RD56F801XPMSMBLDC: PMSM and BLDC Sensorless Motor Control Reference Design using the 56F801X
Overview
This reference design of a 3-phase Permanent Magnet Synchronous Motor (PMSM) sensorless vector control drive and a Brushless DC (BLDC) Motor drive without position encoder coupled to the motor shaft uses the NXP® 56F8013 with Processor Expert® software support.
  • PMSM/BLDC motor are excellent choices for many appliances and industrial applications that require low cost and high-performance variable speed operation
  • This design will employ sensorless FOC to control a PMSM and a sensorless algorithm to control BLDC
  • The hardware design supports both motor types with the algorithms fully implemented digitally via software running on the 56F8013 DSC
Features
General:
  • For PMSM the motor control algorithm employs Field-Oriented Control (FOC). The power stage switches are controlled by means of Space Vector Pulse Width Modulation (SVPWM)
  • The feedback hardware elements are limited to the motor stator phase currents and the bus voltage. No position information devices or stator flux measurement are used; sensorless speed methods are employed
  • The Motor is capable of forward and reverse rotation and has a speed range of 500rpm to 6000rpm
  • The user controls motion profiles, rotation direction, and speed. The RS-232 communication supports further R&D by enabling the easy tuning of control parameters
  • The motor drive system is designed to create minimal acoustic noise
  • Active power factor correction which reduces the negative effects of the load on the power grid in conducted noise and imaginary power
  • Design is low cost
General Benefits:
  • Improved End System Performance
  • Energy savings
  • Quieter operation
  • Improved EMI performance
  • System Cost savings
  • Enhanced Reliability
Performance:
  • Input voltage: 85 ~265VAC
  • Input frequency: 45 ~65HZ
  • Rating bus voltage: 350V
  • Rating output power: 500W
  • Switch frequency of PFC switch: 100KHZ
  • Switch frequency of inverter: 10KHZ
  • Power factor: >95%
  • Efficiency: >90%
Communications:
  • RS232 port for communication with optoisolation
Visual Interface:
  • Multi-segment LED indicators
Block Diagram
Board
Design Resources
%3CLINGO-SUB%20id%3D%22lingo-sub-1099801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERD56F801XPMSMBLDC%3A%20PMSM%20and%20BLDC%20Sensorless%20Motor%20Control%20Reference%20Design%20using%20the%2056F801X%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XPMSMBLDC-PMSM-and-BLDC-Sensorless-Motor-Control%2Fta-p%2F1099801%23toc-hId-360443321%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XPMSMBLDC-PMSM-and-BLDC-Sensorless-Motor-Control%2Fta-p%2F1099801%23toc-hId--1447011142%22%20target%3D%22_blank%22%3EFeatures%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XPMSMBLDC-PMSM-and-BLDC-Sensorless-Motor-Control%2Fta-p%2F1099801%23toc-hId-1040501691%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XPMSMBLDC-PMSM-and-BLDC-Sensorless-Motor-Control%2Fta-p%2F1099801%23toc-hId--766952772%22%20target%3D%22_blank%22%3EBoard%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XPMSMBLDC-PMSM-and-BLDC-Sensorless-Motor-Control%2Fta-p%2F1099801%23toc-hId-1720560061%22%20target%3D%22_blank%22%3EDesign%20Resources%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-360443321%22%20id%3D%22toc-hId-1298495889%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20reference%20design%20of%20a%203-phase%20Permanent%20Magnet%20Synchronous%20Motor%20(PMSM)%20sensorless%20vector%20control%20drive%20and%20a%20Brushless%20DC%20(BLDC)%20Motor%20drive%20without%20position%20encoder%20coupled%20to%20the%20motor%20shaft%20uses%20the%20NXP%C2%AE%2056F8013%20with%20Processor%20Expert%C2%AE%20software%20support.%3C%2FP%3E%3CUL%3E%3CLI%3EPMSM%2FBLDC%20motor%20are%20excellent%20choices%20for%20many%20appliances%20and%20industrial%20applications%20that%20require%20low%20cost%20and%20high-performance%20variable%20speed%20operation%3C%2FLI%3E%3CLI%3EThis%20design%20will%20employ%20sensorless%20FOC%20to%20control%20a%20PMSM%20and%20a%20sensorless%20algorithm%20to%20control%20BLDC%3C%2FLI%3E%3CLI%3EThe%20hardware%20design%20supports%20both%20motor%20types%20with%20the%20algorithms%20fully%20implemented%20digitally%20via%20software%20running%20on%20the%2056F8013%20DSC%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1447011142%22%20id%3D%22toc-hId--508958574%22%3EFeatures%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CEM%3EGeneral%3A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EFor%20PMSM%20the%20motor%20control%20algorithm%20employs%20Field-Oriented%20Control%20(FOC).