PN1720 on Yocto -Linux.
maksimaltunin
Hi all,
we try to start the nfc board PN7120 on Yocto. Please Help. We see follow errors:
## NFC demo ##
## Poll mode activated ##
... press enter to quit ...
NxpExtns: find found NXPLOG_TML_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_FWDNLD_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_NCIX_LOGLEVEL=(0x3)
NxpExtns: find found NXPLOG_NCIR_LOGLEVEL=(0x3)
NxpHal: Entering phNxpNciHal_init_monitor
NxpHal: Returning with SUCCESS
NxpTml: Opening port=/dev/pn544
NxpTml: phTmlNfc_i2c_reset(), VEN level 1
NxpTml: phTmlNfc_i2c_reset(), VEN level 0
NxpTml: PN54X - Tml Reader Thread Startepn54x_dev_write : i2c_master_send returned -11
d................
NxpTml: PN54X - Read requested.....
Npn54x_dev_write : i2c_master_send returned -11
xpTml: PN54X - Invoking I2C Read.....
NxpTml: PN54X - pn54x_dev_write : i2c_master_send returned -11
Tml Writer Thread Started................
Tml Writer Thread Running................
Write requested.....
NxpTml: PN54X - Invoking I2C Write...pn54x_dev_write : i2c_master_send returned -11
NxpHal: thread started
NxpTml: _i2c_write() errno : 5
NxpTml: PN54X - Error in I2C Write.....
NxpTml: PN54X - Posting Fresh Write message.....
NxpTml: PN54X - Tml Writer Thread Running................
NxpHal: write error status = 0x1ff
NxpHal: write_unlocked failed - PN54X Maybe in Standby Mode - Retry
NxpTml: PN54X - Write requested.....
NxpTml: PN54X - Invoking I2C Write.....
NxpHal: write_unlocked failed - PN54X Maybe in Standby Mode (max count = 0x6)
NxpTml: phTmlNfc_i2c_reset(), VEN level pn54x_dev_read: i2c_master_recv returned -11
0
NxpTml: _i2c_read() [hdr] erpn54x_dev_read: i2c_master_recv returned -11
rno : b
NxpTml: PN54X - Erropn54x_dev_read: i2c_master_recv returned -11
r in I2C Read.....
NxpTml: pn54x_dev_read: i2c_master_recv returned -11
Npn54x_dev_read: i2c_master_recv returned -11
xpTml: PN54X - Invoking I2C Rpn54x_dev_read: i2c_master_recv returned -11
ead.....
NxpTml: _i2c_readpn54x_dev_read: i2c_master_recv returned -11
() [hdr] errno : b
NxpTml: Ppn54x_dev_read: i2c_master_recv returned -11
N54X - Error in I2C Read.....
NxpTml: PN54X - Read requestepn54x_dev_read: i2c_master_recv returned -11
d.....
NxpTml: PN54X - Invpn54x_dev_read: i2c_master_recv returned -11
oking I2C Read.....
_i2c_read() [hdr] errno : b
Nxpn54x_dev_read: i2c_master_recv returned -11
pTml: PN54X - Error in I2C Repn54x_dev_read: i2c_master_recv returned -11
ad.....
NxpTml: PN54X - Repn54x_dev_read: i2c_master_recv returned -11
ad requested.....
rno : b
r in I2C Read.....
ead.....
() [hdr] errno : b
d.....
oking I2C Read.....
pTml: PN54X - Error in I2C Read.....
NxpTml: PN54X - Invoking I2C Read.....
NxpTml: _i2c_read() [hdr] errno : b
NxpTml: PN54X - Error in I2C Read.....
NxpTpn54x_dev_read: i2c_master_recv returned -11
NxpHal: PN54X Reset - SUCCESS
NxpHal: phNxpNciHal_write failed for hal ext
NxpHal: Force FW Download, NFCC not coming out from Standby
The driver is running:
Module Size Used by Tainted: G
fusion 116695 8
g_serial 3865 0
libcomposite 44818 1 g_serial
configfs 28596 2 libcomposite
wlan 3030973 0
pn5xx_i2c 10181 0
nexis 13565 0
any ideas?
thank you in advance
UPDATE from 09.05.2018 ----------------------------------------------------------------------------------------------------------------------
1. start i2cdetect 0 -y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- UU -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: UU -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
2. start nfcDemo poll
## NFC demo ##
NxpTml: phTmlNfc_i2c_open_and_configure
NxpTml: PN54X - Tml Writer Thread Started................
NxpHal: NxpTml: PN54X - Write requested.....
thread started
NxpTml: PN54X - Tml Reader Thread Started................
NxpNciX: len = 4 > 20000101
NxpTml: PN54X - I2C Write successful.....
NxpHal: write successful status = 0x0
NxpHal: Response timer started
NxpHal: Waiting after ext cmd sent
NxpHal: hal_extns_write_rsp_timeout_cb - write timeout!!!
NxpHal: Response timer stopped
NxpHal: Callback Status is failed!! Timer Expired!! Couldn't read it! 0xff
NxpHal: NCI_CORE_RESET: Failed
NxpHal: Power Cycle
NxpTml: PN54X - I2C Read successful.....
NxpNciR: len = 131 > 00008097A2861511061818082700C012CF0004903F120A027A690420481288000000005E002000045040000000000000000000005002000001000880B2000000800000000000400000D0D30000000A400500004000000000000000001A4040A00500000000000000000000000000000000000000000000000000000000000000000000
NxpTml: PN54X - Posting read message.....
NxpHal: read successful status = 0x0
NxpTml: _i2c_read() [pyld] EOF
PN54X - Error in I2C Read....pn54x_dev_read: i2c_master_recv returned -11
NxpTml: PN54X - Read reqpn54x_dev_read: i2c_master_recv returned -11
uested.....
NxpTml: PN54X pn54x_dev_read: i2c_master_recv returned -11
NxpTmpn54x_dev_read: i2c_master_recv returned -11
l: _i2c_read() [hdr] errno : pn54x_dev_read: i2c_master_recv returned -11
b
NxpTml: PN54X - Error in Ipn54x_dev_read: i2c_master_recv returned -11
2C Read.....
NxpTml: PN54Xpn54x_dev_read: i2c_master_recv returned -11
NxpTml:pn54x_dev_read: i2c_master_recv returned -11
PN54X - Invoking I2C Read...pn54x_dev_read: i2c_master_recv returned -11
NxpTml: _i2c_read() [hdpn54x_dev_read: i2c_master_recv returned -11
r] errno : b
NxpTml: PN54X -pn54x_dev_read: i2c_master_recv returned -11
NxpTmlpn54x_dev_read: i2c_master_recv returned -11
: PN54X - Read requested.....pn54x_dev_read: i2c_master_recv returned -11
NxpTml: PN54X - Invoking pn54x_dev_read: i2c_master_recv returned -11
I2C Read.....
NxpTml: _i2cpn54x_dev_read: i2c_master_recv returned -11
NxpTml: _i2c_read() [hdr] errpn54x_dev_write : i2c_master_send returned -11
no : b
NxpTml: pn54x_dev_write : i2c_master_send returned -11
NxpTml: PN54X - Invoking I2C Rpn54x_dev_write : i2c_master_send returned -11
ead.....
NxpTml: PN54X - Read requespn54x_dev_write : i2c_master_send returned -11
ted.....
NxpTml:pn54x_dev_write : i2c_master_send returned -11
NxpHal: write errpn54x_dev_read: i2c_master_recv returned -11
or status = 0x1ff
NxpHal: wrpn54x_dev_read: i2c_master_recv returned -11
ite_unlocked failed - PN54X Maybepn54x_dev_read: i2c_master_recv returned -11
PN54X - Write requested.....pn54x_dev_read: i2c_master_recv returned -11
I2C Write.....
NxpTml: _i2pn54x_dev_read: i2c_master_recv returned -11
c_write() errno : 5
NxpTml: PN54X - Posting Frepn54x_dev_read: i2c_master_recv returned -11
PN54X - Tml Writer Thread Runpn54x_dev_read: i2c_master_recv returned -11
NxpHal: pn54x_dev_read: i2c_master_recv returned -11
pHal: write_unlocked failed -pn54x_dev_read: i2c_master_recv returned -11
PN54X Maybe in Standby Mode - Repn54x_dev_read: i2c_master_recv returned -11
try
NxpTml: PN54X - Write repn54x_dev_read: i2c_master_recv returned -11
quested.....
Nxppn54x_dev_read: i2c_master_recv returned -11
NxpTml: PN54X - Error in I2C pn54x_dev_read: i2c_master_recv returned -11
Write.....
NxpTml: _i2c_read() [hdr] errnpn54x_dev_read: i2c_master_recv returned -11
o : b
NxpHal:pn54x_dev_write : i2c_master_send returned -11
NxpHal: Force FW Dpn54x_dev_write : i2c_master_send returned -11
NxpExtns: find foundpn54x_dev_write : i2c_master_send returned -11
MIFARE_READER_ENABLE=(0x1)
NxpTml: PN54X - Write requestepn54x_dev_write : i2c_master_send returned -11
d.....
NxpTml: PN54X - Error in I2C Writepn54x_dev_write : i2c_master_send returned -11
0
rno : b
r in I2C Read.....
ead.....
() [hdr] errno : b
d.....
oking I2C Read.....
ad.....
ad requested.....
rno : b
r in I2C Read.....
ead.....
() [hdr] errno : b
d.....
oking I2C Read.....
3. i2cdetect 0 -y
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
My i2c intaface is not working after execute nfcDemoApp from nxp. Please help
Tags (2)
jimmychan
I think this may useful for you.
https://community.nxp.com/docs/DOC-331906
