NFC Antenna Design Tool Source Code
akif_turker
I try to customise some values on NFC Antenna Design Tool software for PN7150, but I can not. For example, I have a ready antenna like Molex 1462360001. On the datasheet of antenna La, Ca, Ra, Fra and Q values are given. I want to calculate matching and EMC Filter circuit component values quickly. Of course, I can find the calculation formulas in the PN7150 datasheet, but it would be nice if I could make calculations for different antennas in a short time.
May you share NFC Antenna Design Tool source code?
I can customise some values for flexible use. I believe it will also help most of the people developing their antenna design.
Akif
Tags (3)
fabio_schmuki
Hi akif,
struggling at the same point as you. I'd like to calculate the matching network for the Molex Antenna: 1462362122.
Did you had sucess and may you can share your calculation?
BR Fabio
vicentegomez
Sorry at this moment we can not share the source code for the antenna design
BTW
we are working on version 2 of this tool, it will available soon.
regards
Vicente Gomez
