Manipulate Keystore File from Card Test Framework
johannesdev
using the Card Test Framework it is possible to export/import .key files. Hereby it is easy for me to test a DESFire Card "Layout" where I can export keys from the Card Test Framework and import it to RFIDDiscover and vice-versa.
Unfortunately I can only open and read/write this Keystore file using the two programs.However, I would really want to get keys from a third source, write it to a .key file and then open it using the NXP Card Test Framework.
It seems that the .key file is some binary data stream export from some .NET classes. Is there a wrapper from NXP or an class definition?
Tanks for any help!
EduardoZamora
Hello @johannesdev
Hope you are doing well.
My apologies, there is no information available about modifying or creating compatible .key files to work with these tools, as this may be a security topic and we do not have access to this information.
I truly apologize for the inconvenience.
Eduardo.
EduardoZamora
Hello @johannesdev
Eduardo.
%3CLINGO-SUB%20id%3D%22lingo-sub-1860550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EManipulate%20Keystore%20File%20from%20Card%20Test%20Framework%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1860550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Eusing%20the%20%3CEM%3ECard%20Test%20Framework%3C%2FEM%3E%20it%20is%20possible%20to%20export%2Fimport%20.key%20files.%20Hereby%20it%20is%20easy%20for%20me%20to%20test%20a%20DESFire%20Card%20%22Layout%22%20where%20I%20can%20export%20keys%20from%20the%20%3CEM%3ECard%20Test%20Framework%3C%2FEM%3E%20and%20import%20it%20to%20%3CEM%3ERFIDDiscover%3C%2FEM%3E%20and%20vice-versa.%3C%2FP%3E%3CP%3EUnfortunately%20I%20can%20only%20open%20and%20read%2Fwrite%20this%20Keystore%20file%20using%20the%20two%20programs.However%2C%20I%20would%20really%20want%20to%20get%20keys%20from%20a%20third%20source%2C%20write%20it%20to%20a%20.key%20file%20and%20then%20open%20it%20using%20the%20%3CEM%3ENXP%20Card%20Test%20Framework%3C%2FEM%3E.%3C%2FP%3E%3CP%3EIt%20seems%20that%20the%20.key%20file%20is%20some%20binary%20data%20stream%20export%20from%20some%20.NET%20classes.%20Is%20there%20a%20wrapper%20from%20NXP%20or%20an%20class%20definition%3F%3C%2FP%3E%3CP%3ETanks%20for%20any%20help!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Manipulate%20Keystore%20File%20from%20Card%20Test%20Framework%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F146905%22%20target%3D%22_blank%22%3E%40johannesdev%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMy%20apologies%2C%20there%20is%20no%20information%20available%20about%20modifying%20or%20creating%20compatible%20.key%20files%20to%20work%20with%20these%20tools%2C%20as%20this%20may%20be%20a%20security%20topic%20and%20we%20do%20not%20have%20access%20to%20this%20information.%3C%2FP%3E%0A%3CP%3EI%20truly%20apologize%20for%20the%20inconvenience.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EEduardo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
