RD3PHASEPMSMVCQE: 3-phase PMSM Vector Control Reference Design based on Kinetis® K40 MCUs
Overview
The 3-phase PMSM Vector Control using Quadrature Encoder on based on Kinetis® K40 MCUs reference design demonstrates the ability of the Kinetis K40 Arm® Cortex®-M4 MCU to drive the advanced motor control application.
  • Targeted at the NXP® Tower® rapid prototyping system as a hardware development platform.
  • Together with available embedded source code, you can quickly build own industrial drive application.
  • For the successful execution of the vector control algorithm, the information on the motor shaft position is critical.
  • The quadrature encoder position information is known in the entire motor speed range, allowing the motor start with full torque at zero speed.
Features
  • Vector control of the PMSM using the quadrature encoder as a position sensor
  • Targeted at the Tower® rapid prototyping system (K40 tower board, Tower 3-phase low voltage power stage)
  • Vector control with a speed closed loop
  • Rotation in both directions
  • Application speed range from 0% to 100% of nominal speed (no field weakening)
  • Operation via the user buttons on the Kinetis® K40 Tower board or via FreeMASTER software
Block Diagram
Design Resources
%3CLINGO-SUB%20id%3D%22lingo-sub-1111317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERD3PHASEPMSMVCQE%3A%203-phase%20PMSM%20Vector%20Control%20Reference%20Design%20based%20on%20Kinetis%C2%AE%20K40%20MCUs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD3PHASEPMSMVCQE-3-phase-PMSM-Vector-Control-Reference-Design%2Fta-p%2F1111317%23toc-hId-381441208%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD3PHASEPMSMVCQE-3-phase-PMSM-Vector-Control-Reference-Design%2Fta-p%2F1111317%23toc-hId--1426013255%22%20target%3D%22_blank%22%3EFeatures%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD3PHASEPMSMVCQE-3-phase-PMSM-Vector-Control-Reference-Design%2Fta-p%2F1111317%23toc-hId-1061499578%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD3PHASEPMSMVCQE-3-phase-PMSM-Vector-Control-Reference-Design%2Fta-p%2F1111317%23toc-hId--745954885%22%20target%3D%22_blank%22%3EDesign%20Resources%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381441208%22%20id%3D%22toc-hId-1298465128%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%203-phase%20PMSM%20Vector%20Control%20using%20Quadrature%20Encoder%20on%20based%20on%20Kinetis%C2%AE%20K40%20MCUs%20reference%20design%20demonstrates%20the%20ability%20of%20the%20Kinetis%20K40%20Arm%C2%AE%20Cortex%C2%AE-M4%20MCU%20to%20drive%20the%20advanced%20motor%20control%20application.%3C%2FP%3E%3CUL%3E%3CLI%3ETargeted%20at%20the%20NXP%C2%AE%20Tower%C2%AE%20rapid%20prototyping%20system%20as%20a%20hardware%20development%20platform.%3C%2FLI%3E%3CLI%3ETogether%20with%20available%20embedded%20source%20code%2C%20you%20can%20quickly%20build%20own%20industrial%20drive%20application.%3C%2FLI%3E%3CLI%3EFor%20the%20successful%20execution%20of%20the%20vector%20control%20algorithm%2C%20the%20information%20on%20the%20motor%20shaft%20position%20is%20critical.%3C%2FLI%3E%3CLI%3EThe%20quadrature%20encoder%20position%20information%20is%20known%20in%20the%20entire%20motor%20speed%20range%2C%20allowing%20the%20motor%20start%20with%20full%20torque%20at%20zero%20speed.%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426013255%22%20id%3D%22toc-hId--508989335%22%3EFeatures%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EVector%20control%20of%20the%20PMSM%20using%20the%20quadrature%20encoder%20as%20a%20position%20sensor%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ETargeted%20at%20the%20Tower%3CSPAN%20style%3D%22font-size%3A%2010.88px%3B%22%3E%3CSUP%3E%C2%AE%3C%2FSUP%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Erapid%20prototyping%20system%20(K40%20tower%20board%2C%20Tower%203-phase%20low%20voltage%20power%20stage)%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EVector%20control%20with%20a%20speed%20closed%20loop%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ERotation%20in%20both%20directions%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EApplication%20speed%20range%20from%200%25%20to%20100%25%20of%20nominal%20speed%20(no%20field%20weakening)%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EOperation%20via%20the%20user%20buttons%20on%20the%20Kinetis%3CSPAN%20style%3D%22font-size%3A%2010.88px%3B%22%3E%3CSUP%3E%C2%AE%3C%2FSUP%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EK40%20Tower%20board%20or%20via%20FreeMASTER%20software%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061499578%22%20id%3D%22toc-hId-1978523498%22%3EBlock%20Diagram%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD3PHASEPMSMVCQE_BD.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD3PHASEPMSMVCQE_BD.jpg%22%20style%3D%22width%3A%20791px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110565iC3F05DFD882E7D46%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RD3PHASEPMSMVCQE_BD.jpg%22%20alt%3D%22RD3PHASEPMSMVCQE_BD.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERD3PHASEPMSMVCQE_BD.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745954885%22%20id%3D%22toc-hId-171069035%22%3EDesign%20Resources%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1111317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELegacy%20Designs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-12-2020 10:32 AM
Updated by:
