Hello joshgott,
See the excel calculator in the attachment. Based on the inputs values (VDD voltage and complex impedance), you can calculate the expected TVDD current.
See an example below.
For V_TVDD=4V, and target impedance (14-1i) Ohm. The target current would be approx. 220 mA .
Please note that this calculation is a bit simplified. So if possible, we recommend to measure the current after the impedance tuning.
Tomas