%20The%20power%20stage%20switches%20are%20controlled%20by%20means%20of%20Space%20Vector%20Pulse%20Width%20Modulation%20(SVPWM)%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EThe%20feedback%20hardware%20elements%20are%20limited%20to%20the%20motor%20stator%20phase%20currents%20and%20the%20bus%20voltage.%20No%20position%20information%20devices%20or%20stator%20flux%20measurement%20are%20used%3B%20sensorless%20speed%20methods%20are%20employed%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EThe%20Motor%20is%20capable%20of%20forward%20and%20reverse%20rotation%20and%20has%20a%20speed%20range%20of%20500rpm%20to%206000rpm%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EThe%20user%20controls%20motion%20profiles%2C%20rotation%20direction%2C%20and%20speed.%20The%20RS-232%20communication%20supports%20further%20R%26amp%3BD%20by%20enabling%20the%20easy%20tuning%20of%20control%20parameters%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EThe%20motor%20drive%20system%20is%20designed%20to%20create%20minimal%20acoustic%20noise%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EActive%20power%20factor%20correction%20which%20reduces%20the%20negative%20effects%20of%20the%20load%20on%20the%20power%20grid%20in%20conducted%20noise%20and%20imaginary%20power%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EDesign%20is%20low%20cost%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CEM%3EGeneral%20Benefits%3A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EImproved%20End%20System%20Performance%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EEnergy%20savings%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EQuieter%20operation%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EImproved%20EMI%20performance%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ESystem%20Cost%20savings%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EEnhanced%20Reliability%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CEM%3EPerformance%3A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EInput%20voltage%3A%2085%20~265VAC%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EInput%20frequency%3A%2045%20~65HZ%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ERating%20bus%20voltage%3A%20350V%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ERating%20output%20power%3A%20500W%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ESwitch%20frequency%20of%20PFC%20switch%3A%20100KHZ%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ESwitch%20frequency%20of%20inverter%3A%2010KHZ%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EPower%20factor%3A%20%26gt%3B95%25%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EEfficiency%3A%20%26gt%3B90%25%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CEM%3ECommunications%3A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ERS232%20port%20for%20communication%20with%20optoisolation%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CEM%3EVisual%20Interface%3A%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMulti-segment%20LED%20indicators%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1040501691%22%20id%3D%22toc-hId-1978554259%22%3EBlock%20Diagram%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XPMSMBLDCBD.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XPMSMBLDCBD.jpg%22%20style%3D%22width%3A%20709px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110280i8EB10DCEC2F8131A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RD56F801XPMSMBLDCBD.jpg%22%20alt%3D%22RD56F801XPMSMBLDCBD.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERD56F801XPMSMBLDCBD.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--766952772%22%20id%3D%22toc-hId-171099796%22%3EBoard%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XPMSMBLDCIMG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XPMSMBLDCIMG.jpg%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110464i7B2E8BFA0DA3D759%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RD56F801XPMSMBLDCIMG.jpg%22%20alt%3D%22RD56F801XPMSMBLDCIMG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERD56F801XPMSMBLDCIMG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1720560061%22%20id%3D%22toc-hId--1636354667%22%3EDesign%20Resources%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1099801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELegacy%20Designs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-09-2020 07:45 PM
Updated by:
