NXP Tagwriter - Write from CSV
7,501 次查看
chrisong_what
Hi Sir/Madam,
Good day to you.
Kindly check with you the CSV file if i want to add more records in a row, is it possible can do?
Thanks.
Christopher
标记 (3)
7,200 次查看
t_kubicek
Hallo, could you please provide me the correct vcard template how to write multiple contacts eg. up to 200 contacts via NFC NXP TAGWriter into multiple NFC cards.
Please check also my template attached which NXP writer does not accept.
Thanks Tomas
7,374 次查看
IvanRuiz
Thank you for contacting us. I just checked your case; basically the app allows you to write comma separated values but not more than one record per row, this means that despite you write it either on CSV or "normal" format, you could only add one record per row, please see below for an example of the Comma Separated Value:
Have a nice day!
BR,
Ivan.
4,455 次查看
sipos93
Hi @IvanRuiz
Could I also request a sample of how the CSV content should look like for the application to accept it?
I just want to save plain URL addresses.
For example:
https://1.com
https://2.com
https://3.com
