9F%E8%A1%8C%E7%94%A8G3%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA(G2%E3%81%A8%E5%90%8C%E6%A7%98)%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FTD%3E%0A%3CTD%20width%3D%22719%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FS32G-Bootloader-G3-Customization%2Fta-p%2F1769528%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FS32G-Bootloader-G3-Customization%2Fta-p%2F1769528%3C%2FA%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880465%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880465%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82BSP38%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%80%81uboot%E3%81%A7clk%20dump%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6llce_can_pe%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%80%A4%E3%82%92%E7%85%A7%E4%BC%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%810%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ATF%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E6%A7%8B%E6%88%90%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22learnx_0-1717490794074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22learnx_0-1717490794074.png%22%20style%3D%22width%3A%20363px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F282347i619FA0E0A20F0E57%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22learnx_0-1717490794074.png%22%20alt%3D%22learnx_0-1717490794074.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elearnx_0-1717490794074.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSTRONG%3EATF%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emc_cgm0%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Emc_cgm0%3C%2FSPAN%3E%3CSPAN%3E%40%3C%2FSPAN%3E%3CSPAN%3E40030000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%22nxp%2Cs32cc-mc_cgm0%22%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x40030000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x3000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eassigned-clocks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX2%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX4%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX5%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32GEN1_CLK_MC_CGM0_MUX7%3C%2FSTRONG%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX8%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX9%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX10%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX12%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX14%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_MC_CGM0_MUX16%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_XBAR_2X%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PER%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_FTM0_REF%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_FTM1_REF%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32GEN1_CLK_CAN_PE%3C%2FSTRONG%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_LIN_BAUD%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_GMAC0_TS%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_SPI%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_SDHC%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_QSPI_2X%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eassigned-clock-parents%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_ARM_PLL_DFS1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_FXOSC%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32GEN1_CLK_PERIPH_PLL_PHI2%3C%2FSTRONG%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI4%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI5%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_DFS1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_DFS3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI7%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eassigned-clock-rates%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E80000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E40000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E40000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSTRONG%3E40000000%3C%2FSTRONG%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E125000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E200000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E100000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E400000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_QSPI_2X_CLK_FREQ%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eperiphpll%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eperiphpll%3C%2FSPAN%3E%3CSPAN%3E%40%3C%2FSPAN%3E%3CSPAN%3E4003c000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%22nxp%2Cs32cc-periphpll%22%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x4003c000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x3000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eassigned-clocks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_MUX%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_VCO%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32GEN1_CLK_PERIPH_PLL_PHI2%3C%2FSTRONG%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI4%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI5%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_PERIPH_PLL_PHI7%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eassigned-clock-parents%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Eplat_clks%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_CLK_FXOSC%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eassigned-clock-rates%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3ES32GEN1_PERIPH_PLL_VCO_FREQ%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E100000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E80000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%20%26lt%3B%3C%2FSPAN%3E%3CSTRONG%3E40000000%3C%2FSTRONG%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E125000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E200000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E125000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%2C%20%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E100000000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eaccelpll%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eaccelpll%3C%2FSPAN%3E%3CSPAN%3E%40%3C%2FSPAN%3E%3CSPAN%3E40040000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%22nxp%2Cs32cc-accelpll%22%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26lt%3B%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x40040000%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0x3000%3C%2FSPAN%3E%3CSPAN%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1773901%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1773901%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24888%22%20target%3D%22_blank%22%3E%40Johnli%3C%2FA%3E%3CBR%20%2F%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AE%E8%B5%A4%E3%81%84%E6%9E%A0%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8CATF%E3%81%A7%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%80%A4%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AA%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%80%A4%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9FARM_PLL_VCO%E3%81%AE%E9%96%A2%E9%80%A3%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aiweixin_2-1702467022664.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aiweixin_2-1702467022664.png%22%20style%3D%22width%3A%20379px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F254205i55B6606296309BC5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aiweixin_2-1702467022664.png%22%20alt%3D%22aiweixin_2-1702467022664.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eaiweixin_2-1702467022664.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1773042%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1773042%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AEMCU%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%93%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82EB%E3%81%A7%E3%81%AF%E3%80%81%E6%A7%8B%E6%88%90%E9%A0%85%E7%9B%AE%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1772980%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1772980%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24888%22%20target%3D%22_blank%22%3E%40Johnli%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%E6%82%A8%E5%A5%BD%EF%BC%81%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2~%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%85%B1%E6%9C%89%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%84EB%E3%81%A7%E3%80%8CUnder%20MCU%20Control%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E8%A1%A8%E7%A4%BA%E3%82%92%E3%82%88%E3%81%8F%E8%A6%8B%E3%81%8B%E3%81%91%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E4%BD%95%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9FRM%E3%81%A7%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1771382%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%20Bootloader%20Customzition%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1771382%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E1%3A%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%96%A2%E9%80%A3%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3CA%20id%3D%22link_11%22%20class%3D%22lia-link-navigation%20attachment-link%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FS32G-Bootloader-Customzition%2Ftac-p%2F1771379%2Femcs_t%2FS2h8ZW1haWx8bWVudGlvbl9zdWJzY3JpcHRpb258TFBXQUozUkFGRzZFRjl8MTc3MTM3OXxBVF9NRU5USU9OU3xoSw%3Fattachment-id%3D157652%22%20target%3D%22_blank%22%3ES32G_Supplemental_documentation_on_resolving_clock_conflicts_V1-2023.07.03.pdf%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E2%3A%20Linux%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A8%E6%A7%8B%E6%88%90%E3%81%AF%20ATF%20%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%20ATF%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1750057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1750057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20John%2C%3C%2FP%3E%3CP%3ES32G3%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1541227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1541227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20John%2C%3C%2FP%3E%0A%3CP%3E%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E6%B0%97%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E8%8B%B1%E8%AA%9E%E7%89%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EViktor%3C%2FP%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (4/4)
バージョン履歴
最終更新日:
‎07-03-2023 04:10 AM
更新者:
