read and write for ntag216
4,255件の閲覧回数
459320356
hello,I have many nfc tags Ntag216. which nfc reader/writer soc can easily read and writer it?   pn532 can do that with arm controller?
if so, any lib for pn532 to develop?
thanks for reply.
3 返答(返信)
3,827件の閲覧回数
fernandohcoelho
If your going to work with Arm and Linux, there are some simple libraries written for Mifare Cards in Python, which is not your case. All libraries I found were in C++ and I had to transport it to Java language to work in Arm. Not a complicated task, but takes a lot of testing.
If it is the first time you are using NFC hardware I recomend you use an Atmel MCU + RC522 shield - all libraries are working fine. After understanding the usage you can write your own Arm code.
Regards!
3,827件の閲覧回数
jimmychan
It is a leaflet of NFC solution.
http://www.nxp.com/documents/leaflet/939775017564.pdf
There are EVKs support ntag216. You can find one that meet your needs.
3,827件の閲覧回数
459320356
anybody can help?
