NTAG5 Link: Single SRAM Block Write Not Triggering I2C Master Read - Full SRAM Write Works
1,445 次查看
kavya_ap
I'm implementing  pass-through application using NTAG5 Link (NTP53x2). The system writes small configuration data blocks to SRAM via NFC and reads them via I2C on an embedded MCU.
Current Findings:
  • Single SRAM block write: ED pin does not trigger because it's not the last byte of the 256-byte SRAM
  • Full SRAM write: Works reliably - ED pin triggers and I2C master can read the data
  • Workaround attempted: Configured ED pin with ED_CONFIG = 1100b (trigger on SYNCH_BLOCK write) and set the target data block as the SYNCH_DATA_BLOCK - still no result.
    Is there a configuration method in NTAG5 Link that allows the ED pin to reliably trigger on a single SRAM block write without requiring the entire SRAM to be written? If not, what is the recommended approach for efficient small-data transfers in pass-through mode?
1,420 次查看
EduardoZamora
Hello @kavya_ap
Hope you are doing well.
There may not be a direct implementation to trigger ED pin on single SRAM block write. As you mention, pass-through mode expects SRAM write from 00h to 3Fh in order to trigger ED pin, as depicted in NTAG 5 - Bidirectional data exchange, Figure 1.
For proper pass-through implementation, please stick to the procedures and recommendations described in NTAG 5 - Bidirectional data exchange.
Eduardo.
1,421 次查看
EduardoZamora
Hello @kavya_ap
Eduardo.
1,349 次查看
kavya_ap
Thank you so much.
%3CLINGO-SUB%20id%3D%22lingo-sub-2247386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENTAG5%20%E9%93%BE%E6%8E%A5%EF%BC%9A%E5%8D%95%20SRAM%20%E6%95%B0%E6%8D%AE%E5%9D%97%E5%86%99%E5%85%A5%E6%9C%AA%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20I2C%20%E4%B8%BB%E8%AF%BB%E5%8F%96-%E5%AE%8C%E5%85%A8%20SRAM%20%E5%86%99%E5%85%A5%E6%9C%89%E6%95%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20NTAG5%20Link%20(NTP53x2)%20%E5%AE%9E%E7%8E%B0%E7%9B%B4%E9%80%9A%E5%BA%94%E7%94%A8%E3%80%82%E7%B3%BB%E7%BB%9F%E9%80%9A%E8%BF%87%20NFC%20%E5%B0%86%E5%B0%8F%E5%9E%8B%E9%85%8D%E7%BD%AE%E6%95%B0%E6%8D%AE%E5%9D%97%E5%86%99%E5%85%A5%20SRAM%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%E5%B5%8C%E5%85%A5%E5%BC%8F%20MCU%20%E4%B8%8A%E7%9A%84%20I2C%20%E8%AF%BB%E5%8F%96%E8%BF%99%E4%BA%9B%E6%95%B0%E6%8D%AE%E5%9D%97%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%E7%9B%AE%E5%89%8D%E7%9A%84%E7%A0%94%E7%A9%B6%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%8D%95%E4%B8%AA%20SRAM%20%E5%8C%BA%E5%9D%97%E5%86%99%E5%85%A5%EF%BC%9AED%20%E5%BC%95%E8%84%9A%E4%B8%8D%E4%BC%9A%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%B8%8D%E6%98%AF%20256%20%E5%AD%97%E8%8A%82%20SRAM%20%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E5%AD%97%E8%8A%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%AE%8C%E5%85%A8%20SRAM%20%E5%86%99%E5%85%A5%EF%BC%9A%E5%B7%A5%E4%BD%9C%E5%8F%AF%E9%9D%A0-ED%20%E5%BC%95%E8%84%9A%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E5%92%8C%20I2C%20%E4%B8%BB%E7%AB%99%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%3E%E5%B0%9D%E8%AF%95%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%9A%E5%B0%86%20ED%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%20ED_CONFIG%20%3D%201100b%EF%BC%88%E5%86%99%E5%85%A5%20SYNCH_BLOCK%20%E6%97%B6%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%89%EF%BC%8C%E5%B9%B6%E5%B0%86%E7%9B%AE%E6%A0%87%E6%95%B0%E6%8D%AE%E5%9D%97%E8%AE%BE%E7%BD%AE%E4%B8%BA%20SYNCH_DATA_BLOCK-%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3ENTAG5%20Link%20%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%B8%80%E7%A7%8D%E9%85%8D%E7%BD%AE%E6%96%B9%E6%B3%95%EF%BC%8C%E5%AE%83%E5%85%81%E8%AE%B8%20ED%20%E5%BC%95%E8%84%9A%E5%9C%A8%3CSPAN%3E%3C%2FSPAN%3E%E5%8D%95%E4%B8%AA%20SRAM%20%E5%9D%97%E5%86%99%E5%85%A5%E6%97%B6%E5%8F%AF%E9%9D%A0%E5%9C%B0%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E5%86%99%E5%85%A5%E6%95%B4%E4%B8%AA%20SRAM%EF%BC%9F%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E5%BB%BA%E8%AE%AE%E9%87%87%E7%94%A8%E4%BB%80%E4%B9%88%E6%96%B9%E6%B3%95%E6%9D%A5%E5%AE%9E%E7%8E%B0%E7%9B%B4%E9%80%9A%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%AB%98%E6%95%88%E7%9A%84%E5%B0%8F%E9%A2%9D%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2247791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTAG5%20Link%3A%20Single%20SRAM%20Block%20Write%20Not%20Triggering%20I2C%20Master%20Read%20-%20Full%20SRAM%20Write%20Works%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247791%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257240%22%20target%3D%22_blank%22%3E%40kavya_ap%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E7%9B%B4%E6%8E%A5%E5%AE%9E%E7%8E%B0%E5%8D%95%E4%B8%AA%20SRAM%20%E6%95%B0%E6%8D%AE%E5%9D%97%E5%86%99%E5%85%A5%E6%97%B6%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20ED%20%E5%BC%95%E8%84%9A%E3%80%82%E6%AD%A3%E5%A6%82%E4%BD%A0%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E7%9B%B4%E9%80%9A%E6%A8%A1%E5%BC%8F%E8%A6%81%E6%B1%82%E4%BB%8E00%E5%B0%8F%E6%97%B6%E5%88%B03Fh%E7%9A%84SRAM%E5%86%99%E5%85%A5%E4%BB%A5%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7ED%E5%BC%95%E8%84%9A%EF%BC%8C%E5%A6%82%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12364.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENTAG%205-%3C%2FA%3E%20%E5%8F%8C%E5%90%91%E6%95%B0%E6%8D%AE%E4%BA%A4%E6%8D%A2%EF%BC%8C%E5%9B%BE%201%20%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E6%AD%A3%E7%A1%AE%E5%AE%9E%E6%96%BD%E4%BC%A0%E9%80%92%EF%BC%8C%E8%AF%B7%E9%81%B5%E5%AE%88%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12364.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENTAG%205%20-%20%E5%8F%8C%E5%90%91%E6%95%B0%E6%8D%AE%E4%BA%A4%E6%8D%A2%3C%2FA%3E%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EEduardo%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NTAG5%20Link%3A%20Single%20SRAM%20Block%20Write%20Not%20Triggering%20I2C%20Master%20Read%20-%20Full%20SRAM%20Write%20Works%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FLINGO-BODY%3E
