PN7642 jlink error
3,282件の閲覧回数
asknxp
Hi there,
 for a while.
It works pretty well until two days ago.
The detail of the error message is the following. I am wondering if my dev board is bad or something like that.
Any idea what happened and how to fix it?
Thank you very much
--Kenny
ERROR: Could not connect to target.
  SEGGER J-Link GDB Server V7.94b Command Line Version
  JLinkARM.dll V7.94b (DLL compiled Dec 13 2023 16:59:37)
  Command line: -SettingsFile "/source/nfc_pn7642/application/Debug/nfc_pn7642 JLink Debug SettingsFile.jlink" -nosilent -swoport 2337 -select USB=505001876 -jlinkscriptfile /Documents/MCUXpressoIDE_11.9.0_2144/workspace/.mcuxpressoide_packages_support/PN7642_support/Script/pnev7642fama.jlinkscript -telnetport 2338 -singlerun -endian little -noir -speed 4000 -port 2339 -vd -device PN7642 -if SWD -halt -reportuseraction
  -----GDB Server start settings-----
  GDBInit file:                  none
  GDB Server Listening port:     2339
  SWO raw output listening port: 2337
  Terminal I/O port:             2338
  Accept remote connection:      yes
  Generate logfile:              off
  Verify download:               on
  Init regs on start:            off
  Silent mode:                   off
  Single run mode:               on
  Target connection timeout:     0 ms
  ------J-Link related settings------
  J-Link Host interface:         USB
  J-Link script:                 /Documents/MCUXpressoIDE_11.9.0_2144/workspace/.mcuxpressoide_packages_support/PN7642_support/Script/pnev7642fama.jlinkscript
  J-Link settings file:          "/source/nfc_pn7642/application/Debug/nfc_pn7642 JLink Debug SettingsFile.jlink"
  ------Target related settings------
  Target device:                 PN7642
  Target device parameters:      none
  Target interface:              SWD
  Target interface speed:        4000kHz
  Target endian:                 little
  Connecting to J-Link...
  J-Link is connected.
  Device "PN7642" selected.
  Firmware: J-Link Ultra V5 compiled Dec 13 2023 14:34:48
  Hardware: V5.00
  S/N: 505001876
  Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
  Checking target voltage...
  Target voltage: 3.32 V
  Listening on TCP/IP port 2339
  Connecting to target...
  Found SW-DP with ID 0x6BA02477
  DPIDR: 0x6BA02477
  CoreSight SoC-400 or earlier
  Scanning AP map to find all available APs
  AP[1]: Stopped AP scan as end of AP map seems to be reached
  AP[0]: AHB-AP (IDR: 0x84770001)
  Iterating through AP map to find AHB-AP to use
  AP[0]: Skipped. Could not read CPUID register
  Attach to CPU failed. Executing connect under reset.
  DPIDR: 0x6BA02477
  Could not find core in Coresight setup
  DPIDR: 0x6BA02477
  DPIDR: 0x6BA02477
3,248件の閲覧回数
asknxp
OK. Here is what I did to solve the issue.
- After board operates in Mass-Storage mode
- Delete the CRP_00.BIN(180KB)
- Then copy one of the .bin application fw to the drive.
- Then my J-link works again.
Thanks Kelly for the hints.
--Kenny
4 返答(返信)
3,254件の閲覧回数
asknxp
OK. I think I found the documentation for Mass-storage mode to update the firmware.
https://www.nxp.com/docs/en/application-note/AN13134.pdf page 54.
However, I have no idea which file I should put.
[kenny@MBP PN7642_FW_v02.02]$ ls -l
total 1840
-rw-r--r--@ 1 kenny staff 207995 Oct 10 2023 NXP_SLDA.pdf
-rw-r--r--@ 1 kenny staff 115 Oct 6 2023 PN7642_Default_AESChipKey.txt
-rw-r--r--@ 1 kenny staff 5702 Oct 6 2023 PN7642_Default_App_RSAKey.pem
-rw-r--r--@ 1 kenny staff 55036 Dec 15 2022 PN7642_SecureFW_SCR.pdf
-rw-r--r--@ 1 kenny staff 40114 Oct 9 2023 PN7642_v02.F2.esfwu
-rw-r--r--@ 1 kenny staff 1770 Oct 10 2023 ReadMe.txt
-rw-r--r--@ 1 kenny staff 306336 Oct 9 2023 phDnldNfc_UpdateSeq_v02.02.c
-rw-r--r--@ 1 kenny staff 256876 Oct 9 2023 phDnldNfc_UpdateSeq_v02.F2.c
-rw-r--r--@ 1 kenny staff 47842 Oct 9 2023 pn7642_v02.02.esfwu
-rw-r--r--@ 1 kenny staff 232 Oct 6 2023 version.txt
I assume that should be a bin file format.
