I have an empty Mifare Classic card and want to encrypt memory in just one sector by changing the key for that sector.
However since this is an empty card all sectors have the default key FF FF FF FF FF FF.
Should I change the key for all the other sectors as well even though they are unused and empty?
Solved! Go to Solution.
Hello!
Yes, it is advised to change ALL keys on MIFARE Classic cards away from the default values (even the key for Sector0)
Please refer to the document "AN11302 - End to end system security risk considerations for implementing MIFARE Classic" which describes possible attacks and countermeasures on MIFARE Classic.
Please be also aware that for storing sensitive data, its not advised to use MIFARE Classic, but rather a more secure MIFARE card like DESFire Light.
Florian
Hello!
Florian
