Store user data in PN5180 EEPROM RFU address
1,384 次查看
deniscollis
Contributor V
I want to store a 1-byte checksum in a non-volatile location on the PN5180.  I did not find an EEPROM field reserved for user data. Can I use any EEPROM address that is marked RFU?
标记 (3)
1,221 次查看
Kan_Li
If you won't update the firmware of PN5180 in the future, you may do that, otherwise might cause when the RFU address is used by the latest firmware.
Kan
1,222 次查看
Kan_Li
Kan
