OM26630FDK 'correct microcontroller firmware'
2,930件の閲覧回数
lorenzomarcanto
We bought a OM26630FDK kit to test the NFC reader kit; the NFC Cockpit software downloaded and installed properly, also the board is detected correctly (it's seen as COM6). However the log panel says "please use the correct microcontroller firmware for the cockpit version in use". Shouldn't be the kit ready to use? how to make it work?
2,361件の閲覧回数
IvanRuiz
Please flash the binary (BootLoader_And_Nfcrdlib_SimplifiedAPI_EMVCo_Secondary.bin) contained in Cockpit firmware for CLRC663, it is by default in the following path: C:\...\NxpNfcCockpit_v4.7.0.0\firmware\Secondary_RC663
You may flash it by using the MCUXPresso Flash programmer tool. You can take this as reference to know where the tool is:
https://community.nxp.com/thread/449152?commentID=896950#comment-896950
Ivan.
