NTAG5 Link: Single SRAM Block Write Not Triggering I2C Master Read - Full SRAM Write Works
ソリューションへジャンプ
1,490件の閲覧回数
kavya_ap
I'm implementing  pass-through application using NTAG5 Link (NTP53x2). The system writes small configuration data blocks to SRAM via NFC and reads them via I2C on an embedded MCU.
Current Findings:
  • Single SRAM block write: ED pin does not trigger because it's not the last byte of the 256-byte SRAM
  • Full SRAM write: Works reliably - ED pin triggers and I2C master can read the data
  • Workaround attempted: Configured ED pin with ED_CONFIG = 1100b (trigger on SYNCH_BLOCK write) and set the target data block as the SYNCH_DATA_BLOCK - still no result.
    Is there a configuration method in NTAG5 Link that allows the ED pin to reliably trigger on a single SRAM block write without requiring the entire SRAM to be written? If not, what is the recommended approach for efficient small-data transfers in pass-through mode?
1,465件の閲覧回数
EduardoZamora
Hello @kavya_ap
Hope you are doing well.
There may not be a direct implementation to trigger ED pin on single SRAM block write. As you mention, pass-through mode expects SRAM write from 00h to 3Fh in order to trigger ED pin, as depicted in NTAG 5 - Bidirectional data exchange, Figure 1.
For proper pass-through implementation, please stick to the procedures and recommendations described in NTAG 5 - Bidirectional data exchange.
Eduardo.
2 返答(返信)
1,466件の閲覧回数
EduardoZamora
Hello @kavya_ap
Eduardo.
1,394件の閲覧回数
kavya_ap
Thank you so much.
%3CLINGO-SUB%20id%3D%22lingo-sub-2247386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENTAG5%20%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%E5%8D%98%E4%B8%80%20SRAM%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%A7%E3%81%AF%20I2C%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%20-%20%E3%83%95%E3%83%AB%20SRAM%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ENTAG5%E3%83%AA%E3%83%B3%E3%82%AF%EF%BC%88NTP53x2%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81NFC%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E5%B0%8F%E3%81%95%E3%81%AA%E6%A7%8B%E6%88%90%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%20SRAM%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%80%81%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%20MCU%20%E4%B8%8A%E3%81%AE%20I2C%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%AA%BF%E6%9F%BB%E7%B5%90%E6%9E%9C%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%8D%98%E4%B8%80SRAM%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3A%20256%E3%83%90%E3%82%A4%E3%83%88SRAM%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81ED%E3%83%94%E3%83%B3%E3%81%AF%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%AE%8C%E5%85%A8%E3%81%AASRAM%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3A%20%E7%A2%BA%E5%AE%9F%E3%81%AB%E5%8B%95%E4%BD%9C%20-%20ED%E3%83%94%E3%83%B3%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%80%81I2C%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8BCAN%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3A%20ED%20%E3%83%94%E3%83%B3%E3%82%92%20ED_CONFIG%20%3D%201100b%20(SYNCH_BLOCK%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%99%82%E3%81%AB%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%20SYNCH_DATA_BLOCK%20%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E7%B5%90%E6%9E%9C%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3ENTAG5%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%AF%E3%80%81ED%E3%83%94%E3%83%B3%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ESRAM%20%E5%85%A8%E4%BD%93%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%9B%E3%81%9A%E3%81%AB%E5%8D%98%E4%B8%80%E3%81%AE%20SRAM%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AB%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%BB%A2%E9%80%81%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2247791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTAG5%20Link%3A%20Single%20SRAM%20Block%20Write%20Not%20Triggering%20I2C%20Master%20Read%20-%20Full%20SRAM%20Write%20Works%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257240%22%20target%3D%22_blank%22%3E%40kavya_ap%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%AA%BF%E5%AD%90%E3%81%8C%E8%89%AF%E3%81%84%E3%81%A8%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8D%98%E4%B8%80%E3%81%AE%20SRAM%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%99%82%E3%81%AB%20ED%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%99%E3%82%8B%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%AA%E5%AE%9F%E8%A3%85%E3%81%AF%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E6%8C%87%E6%91%98%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12364.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENTAG%205%20-%20%E5%8F%8C%E6%96%B9%E5%90%91%E3%83%87%E3%83%BC%E3%82%BF%E4%BA%A4%E6%8F%9B%3C%2FA%3E%E3%80%81%E5%9B%B3%201%20%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81ED%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%2000h%20%E3%81%8B%E3%82%89%203Fh%20%E3%81%B8%E3%81%AE%20SRAM%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%91%E3%82%B9%E3%82%B9%E3%83%AB%E3%83%BC%E5%AE%9F%E8%A3%85%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12364.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%8CNTAG%205%20-%20%E5%8F%8C%E6%96%B9%E5%90%91%E3%83%87%E3%83%BC%E3%82%BF%E4%BA%A4%E6%8F%9B%E3%80%8D%3C%2FA%3E%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%A8%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%89%E3%82%A5%E3%82%A2%E3%83%AB%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTAG5%20Link%3A%20Single%20SRAM%20Block%20Write%20Not%20Triggering%20I2C%20Master%20Read%20-%20Full%20SRAM%20Write%20Works%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FLINGO-BODY%3E