Here is the screenshot when board operates in Mass-storage mode.
--Kenny
3,249件の閲覧回数
asknxp
--Kenny
3,254件の閲覧回数
asknxp
Hi Kelly,
I believe I am using FW02.02. OK. I will try to update the firmware again. Do you have a quick reference for using Mass-storge mode to update the firmware?
Thanks.
--Kenny
3,258件の閲覧回数
KaiLi
Hello @asknxp
What is your FW version? Or can you enter Mass-storage mode and update the firmware to the latest version (FW02.02)and try again.
kelly
%3CLINGO-SUB%20id%3D%22lingo-sub-1861215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7642%20jlink%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CDIV%3E%E5%90%8C%E3%81%98PN7642%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88(%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frfid-nfc%2Fnfc-hf%2Fnfc-readers%2Fdevelopment-kit-for-pn7642-secure-compact-nfc-controller-with-programmable-memory-and-crypto-acceleration%3AOM27642)%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Frfid-nfc%2Fnfc-hf%2Fnfc-readers%2Fdevelopment-kit-for-pn7642-secure-compact-nfc-controller-with-programmable-memory-and-crypto-acceleration%3AOM27642)%3C%2FA%3E%E3%81%A8Segger%20J-link%20utra%2B(%3CA%20href%3D%22https%3A%2F%2Fwww.segger.com%2Fproducts%2Fdebug-probes%2Fj-link%2Fmodels%2Fj-link-ultra-plus%2F)%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.segger.com%2Fproducts%2Fdebug-probes%2Fj-link%2Fmodels%2Fj-link-ultra-plus%2F)%3C%2FA%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%AE%E9%96%93%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E2%E6%97%A5%E5%89%8D%E3%81%BE%E3%81%A7%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%82%AA%E3%81%84%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%AA%E3%81%AE%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E4%BD%95%E3%81%8B%E8%80%83%E3%81%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E--Kenny%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CBLOCKQUOTE%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%26nbsp%3BSEGGER%20J-Link%20GDB%20Server%20V7.94b%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E7%89%88%3CBR%20%2F%3EJLinkARM.dll%20V7.94b%20(DLL%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%202023%E5%B9%B412%E6%9C%8813%E6%97%A5%2016%3A59%3A37)%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3A%20-SettingsFile%20%22%2Fsource%2Fnfc_pn7642%2Fapplication%2FDebug%2Fnfc_pn7642%20JLink%20Debug%20SettingsFile.jlink%22-nosilent%20-swoport%202337%20-select%20USB%3D505001876%20-jlinkscriptfile%20%2FDocuments%2FMCUXpressoIDE_11.9.0_2144%2Fworkspace%2F.mcuxpressoide_packages_support%2FPN7642_support%2FScript%2Fpnev7642fama.jlinkscript%20-telnetport%202338%20-singlerun%20-endian%20little%20-noir%20-speed%204000%20-port%202339%20-vd%20-device%20PN7642%20-if%20SWD%20-halt%20-reportuseraction%3CBR%20%2F%3E-----GDB%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E8%B5%B7%E5%8B%95%E8%A8%AD%E5%AE%9A-----%3CBR%20%2F%3EGDBInit%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%E3%81%AA%E3%81%97%3CBR%20%2F%3EGDB%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%83%9D%E3%83%BC%E3%83%88%3A%202339%3CBR%20%2F%3ESWO%20RAW%E5%87%BA%E5%8A%9B%E3%83%AA%E3%82%B9%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%9D%E3%83%BC%E3%83%88%3A2337%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%ABI%20%2F%20O%E3%83%9D%E3%83%BC%E3%83%88%3A2338%3CBR%20%2F%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%3A%E3%81%AF%E3%81%84%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E7%94%9F%E6%88%90%3A%E3%82%AA%E3%83%95%3CBR%20%2F%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E7%A2%BA%E8%AA%8D%3A%E3%82%AA%E3%83%B3%3CBR%20%2F%3E%E9%96%8B%E5%A7%8B%E6%99%82%E3%81%AE%20init%20regs%3A%20%E3%82%AA%E3%83%95%3CBR%20%2F%3E%E3%82%B5%E3%82%A4%E3%83%AC%E3%83%B3%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3A%E3%82%AA%E3%83%95%3CBR%20%2F%3E%E5%8D%98%E4%B8%80%E5%AE%9F%E8%A1%8C%E3%83%A2%E3%83%BC%E3%83%89%3A%E3%82%AA%E3%83%B3%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3A%200%20%E3%83%9F%E3%83%AA%E7%A7%92%3CBR%20%2F%3E------J-Link%E9%96%A2%E9%80%A3%E3%81%AE%E8%A8%AD%E5%AE%9A------%3CBR%20%2F%3EJ-Link%E3%83%9B%E3%82%B9%E3%83%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3AUSB%3CBR%20%2F%3EJ-Link%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%20%2FDocuments%2FMCUXpressoIDE_11.9.0_2144%2Fworkspace%2F.mcuxpressoide_packages_support%2FPN7642_support%2FScript%2Fpnev7642fama.jlinkscript%3CBR%20%2F%3E%26nbsp%3BJ-Link%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%E3%80%8C%2Fsource%2Fnfc_pn7642%2Fapplication%2FDebug%2Fnfc_pn7642%20JLink%20Debug%20SettingsFile.jlink%E3%80%8D%3CBR%20%2F%3E%26nbsp%3B------%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E9%96%A2%E9%80%A3%E3%81%AE%E8%A8%AD%E5%AE%9A------%3CBR%20%2F%3E%E5%AF%BE%E8%B1%A1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3APN7642%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3A%E3%81%AA%E3%81%97%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3ASWD%3CBR%20%2F%3E%E7%9B%AE%E6%A8%99%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E9%80%9F%E5%BA%A6%3A4000kHz%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%3A%E3%83%AA%E3%83%88%E3%83%AB%3CBR%20%2F%3EJ-Link%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3EJ-Link%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8CPN7642%E3%80%8D%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20J-Link%20Ultra%20V5%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%202023%20%E5%B9%B4%2012%20%E6%9C%88%2013%20%E6%97%A5%2014%3A34%3A48%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3AV5.00%3CBR%20%2F%3ES%20%2F%20N%3A505001876%3CBR%20%2F%3E%E6%A9%9F%E8%83%BD%3ARDI%E3%80%81FlashBP%E3%80%81FlashDL%E3%80%81JFlash%E3%80%81GDB%3CBR%20%2F%3E%E7%9B%AE%E6%A8%99%E9%9B%BB%E5%9C%A7%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E9%9B%BB%E5%9C%A7%3A3.32V%3CBR%20%2F%3ETCP%2FIP%20%E3%83%9D%E3%83%BC%E3%83%88%202339%20%E3%81%A7%E3%83%AA%E3%83%83%E3%82%B9%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3EID%200x6BA02477%E3%81%AESW-DP%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A0x6BA02477%3CBR%20%2F%3ECoreSight%20SoC-400%E4%BB%A5%E5%89%8D%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEAP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEAP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%3CBR%20%2F%3EAP%5B1%5D%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81AP%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001)%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20AHB-AP%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%20%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3BDPIDR%3A0x6BA02477%3CBR%20%2F%3ECoreSight%20SoC-400%E4%BB%A5%E5%89%8D%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEAP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEAP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%3CBR%20%2F%3EAP%5B1%5D%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81AP%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001)%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20AHB-AP%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3EID%200x6BA02477%E3%81%AESW-DP%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A0x6BA02477%3CBR%20%2F%3ECoreSight%20SoC-400%E4%BB%A5%E5%89%8D%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEAP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEAP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%3CBR%20%2F%3EAP%5B1%5D%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81AP%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001)%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20AHB-AP%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3E%26nbsp%3B%3CFONT%20color%3D%22%23ff0000%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EAP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FFONT%3E%3CBR%20%2F%3ECPU%20%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3BDPIDR%3A0x6BA02477%3CBR%20%2F%3ECoreSight%20SoC-400%E4%BB%A5%E5%89%8D%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEAP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEAP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%3CBR%20%2F%3EAP%5B1%5D%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81AP%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001)%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20AHB-AP%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3E%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CFONT%20color%3D%22%23ff0000%22%3EAP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FFONT%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20jlink%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%8C%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20After%20Board%E3%81%8CMass-Storage%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E-%20CRP_00.BIN%E3%81%AE%E5%89%8A%E9%99%A4(180KB)%3C%2FP%3E%3CP%3E-%20%E6%AC%A1%E3%81%AB%E3%80%81.bin%E3%81%AE1%E3%81%A4%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AB%20fw%20%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81J-link%E3%81%8C%E5%86%8D%E3%81%B3%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E3%81%8F%E3%82%8C%E3%81%9F%E3%82%B1%E3%83%AA%E3%83%BC%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E--Kenny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20jlink%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%9E%E3%82%B9%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13134.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13134.pdf%3C%2FA%3E%26nbsp%3B54%E3%83%9A%E3%83%BC%E3%82%B8%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%BD%AE%E3%81%91%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%5Bkenny%40MBP%20PN7642_FW_v02.02%5D%24%20ls%20-l%3CBR%20%2F%3E%E5%90%88%E8%A8%88%201840%3CBR%20%2F%3E-rw-r--r-%401%20%E3%82%B1%E3%83%8B%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%83%E3%83%95%20207995%202023%E5%B9%B410%E6%9C%8810%E6%97%A5%20NXP_SLDA.pdf%3CBR%20%2F%3E-rw-r--r-%401%20kenny%20staff%20115%202023%E5%B9%B410%E6%9C%886%E6%97%A5%20PN7642_Default_AESChipKey.txt%3CBR%20%2F%3E-rw-r--r-%401%20Kenny%20Staff%205702%202023%E5%B9%B410%E6%9C%886%E6%97%A5%20PN7642_Default_App_RSAKey.pem%3CBR%20%2F%3E-rw-r--r-%401%20kenny%20staff%2055036%202022%E5%B9%B412%E6%9C%8815%E6%97%A5%20PN7642_SecureFW_SCR.pdf%3CBR%20%2F%3E-rw-r--r--%40%201%20Kenny%20Staff%2040114%202023%E5%B9%B410%E6%9C%889%E6%97%A5%20PN7642_v02.F2.esfwu%3CBR%20%2F%3E-rw-r--r-%401%20%E3%82%B1%E3%83%8B%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%83%E3%83%95%201770%202023%E5%B9%B410%E6%9C%8810%E6%97%A5%20ReadMe.txt%3CBR%20%2F%3E-rw-r--r-%401%20%E3%82%B1%E3%83%8B%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%83%E3%83%95%20306336%202023%E5%B9%B410%E6%9C%889%E6%97%A5%20phDnldNfc_UpdateSeq_v02.02.c%3CBR%20%2F%3E-rw-r--r-%401%20%E3%82%B1%E3%83%8B%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%83%E3%83%95%20256876%202023%E5%B9%B410%E6%9C%889%E6%97%A5%20phDnldNfc_UpdateSeq_v02.F2.c%3CBR%20%2F%3E-rw-r--r-%401%20Kenny%20staff%2047842%202023%E5%B9%B410%E6%9C%889%E6%97%A5%20pn7642_v02.02.esfwu%3CBR%20%2F%3E-rw-r--r-%401%20%E3%82%B1%E3%83%8B%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%83%E3%83%95%20232%202023%E5%B9%B410%E6%9C%886%E6%97%A5%20version.txt%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8Cbin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E5%A4%A7%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22asknxp_0-1715174151097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22asknxp_0-1715174151097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277756i84C97E9245D4481C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22asknxp_0-1715174151097.png%22%20alt%3D%22asknxp_0-1715174151097.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E--Kenny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20jlink%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B1%E3%83%AA%E3%83%BC%E3%80%81%3C%2FP%3E%3CP%3EFW02.02%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B4%E6%96%B0%E3%82%92%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Mass-storge%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E--Kenny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20jlink%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F180883%22%20target%3D%22_blank%22%3E%40asknxp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEFW%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E5%A4%A7%E5%AE%B9%E9%87%8F%E8%A8%98%E6%86%B6%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3(FW02.02)%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%82%84%E3%82%8A%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B1%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
